Portugafmr 0 Posted May 24, 2021 Posted May 24, 2021 I have the same problems, please help The new system broke may collection files and created a new one, a great mass embyserver.txt
thekingswolf 48 Posted May 24, 2021 Posted May 24, 2021 2 minutes ago, Portugafmr said: I have the same problems, please help The new system broke may collection files and created a new one, a great mass embyserver.txt 6.86 MB · 0 downloads i noticed some changes to collections as well, they go into it here
Happy2Play 9802 Posted May 24, 2021 Posted May 24, 2021 (edited) 7 minutes ago, Portugafmr said: I have the same problems, please help The new system broke may collection files and created a new one, a great mass embyserver.txt 6.86 MB · 1 download Not sure why it is happening to so many but your database is locked so basically nothing is happening because your database can not update. 2021-05-24 19:41:42.365 Error Server: Error processing request *** Error Report *** Version: 4.6.0.50 Command line: C:\Users\MARCELO\AppData\Roaming\Emby-Server\system\EmbyServer.dll Operating system: Microsoft Windows 10.0.19042 Framework: .NET Core 3.1.13 OS/Process: x64/x64 Runtime: C:/Users/MARCELO/AppData/Roaming/Emby-Server/system/System.Private.CoreLib.dll Processor count: 8 Data path: C:\Users\MARCELO\AppData\Roaming\Emby-Server\programdata Application path: C:\Users\MARCELO\AppData\Roaming\Emby-Server\system SQLitePCL.pretty.SQLiteException: Busy: database is locked SQLitePCL.pretty.SQLiteException: Exception of type 'SQLitePCL.pretty.SQLiteException' was thrown. at SQLitePCL.pretty.SQLiteException.CheckOk(sqlite3 db, Int32 rc) at SQLitePCL.pretty.StatementImpl.MoveNext() at Emby.Server.Implementations.Data.SqliteUserDataRepository.SaveUserData(Int64 internalUserId, Int64 itemId, UserItemData userData, CancellationToken cancellationToken) at Emby.Server.Implementations.Library.UserDataManager.SaveUserData(User user, BaseItem item, UserItemData userData, UserDataSaveReason reason, CancellationToken cancellationToken) at Emby.Server.Implementations.Session.SessionManager.OnPlaybackProgress(User user, BaseItem item, PlaybackProgressInfo info, SessionInfo sessionInfo) at Emby.Server.Implementations.Session.SessionManager.OnPlaybackProgress(PlaybackProgressInfo info, Boolean isAutomated) at Emby.Server.Implementations.Services.ServiceController.GetTaskResult(Task task) at Emby.Server.Implementations.Services.ServiceHandler.ProcessRequestAsync(HttpListenerHost appHost, IRequest httpReq, IResponse httpRes, RestPath restPath, String responseContentType, CancellationToken cancellationToken) at Emby.Server.Implementations.HttpServer.HttpListenerHost.RequestHandler(IRequest httpReq, ReadOnlyMemory`1 urlString, ReadOnlyMemory`1 localPath, CancellationToken cancellationToken) Source: SQLitePCL.pretty TargetSite: Void CheckOk(SQLitePCLEx.sqlite3, Int32) Do you see multiple instances of Emby in TaskManager? If you shutdown Emby does it still show in TaskManager? Edited May 24, 2021 by Happy2Play
Carlo 4561 Posted May 24, 2021 Posted May 24, 2021 Try the instructions in this article https://support.emby.media/support/solutions/articles/44002210894-corrupt-database Start with "Remove Database Locks" which is normally all that is needed.
Portugafmr 0 Posted May 24, 2021 Posted May 24, 2021 23 minutes ago, Happy2Play said: Não sei por que isso está acontecendo com tantos, mas seu banco de dados está bloqueado, então basicamente nada está acontecendo porque seu banco de dados não pode ser atualizado. Você vê várias instâncias de Emby no TaskManager? Se você desligar o Emby, ele ainda aparecerá no TaskManager? Emby Server e Embytray
Portugafmr 0 Posted May 24, 2021 Posted May 24, 2021 Eu tenho os mesmos problemas, por favor me ajude O novo sistema quebrou muitos arquivos de coleta e criou um novo, uma grande massa
Happy2Play 9802 Posted May 24, 2021 Posted May 24, 2021 Just now, Portugafmr said: I have the same problems, please help The new system broke many collection files and created a new, a large mass Sorry are you having a issue with library scanning or the major change of how Collections are being made now?
Portugafmr 0 Posted May 24, 2021 Posted May 24, 2021 If I return the Friday backup that everything was fine, will it solve? This happened after the update!
Happy2Play 9802 Posted May 24, 2021 Posted May 24, 2021 Just now, Portugafmr said: If I return the Friday backup that everything was fine, will it solve? This happened after the update! What happened after the update, please provide examples as this topic is about Failed library scans not Collection. Depending on the type of backup it may resolve your issue and revert to previous version but that depends on your backup.
Portugafmr 0 Posted May 24, 2021 Posted May 24, 2021 4 minutes ago, Happy2Play said: Sorry are you having a issue with library scanning or the major change of how Collections are being made now? Everything I had from collections is gone. There were others that are not the ones I made
Portugafmr 0 Posted May 24, 2021 Posted May 24, 2021 9 minutes ago, Happy2Play said: Desculpe, você está tendo problemas com a digitalização da biblioteca ou uma grande mudança na forma como as coleções estão sendo feitas agora? After the system update! I'm having trouble scanning all libraries! I don't see any new items. Besides my collection is gone
Happy2Play 9802 Posted May 24, 2021 Posted May 24, 2021 Just now, Portugafmr said: After the system update! I'm having trouble scanning all libraries! I don't see any new items. Besides my collection is gone Please post as server log. Collection are a separate issue.
Carlo 4561 Posted May 25, 2021 Posted May 25, 2021 Have you run a full library scan and then a scan for missing meta-data? That will most likely get you back to what you had.
