MBSki 1115 Posted May 20, 2021 Posted May 20, 2021 How long should it take for the server to scan after the update? I started 12 hours ago and it's still scanning on a 100 GB database. Is that expected?
Happy2Play 9802 Posted May 20, 2021 Posted May 20, 2021 Every system is different, all you can do is check the server log to see what it is doing. 1
mavs 1 Posted May 21, 2021 Posted May 21, 2021 Could be related to the MusicBrainz server issue... my library scans have been taking a very long time since the upgrade and I can see from the server logs it looks like it's waiting for timeouts/exceptions to happen before moving the progress bar along. It gets there eventually. 1
Crush420 6 Posted May 21, 2021 Posted May 21, 2021 Mine is taking an incredibly long time also. It's been stuck at 98% for hours now. I have tried to restart it & same thing, stuck at 98%. I add content to my library all the time , and a scan usually takes just a few seconds. What's up?
Happy2Play 9802 Posted May 21, 2021 Posted May 21, 2021 8 minutes ago, Crush420 said: Mine is taking an incredibly long time also. It's been stuck at 98% for hours now. I have tried to restart it & same thing, stuck at 98%. I add content to my library all the time , and a scan usually takes just a few seconds. What's up? It really depends on your setup and libraries. Can you post your server log.
Crush420 6 Posted May 21, 2021 Posted May 21, 2021 (edited) is this correct...? Edited May 21, 2021 by Crush420
nagetech 70 Posted May 21, 2021 Posted May 21, 2021 Not thread jacking, just tossing in that I too am stuck at 98% and see a ton of musicbrainz issues.
mavs 1 Posted May 21, 2021 Posted May 21, 2021 Yes mine gets very slow from around 96-97%, but like I said above it completes ok in the end. Last one took just over 5 hours, usually takes a couple of minutes. Seeing lots of these in the server log during the slow period: 2021-05-21 13:45:46.755 Error App: Error in MusicBrainz *** Error Report *** Version: 4.6.0.50 Command line: C:\Users\home\AppData\Roaming\Emby-Server\system\EmbyServer.dll -service Operating system: Microsoft Windows 10.0.19042 Framework: .NET Core 3.1.13 OS/Process: x64/x64 Runtime: C:/Users/home/AppData/Roaming/Emby-Server/system/System.Private.CoreLib.dll Processor count: 6 Data path: C:\Users\home\AppData\Roaming\Emby-Server\programdata Application path: C:\Users\home\AppData\Roaming\Emby-Server\system System.Net.Http.HttpRequestException: System.Net.Http.HttpRequestException: The SSL connection could not be established, see inner exception. ---> System.IO.IOException: Authentication failed because the remote party has closed the transport stream. at System.Net.Security.SslStream.StartReadFrame(Byte[] buffer, Int32 readBytes, AsyncProtocolRequest asyncRequest) at System.Net.Security.SslStream.PartialFrameCallback(AsyncProtocolRequest asyncRequest) --- End of stack trace from previous location where exception was thrown --- at System.Net.Security.SslStream.EndProcessAuthentication(IAsyncResult result) at System.Threading.Tasks.TaskFactory`1.FromAsyncCoreLogic(IAsyncResult iar, Func`2 endFunction, Action`1 endAction, Task`1 promise, Boolean requiresSynchronization) --- End of stack trace from previous location where exception was thrown --- at System.Net.Http.ConnectHelper.EstablishSslConnectionAsyncCore(Stream stream, SslClientAuthenticationOptions sslOptions, CancellationToken cancellationToken) --- End of inner exception stack trace --- at Emby.Server.Implementations.HttpClientManager.CoreHttpClientManager.SendAsyncInternal(HttpRequestOptions options, String httpMethod) at Emby.Server.Implementations.HttpClientManager.CoreHttpClientManager.SendAsync(HttpRequestOptions options, String httpMethod) at MusicBrainz.MusicBrainzAlbumProvider.GetMusicBrainzResponse(String url, Boolean isSearch, Boolean forceMusicBrainzProper, CancellationToken cancellationToken) at MusicBrainz.MusicBrainzArtistProvider.GetSearchResults(ArtistInfo searchInfo, CancellationToken cancellationToken) at MusicBrainz.MusicBrainzArtistProvider.GetMetadata(ArtistInfo id, CancellationToken cancellationToken) at MediaBrowser.Providers.Manager.MetadataService`2.ExecuteRemoteProviders(BaseItem originalItem, MetadataResult`1 temp, LibraryOptions libraryOptions, String logName, TIdType id, IEnumerable`1 providers, CancellationToken cancellationToken) Source: System.Net.Http TargetSite: Void MoveNext() InnerException: System.IO.IOException: Authentication failed because the remote party has closed the transport stream. Source: System.Net.Security TargetSite: Void StartReadFrame(Byte[], Int32, System.Net.AsyncProtocolRequest) at System.Net.Security.SslStream.StartReadFrame(Byte[] buffer, Int32 readBytes, AsyncProtocolRequest asyncRequest) at System.Net.Security.SslStream.PartialFrameCallback(AsyncProtocolRequest asyncRequest) --- End of stack trace from previous location where exception was thrown --- at System.Net.Security.SslStream.EndProcessAuthentication(IAsyncResult result) at System.Threading.Tasks.TaskFactory`1.FromAsyncCoreLogic(IAsyncResult iar, Func`2 endFunction, Action`1 endAction, Task`1 promise, Boolean requiresSynchronization) --- End of stack trace from previous location where exception was thrown --- at System.Net.Http.ConnectHelper.EstablishSslConnectionAsyncCore(Stream stream, SslClientAuthenticationOptions sslOptions, CancellationToken cancellationToken)
Happy2Play 9802 Posted May 21, 2021 Posted May 21, 2021 6 minutes ago, Crush420 said: is this correct...? embyserver.txt 5.25 MB · 1 download Yes it is more then likely the Musicbrainz issue. There are other topics on this as they were not really prepare for this update hammering the server. https://emby.media/community/index.php?/topic/98084-musicbrainz-issue
MBSki 1115 Posted May 21, 2021 Author Posted May 21, 2021 Mine finally finished after about 36 hours. Just need to let it do it's thing and not restart the server. 1
