marauder 18 Posted May 21, 2021 Posted May 21, 2021 I just updated to emby 4.6.0.50 and now when I go to view on my Samsung tv horizontal Home Screen doesn’t work only vertical. when in horizontal it defaults to tvshows and shows all tvshows. No next up, continue watching, latest episodes. When I change the view to vertical and restart the app I get all those back.
marauder 18 Posted May 22, 2021 Author Posted May 22, 2021 (edited) Here are some photos and a video to help show the issue. in the first photo you can see the home and favorites pages are gone. https://www.dropbox.com/s/bf35nrmhh8xc0ko/2021-05-21 23.24.14.mov?dl=0 Edited May 22, 2021 by marauder
carratt3582 0 Posted May 22, 2021 Posted May 22, 2021 I'm also getting this error in Emby Theatre v3.0.15 on all my devices. Any help would be greatly appreciated.
Luke 42241 Posted May 22, 2021 Posted May 22, 2021 There are some sporadic reports of the content type of some libraries being lost on the upgrade to 4.6. Check the TV library in Emby library setup. If it's showing as mixed content type, then you'll need to remove the library and add it back as a TV library. Apologies for the disruption. Please let us know if this helps.
marauder 18 Posted May 22, 2021 Author Posted May 22, 2021 16 minutes ago, Luke said: There are some sporadic reports of the content type of some libraries being lost on the upgrade to 4.6. Check the TV library in Emby library setup. If it's showing as mixed content type, then you'll need to remove the library and add it back as a TV library. Apologies for the disruption. Please let us know if this helps. i'm seeing it as mixed content, if I remove and read it will I lose all by play history/show progress?
Solution Luke 42241 Posted May 22, 2021 Solution Posted May 22, 2021 1 minute ago, marauder said: i'm seeing it as mixed content, if I remove and read it will I lose all by play history/show progress? Generally, no because the internet metadata should be the same both before and after.
marauder 18 Posted May 22, 2021 Author Posted May 22, 2021 That fixed the issue. Images library are rebuilding now.
Luke 42241 Posted May 23, 2021 Posted May 23, 2021 Thanks for the feedback. Apologies for the disruption.
