unisoft 355 Posted May 21, 2021 Posted May 21, 2021 (edited) Before 4.6.0.50, the screen display used to show the embedded track numbers for each track/chapter of an audiobook or album in Music. It's gone in the upgrade when the display simply shows a LIST of tracks? Checked Emby Theatre and web app so far Please fix... Edited May 21, 2021 by unisoft
Happy2Play 9802 Posted May 21, 2021 Posted May 21, 2021 Can you elaborate Book Unless you are referring to Folder view
unisoft 355 Posted May 21, 2021 Author Posted May 21, 2021 2 minutes ago, Happy2Play said: Can you elaborate Book Unless you are referring to Folder view That's exactly before and after. I use FOLDER VIEW for Audiobooks, but it did show track numbers as they are embedded in the files as ID3v2 tags. Looks odd now without numbering.
Happy2Play 9802 Posted May 21, 2021 Posted May 21, 2021 Yep Folder view are by Sort order. Music is the same way.
Luke 42203 Posted May 21, 2021 Posted May 21, 2021 We will be continuing to work on expanding and improving folder views. 1
unisoft 355 Posted May 21, 2021 Author Posted May 21, 2021 29 minutes ago, Luke said: We will be continuing to work on expanding and improving folder views. It was doing it before the upgrade though? The upgrade removed the track numbering, that's a bug surely? Can't see a reason why it would be removed due to it being useful.
