PINKISH 2 Posted May 22, 2021 Posted May 22, 2021 Emby let's you literally change and lock everything to avoid any errors in the databse but not images... the amount of time i tried changing a picture for a tv show and emby changing it back to something else or a wrong images by itself. Please allow us to lock images. Recently emby renaming the season 2 episodes love death and robots to the wrong order.
Luke 42203 Posted May 22, 2021 Posted May 22, 2021 Hi, currently there is no need for a lock for this because Emby does not change images. Quote emby changing it back to something else Most likely you have the original image still sitting around in your media folders, and this always takes priority so that's why the library scan changes it back. If you had enabled the option to allow emby to save images to media folders, then it would have overwritten the originals when you did your manual edits.
PINKISH 2 Posted May 22, 2021 Author Posted May 22, 2021 That's the issue, i've changed the images multiple times with save images to media folder and it always change it back 1
Luke 42203 Posted May 22, 2021 Posted May 22, 2021 Hi there, please go over a specific example: Thanks.
