ebr 16337 Posted June 11, 2021 Posted June 11, 2021 1 hour ago, rodainas said: @cayarstested the latest beta, same results, no subtitle showing up. Exactly what beta did you test?
rodainas 191 Posted June 11, 2021 Author Posted June 11, 2021 The one posted in here Emby Android TV Release Notes (BETA) - Android - Emby Community Installed app-amazon-release 2.0.26 Fix crash entering audio player before playback started Restore DD bitrate constraint on Fire but up to 640k Change subtitle offset increment to 250ms (please only install the proper release for your platform) app-google-release.zipapp-amazon-release.zip
Carlo 4561 Posted June 11, 2021 Posted June 11, 2021 I have a Frestick 4K I can use to do some testing for you. Could you provide a sample file that has this problem?
rodainas 191 Posted June 12, 2021 Author Posted June 12, 2021 @cayars Sent you PM with link, thank you.
Carlo 4561 Posted June 14, 2021 Posted June 14, 2021 (edited) I first tested via web player where both subs playback. Next I tried on the FireStick 4K.with 2.0.26a and neither sub would play for me. @ebr let me know if there is anything specific you would like me to test. Edited June 14, 2021 by cayars 1
ebr 16337 Posted June 14, 2021 Posted June 14, 2021 22 minutes ago, cayars said: I first tested via web player where both subs playback. The item was transcoding then? 22 minutes ago, cayars said: Next I tried on the FireStick 4K.with 2.0.26a and neither sub would play for me. How was it playing then?
Carlo 4561 Posted June 14, 2021 Posted June 14, 2021 I just sent you an in app log from the FireStick 4K @ebr user Carlo
hisune 3 Posted April 20, 2022 Posted April 20, 2022 (edited) @cayars @Luke @ebr I have the same problem, ASS/SSA subtitles not showing up in AndroidTV client, and this question has led me to consider whether to buy a Emby Premiere or not. My AndroidTV client version is 2.0.70g Edited April 20, 2022 by hisune
rodainas 191 Posted April 20, 2022 Author Posted April 20, 2022 8 hours ago, hisune said: @cayars @Luke @ebr I have the same problem, ASS/SSA subtitles not showing up in AndroidTV client, and this question has led me to consider whether to buy a Emby Premiere or not. My AndroidTV client version is 2.0.70g This happens with a a few files, a minor percentage but stills happens. In contrast Kodi shows all those ass subtitles. The alternative I took was to batch convert those subtitles to srt to avoid the inconvenience w emby for androidtv in the firestick 4k.
hisune 3 Posted April 20, 2022 Posted April 20, 2022 2 minutes ago, rodainas said: This happens with a a few files, a minor percentage but stills happens. In contrast Kodi shows all those ass subtitles. The alternative I took was to batch convert those subtitles to srt to avoid the inconvenience w emby for androidtv in the firestick 4k. What batch conversion format tool do you use? In addition, if manual format conversion cannot be automated, it will be troublesome to add movies.
rodainas 191 Posted April 20, 2022 Author Posted April 20, 2022 59 minutes ago, hisune said: What batch conversion format tool do you use? In addition, if manual format conversion cannot be automated, it will be troublesome to add movies. I use linux cli with a ffmpeg batch command if you are interested I can look for it and share it. Automation will depend on how you add new media to your libraries.
ebr 16337 Posted April 20, 2022 Posted April 20, 2022 10 hours ago, hisune said: @cayars @Luke @ebr I have the same problem, ASS/SSA subtitles not showing up in AndroidTV client, and this question has led me to consider whether to buy a Emby Premiere or not. My AndroidTV client version is 2.0.70g Hi. This topic is from a few versions ago. Can we please look at an example? Please attach the information requested in how to report a media playback issue. Thanks!
Weevillo 30 Posted April 21, 2022 Posted April 21, 2022 I can report that I had the same issue last weekend, but it got resolved. It started with not being able to show the subtitles on any Emby client (ATV, general Android app, web player or ET), so I tried Jellyfin and it worked there, same with MPV on my PC. The issue seems to have stemmed from me initializing a metadata refresh or library scan (can't remember which one I'm afraid) after having just recently changed the name of the movie files. I've had similar issues related to file naming in the past; one such example was my episode files having too long names and that somehow broke Emby's ability to read metadata, so I couldn't play any of them back (I had enabled long character names in regedit). Fixed that one by including "\\?\" in the destination path. Anyhow, might be something to look into. The problem went away the next day and I was able to play the movie files with ASS subtitles (all this time the server reported back that the files were direct playing).
DylanParham 15 Posted October 12, 2022 Posted October 12, 2022 (edited) Good afternoon! It seems like I might be having a similar problem. I am streaming to a Shield TV and the ASS/SSA subtitles are not displaying on the app. I tested on Firefox as well as Emby Theater and both seem to be working properly with and without transcode. I have two different sets of ASS subs for this media (one with and one without honorifics) and neither are displaying when playing the content when direct playing to the Shield TV. Exactly what you were doing and what happened. Include the name of whatever you played if it is a playback problem Opened S1E1 of Reincarnated as a Sword (episode titled Catgirl Meets Sword in the logs), played about 20 seconds of it, no ASS subtitles were displayed. The time you sent the log (in Eastern Time please - UTC -5) 3:13 PM EST on 10/12/22. The name of the Emby user on the local server that was logged in at the time Dylan Thanks for everything you guys do. If you need any additional info, please let me know! Additional notes: The forced ASS subtitles on the first entry work fine, the second do not. embyserver.txt Edited October 12, 2022 by DylanParham more info
ebr 16337 Posted October 12, 2022 Posted October 12, 2022 @DylanParham Hi. I notice you have two subtitles marked as default. Does it make a difference if you remove that flag from one of those tracks?
DylanParham 15 Posted October 13, 2022 Posted October 13, 2022 (edited) @Luke Hey sorry, I DM'd @ebr this morning but it looks like they haven't read it yet so I'll go ahead and post here. Didn't want to flood the thread with questions. When you say that I have two default subtitle tracks selected, do you mean between the two different files for the same episode? How would I go about removing the flag for one of the tracks? If it makes a difference, the problem was occurring before I added the second (forced, top row in the screenshot) file - I only added the second file so I could watch in the meantime since the subtitle track for it works. The one marked 'Kaleido' (bottom row) is the one having issues. Neither of the subtitle tracks show. The unmarked version (top row) plays fine. Another note, I did update to 4.8.0.12 beta this morning from 4.8.0.10 beta and still having the same issue. Edited October 13, 2022 by DylanParham
ebr 16337 Posted October 13, 2022 Posted October 13, 2022 Sorry, my bad. I read your screen grab wrong. Didn't realize it was two different versions. 1
Luke 42243 Posted October 14, 2022 Posted October 14, 2022 Editing track flags is something you can do with software such as mkvtoolnix. You can also try sideloading our standard android app on the same device and see how that compares. https://emby.media/emby-for-android.html Thanks.
DylanParham 15 Posted October 14, 2022 Posted October 14, 2022 (edited) 4 hours ago, Luke said: Editing track flags is something you can do with software such as mkvtoolnix. You can also try sideloading our standard android app on the same device and see how that compares. https://emby.media/emby-for-android.html Thanks. @Luke & @ebr Sideloaded android app and it did not display the subtitles. Turning on the forced display subtitle flag caused the subtitles to appear properly in both the Android and Android TV app. Is it expected behavior to not display the subtitles if the forced flag is not enabled, i.e. should I expect to adjust any future episodes that I get in that format? Edited October 14, 2022 by DylanParham
Luke 42243 Posted October 14, 2022 Posted October 14, 2022 12 minutes ago, DylanParham said: @Luke & @ebr Sideloaded android app and it did not display the subtitles. Turning on the forced display subtitle flag caused the subtitles to appear properly in both the Android and Android TV app. Is it expected behavior to not display the subtitles if the forced flag is not enabled, i.e. should I expect to adjust any future episodes that I get in that format? Default display depends on your subtitle preferences but you always manually select them in the video player.
DylanParham 15 Posted October 14, 2022 Posted October 14, 2022 (edited) @Luke Correct - in this instance I am selecting the English (Default ASS) subs and they are not displaying when the media is direct playing. The only way I was able to get the original file to show subs (without the forced flag on) was to enable the "Burn in SSA Subs for Formatting" which obviously causes transcoding. If I flip the forced flag on, then I can direct play the updated file with no issue. Here are my current subtitle settings on the Shield: Edited October 14, 2022 by DylanParham img
Luke 42243 Posted October 14, 2022 Posted October 14, 2022 6 minutes ago, DylanParham said: @Luke Correct - in this instance I am selecting the English (Default ASS) subs and they are not displaying when the media is direct playing. The only way I was able to get the original file to show subs (without the forced flag on) was to enable the "Burn in SSA Subs for Formatting" which obviously causes transcoding. If I flip the forced flag on, then I can direct play the updated file with no issue. Here are my current subtitle settings on the Shield: The default mode doesn't guarantee that they'll be selected when you start playback, but you can always select them during playback. Did you try that?
