Solution Guest Posted May 21, 2021 Solution Posted May 21, 2021 (edited) Hi guys, TrueNAS-12.0-U3.1 Emby Version: n/a ?? I installed the emby server plugin from the plugins section of TrueNAS. Almost everything worked but know I found out that I can't connect to the emby server with any wifi device. My shield which is connected via lan works. The emby ui via browser can only be opened when the device is connected with lan. Summarized: I can't connect to emby server with the emby app or webbrowser on my two android devices with wifii. The funny thing is that I can connect to my NAS and all other network devices. Only the emby server is not reachable. What I've already tried: Restart router, switches, NAS (stop, start and restart the emby jail). +++ Edit: +++ Now I think I know why this happens: Just now one of my android devices was in the root mesh of my fritzbox and i could connect to emby server. Then I switched back to the other mesh and then I couldnt connect. +++ Edit Edit: +++ I forgot to restart my fritz repeater. After doing that everything works fine. Really really weird... Edited May 21, 2021 by DooDafiit solution
Luke 42237 Posted May 22, 2021 Posted May 22, 2021 Hi, glad to hear it's resolved now. Thanks for following up.
