kaledi 42 Posted May 22, 2021 Posted May 22, 2021 Just upgraded to the latest version of Emby server on Synology NAS. I've enabled the option in the movie library to put collections together, but I don't see collections, and I don't see movies that should be in a collection, in a collection. What am I doing incorrect?
Carlo 4561 Posted May 22, 2021 Posted May 22, 2021 Hi, After you change/set the option you need to run a library scan for them to be created.
Solution Luke 42203 Posted May 22, 2021 Solution Posted May 22, 2021 HI there, did you make sure to read the help text at the top of the library options dialog? Changing the options will not apply to existing content unless you refresh their metadata.
kaledi 42 Posted May 22, 2021 Author Posted May 22, 2021 Ahh, ok, so I need to refresh metadata. thanks 1
