justinrh 267 Posted May 24, 2021 Posted May 24, 2021 The info about the TV NICs not being able to do the job is very surprising to me. I figured Gigabit NICs and the associated Ethernet technology are such a commodity that even low-end, off-brand stuff should work well. Wow. Good to know!
Luke 42246 Posted May 25, 2021 Posted May 25, 2021 @KodiaK has this helped you? Are you still having an issue with this?
KodiaK 3 Posted May 25, 2021 Author Posted May 25, 2021 Well, it seems that switching the TV to wi-fi might have solved the issue. But I would still like if somebody might be able to tell me from the log that the ethernet connection was the actual cause.
Luke 42246 Posted May 25, 2021 Posted May 25, 2021 5 minutes ago, KodiaK said: Well, it seems that switching the TV to wi-fi might have solved the issue. But I would still like if somebody might be able to tell me from the log that the ethernet connection was the actual cause. That's interesting. Thanks for the feedback.
ebr 16338 Posted May 26, 2021 Posted May 26, 2021 5 hours ago, KodiaK said: But I would still like if somebody might be able to tell me from the log that the ethernet connection was the actual cause There isn't really a way for us to be sure but I think that is a rational conclusion at this point. 1
