TheWERLD 3 Posted May 26, 2021 Posted May 26, 2021 My timer issues started after updating from 4.5.4.0 to 4.6.0.50. I then upgraded to 4.6.1.0, hoping for a fix, but still no luck. Hope the version info is helpful. I'm currently using Emby from Google Chrome on Windows 10 and 99% of my movies are Direct Play.
scott46953 31 Posted May 26, 2021 Posted May 26, 2021 I submited a log file of my server not upgrading however I noticed that my log settings was turned off?? but why was it making a log file?? Does turning on the log file add more information? Or is it running while off due to an older bug? Anyways i turned it on and plan on doing a couple of restarts shortly to see if anything has changed. I'm still stuck on 4.6.0.50 while it says update to 4.6.1.0 Here is the log file, I just made of the update error... Never mind, today it took 2 restarts and now it finally updated. So recap, 4 restarts yesterday morning and today 2 restarts and now its updated. version=4.6.1.0
Luke 42203 Posted May 26, 2021 Posted May 26, 2021 Quote that my log settings was turned off?? but why was it making a log file?? @scott46953 we do not have any settings to completely turn off logging. What gave you this impression?
Luke 42203 Posted May 26, 2021 Posted May 26, 2021 9 hours ago, Brendon said: If i do that @Luke, i will see any current remote connections, the progress bars do not move, nor do the numerical timers, if i refresh again the info will update, so progress moves to current position and numerical status will change to show current time index but they still stay static and do not move, if i don't refresh they will disappear within a few minutes, i have witnessed them appear and reappear at times without doing anything as well. So to me yes the data is correct upon each refresh. Now here's the kicker, if i start a stream within my LAN it will show on the dashboard correctly, both progress bar and timers show active progress BUT it will force all remote connections to vanish and the only way to see them again at all is to stop the LAN stream. So in other words if you were to just sit there and keep hitting the refresh button, everything would look fine?
Carlo 4561 Posted May 26, 2021 Posted May 26, 2021 1 hour ago, Luke said: @scott46953 we do not have any settings to completely turn off logging. What gave you this impression? He might be thinking of the "Enable debug logging" switch in the Logs menu. This switch just changes the amount of logging done but doesn't need to be in "debug" mode unless asked to do so.
Luke 42203 Posted May 26, 2021 Posted May 26, 2021 1 minute ago, cayars said: He might be thinking of the "Enable debug logging" switch in the Logs menu. This switch just changes the amount of logging done but doesn't need to be in "debug" mode unless asked to do so. Yes I know, that is obvious enough and what I expected, but I still asked because I wanted to hear the explanation from him.
Carlo 4561 Posted May 26, 2021 Posted May 26, 2021 Just now, Luke said: Yes I know, that is obvious enough and what I expected, but I still asked because I wanted to hear the explanation from him. Sorry.
scott46953 31 Posted May 26, 2021 Posted May 26, 2021 (edited) 1 hour ago, Luke said: @scott46953 we do not have any settings to completely turn off logging. What gave you this impression? my server has a off on for log in the log settings. I remember reading something awhile back about the log still running in off mode if the server was restarted instead of shutting down. example, ff logs still writing to log folder even when logs are off on server, sometimes taking up alot of space. after long periods of time, since i got a big drive just for the server itself, i manually delete the logs completely after several weeks, sometimes a month. depending. currently i just checked while sitting at the server and the log folder says, 774 files mostly ff and 6gb used. dates from 5/22 up most be from when i deleted it last? idk Edited May 26, 2021 by scott46953
thegrunge 29 Posted May 26, 2021 Posted May 26, 2021 @Lukei update linux emby server to 4.6.1.0 and restart 2 times, but the problem is always présent. thanks.
Luke 42203 Posted May 26, 2021 Posted May 26, 2021 25 minutes ago, scott46953 said: my server has a off on for log in the log settings. What exactly is the name of the option?
xdwarfx 15 Posted May 26, 2021 Posted May 26, 2021 1 hour ago, scott46953 said: my server has a off on for log in the log settings. I remember reading something awhile back about the log still running in off mode if the server was restarted instead of shutting down. example, ff logs still writing to log folder even when logs are off on server, sometimes taking up alot of space. after long periods of time, since i got a big drive just for the server itself, i manually delete the logs completely after several weeks, sometimes a month. depending. currently i just checked while sitting at the server and the log folder says, 774 files mostly ff and 6gb used. dates from 5/22 up most be from when i deleted it last? idk With all respect but at the moment it is not clear to me what this has to do with the issue in this topic. I apologize if it is related, otherwise start your own topic as many people are waiting for a solution for the problem at hand. Thanks. 1
thegrunge 29 Posted May 26, 2021 Posted May 26, 2021 (edited) @LukeIt's not urgent, but I like to understand why some transcodes with certain devices. It allows me to understand a lot of things. On the other hand, from the Emby Diagnostics plugin I can still the progress and see the reason for transcoding currently even with the bug present in the user sessions section. I added a video where we can see the progress. Enregistrement d’écran, le 2021-05-26 à 19.43.45.mov Edited May 26, 2021 by thegrunge
Brendon 124 Posted May 26, 2021 Author Posted May 26, 2021 (edited) 7 hours ago, Luke said: So in other words if you were to just sit there and keep hitting the refresh button, everything would look fine? As long as i don't start a local stream, yes. This is actually shown in the video i posted last night. Edited May 26, 2021 by Brendon
thegrunge 29 Posted May 26, 2021 Posted May 26, 2021 (edited) @LukeFor some reason I don't know, I left my dashboard open for a few minutes and when I came back to the screen I saw all the users live. when I did a refresh it disappeared. The funniest thing is that I was also listening to something... Edited May 26, 2021 by thegrunge
thegrunge 29 Posted May 26, 2021 Posted May 26, 2021 (edited) On 5/26/2021 at 6:08 PM, thegrunge said: @LukeIt's not urgent, but I like to understand why some transcodes with certain devices. It allows me to understand a lot of things. On the other hand, from the Emby Diagnostics plugin I can still the progress and see the reason for transcoding currently even with the bug present, in the user sessions section. It can be a clue, the dashbord does not work well but the plugin yes, I am on version 4.6.1.0 Edited May 29, 2021 by thegrunge
scott46953 31 Posted May 27, 2021 Posted May 27, 2021 10 hours ago, Luke said: What exactly is the name of the option? This is not a main issue right now. I guess the Dashboard is important... However, the log files are needed for fixing issues with Emby. But when we dont have any current issues, it shouldnt be making log files when turned off. It should temp turn on log file during an automatic update tho if possible, believe that would come handy in the future. Enable debug logging Debug logging should only be enabled as needed for troubleshooting purposes. The increased file system access may prevent the server machine from being able to sleep in some environments. 513 Logs I dont see any big issues as the server is running just fine, just needs some tuning. I'll keep watch on here, i'll jump in if i hear or see something. The current issues are not bothering me or my users. Keep up the good work. If you need anything just quote or ask. I'll try to keep up.
Luke 42203 Posted May 27, 2021 Posted May 27, 2021 7 minutes ago, scott46953 said: This is not a main issue right now. I guess the Dashboard is important... However, the log files are needed for fixing issues with Emby. But when we dont have any current issues, it shouldnt be making log files when turned off. It should temp turn on log file during an automatic update tho if possible, believe that would come handy in the future. Enable debug logging Debug logging should only be enabled as needed for troubleshooting purposes. The increased file system access may prevent the server machine from being able to sleep in some environments. 513 Logs I dont see any big issues as the server is running just fine, just needs some tuning. I'll keep watch on here, i'll jump in if i hear or see something. The current issues are not bothering me or my users. Keep up the good work. If you need anything just quote or ask. I'll try to keep up. Hi, turning off debug logging does not turn off logging altogether, but rather it just reduces the amount of information that is logged. I can promise you, there is no setting in Emby to complete turn off logging. That doesn't mean we can't add one, it just means there isn't one as of right now.
xdwarfx 15 Posted May 27, 2021 Posted May 27, 2021 @Luke do you need any more information from us, or do you have enough to start digging into this issue? Thanks 1
scott46953 31 Posted May 27, 2021 Posted May 27, 2021 Some DVR Recordings are stopping at 3 seconds... Example The Masked Dinger Last night, I had to manually add it from off the web... This morning so far i have found and deleted several programs at 3 seconds... I dont remember reading about this but If i missed this issue, disregaurd. I will dig into this deeper as the day goes... Catching one when it does it is most important at this point. Quad Tuner HDR Home Run and paid IPTV unlimited connections. WIll narrow it down if limited to and possible causes if i can.
Carlo 4561 Posted May 27, 2021 Posted May 27, 2021 (edited) 10 minutes ago, scott46953 said: Some DVR Recordings are stopping at 3 seconds... Example The Masked Dinger Last night, I had to manually add it from off the web... This morning so far i have found and deleted several programs at 3 seconds... I dont remember reading about this but If i missed this issue, disregaurd. I will dig into this deeper as the day goes... Catching one when it does it is most important at this point. Quad Tuner HDR Home Run and paid IPTV unlimited connections. WIll narrow it down if limited to and possible causes if i can. Hi, Have you noticed a pattern such that the failed recordings all come from the m3u source? Edited May 27, 2021 by cayars
scott46953 31 Posted May 27, 2021 Posted May 27, 2021 1 minute ago, cayars said: Hi, Have you noticed a pattern such that the failed recordings all come from the m3u source? Thats what i am trying to figure out now, but when i click on the latest recordings from the home screen and select a recording it doesnt take me to the recording anymore, it takes me to the what do you want to play next of that recording. So it will take me longer as i will have to write down each one and inspect. I used to be able to click each one, look at the time and back out, then go to the next... this last update changed that. I think it should go back to the original way. Will do this today, but i just got called out... so hopefully within a few hours i will get more information... sorry
Carlo 4561 Posted May 27, 2021 Posted May 27, 2021 @CBers, @Happy2Play Can one of you guys move this to a new thread since it doesn't belong here?
Luke 42203 Posted May 27, 2021 Posted May 27, 2021 @scott46953 we're happy to help you, but please keep this on topic and open new tickets about topics that aren't related to this. Thanks !
Edrock200 53 Posted May 28, 2021 Posted May 28, 2021 For the folks experiencing this, are you by chance using a cdn like cloudflare? If so try turning off brotli and rocket loader enhancements
xdwarfx 15 Posted May 28, 2021 Posted May 28, 2021 (edited) 5 hours ago, Edrock200 said: For the folks experiencing this, are you by chance using a cdn like cloudflare? If so try turning off brotli and rocket loader enhancements Good idea, i dont use Cloudflare CDN but i have turned off Safe Browsing in Chrome and also the option in Chrome to use a secure DNS. Maybe that has something to do with it but i have to wait untill a remote client plays something. Maybe someone else can try this before i am able to give a status update. Update: I tried this with 2 remote users and unfortunately it did not solve the issue. @Luke do you also have enough information in the entire topic to start diving into this issue? Thanks Edited May 28, 2021 by xdwarfx
