Luke 42289 Posted May 25, 2021 Posted May 25, 2021 1 minute ago, echoxxzz said: Putting the folder.jpg into the album folder didn't help either. Try running a library scan after doing that.
echoxxzz 22 Posted May 25, 2021 Posted May 25, 2021 9 minutes ago, Luke said: Try running a library scan after doing that. Yes!!!! It's working now. Doing the Scan or just Deleting the Library and recreating it the cover art shows up. I'll have to write a script to massage my music collection and move all my folder.jpg cover art files into the album folder vs. each (Disc X) folder. This is better for me as it cuts down on the # of cover art files I need to store. Question to others? How are most people filing their multi-disc albums if they don't use a "(Disc)" sub-folder structure?
Luke 42289 Posted May 25, 2021 Posted May 25, 2021 If that's a frequently used pattern then we can obviously do the work to support it. The flip side is the possible unintended consequence of showing a disc-specific image as the album image.
echoxxzz 22 Posted May 25, 2021 Posted May 25, 2021 35 minutes ago, Luke said: If that's a frequently used pattern then we can obviously do the work to support it. The flip side is the possible unintended consequence of showing a disc-specific image as the album image. I wouldn't fix it. I like the idea of a cover art for the album and separate art for the discs. This will be really nice for music boxed collections. 2
echoxxzz 22 Posted May 26, 2021 Posted May 26, 2021 On 25/05/2021 at 10:52, Luke said: That folder structure sounds fine, but make sure to configure the library option I mentioned. The folder name must also exactly match the album artist tag in the audio files How exact must the folder name match the albumartist tag? There are lots of artists (ie *NSYNC) that use characters in their name that you cannot use for a folder name. I enable the feature "Replace non-ASCII characters" in MusicBrainz Picard and it would name *NSYNC as _NYSNC.
Luke 42289 Posted May 26, 2021 Posted May 26, 2021 1 hour ago, echoxxzz said: How exact must the folder name match the albumartist tag? There are lots of artists (ie *NSYNC) that use characters in their name that you cannot use for a folder name. I enable the feature "Replace non-ASCII characters" in MusicBrainz Picard and it would name *NSYNC as _NYSNC. the server will normalize that as part of the comparison, so that should be ok. Well, maybe not if you have _nsync in your artist tag because the underscore is a valid file name character. But the comparison routine will strip out invalid characters such as * before comparing.
Flux02400 4 Posted May 27, 2021 Posted May 27, 2021 i Luke, other issue like this thread. In the folder view art does not appear for new imported music album: (i've down all sort of scan) ex:
Luke 42289 Posted May 27, 2021 Posted May 27, 2021 52 minutes ago, Flux02400 said: i Luke, other issue like this thread. In the folder view art does not appear for new imported music album: (i've down all sort of scan) ex: Do you have images in your folders? You need to have your own images in order to see images in folder views.
Flux02400 4 Posted May 27, 2021 Posted May 27, 2021 12 minutes ago, Luke said: Do you have images in your folders? You need to have your own images in order to see images in folder views. Ok, not for all, they are inside song for most of them but before the update folder takes pictures in metadata not in folder, i'll doing it
Luke 42289 Posted May 27, 2021 Posted May 27, 2021 19 minutes ago, Flux02400 said: Ok, not for all, they are inside song for most of them but before the update folder takes pictures in metadata not in folder, i'll doing it Yea I'll see what happened with that. Thanks.
slamthedoor 3 Posted May 27, 2021 Posted May 27, 2021 On 5/25/2021 at 5:25 PM, echoxxzz said: Question to others? How are most people filing their multi-disc albums if they don't use a "(Disc)" sub-folder structure? For me, I use the disc # tag and have all the files in an album folder, no disc sub folders. File name begins with disc number than track number.
echoxxzz 22 Posted May 27, 2021 Posted May 27, 2021 5 hours ago, slamthedoor said: For me, I use the disc # tag and have all the files in an album folder, no disc sub folders. File name begins with disc number than track number. I was actually considering changing to this very format.
Quek9 7 Posted January 22, 2023 Posted January 22, 2023 On 5/21/2021 at 2:27 AM, Volodesi said: Same here. All my other Movies/TV Show is fine.. but my Album art for most of my music is gone.. which I painstakingly set myself through Emby. The art files are still in the folders with each album.. but 80% of them don't show anymore. Going through and manually doing this is about to drive me crazy., This. Has this been fixed?
Luke 42289 Posted January 22, 2023 Posted January 22, 2023 6 hours ago, Quek9 said: This. Has this been fixed? hi @Quek9 can you please describe your issue in more detail? Thanks.
Quek9 7 Posted January 27, 2023 Posted January 27, 2023 On 1/22/2023 at 1:17 PM, Luke said: hi @Quek9 can you please describe your issue in more detail? Thanks. It is fixed. I selected perfect file structure 1
