thegrunge 29 Posted May 29, 2021 Posted May 29, 2021 (edited) Observation. the emby page of my server remained open while I left home with my laptop to my girlfriend for the weekend. when i opened my laptop i could see the functional dashboard until i refreshed the page. After a few minutes the update started up again Enregistrement d’écran, le 2021-05-28 à 21.47.59.mov Edited May 29, 2021 by thegrunge
Solution Luke 42203 Posted May 29, 2021 Solution Posted May 29, 2021 I believe I've chased this down and that it is isolated to when the server admin restricts their own remote control access of other devices. So that should make it easy to resolve and thankfully, that also means this will not be a widespread issue. 1 1
xdwarfx 15 Posted May 29, 2021 Posted May 29, 2021 24 minutes ago, Luke said: I believe I've chased this down and that it is isolated to when the server admin restricts their own remote control access of other devices. So that should make it easy to resolve and thankfully, that also means this will not be a widespread issue. YES YES YES!!! I looked at my own admin user account and for some reason Remote Control was completely turned off. Turning it back on for both options did the trick!!! @Luke thank you very much looking into this and being patient with us in this topic. 1 1
thegrunge 29 Posted May 29, 2021 Posted May 29, 2021 (edited) @LukeYou are right these 2 options were unchecked in my user account! Everything is working now The first option does the job without having to check the second. Edited May 29, 2021 by thegrunge
Tonyemby69 1 Posted May 30, 2021 Posted May 30, 2021 21 hours ago, Luke said: I believe I've chased this down and that it is isolated to when the server admin restricts their own remote control access of other devices. So that should make it easy to resolve and thankfully, that also means this will not be a widespread issue. Confirmed this fixes it. 1
rbjtech 5337 Posted May 30, 2021 Posted May 30, 2021 Thanks @Luke - fixed for me too - not sure why I would have removed those options in the first place but enabling them brings back the active updates.
Brendon 124 Posted May 31, 2021 Author Posted May 31, 2021 Worked for me too @Luke i only had the 'Allow remote control of other users' disabled though, shared devices was enabled already. 1
TheWERLD 3 Posted June 3, 2021 Posted June 3, 2021 Thanks for fixing the timer issue. Mine is now working with update 4.6.2.0 2
