FreeBSD_Lover 14 Posted May 20, 2021 Posted May 20, 2021 So I have been using Emby with HD Home Run flawlessly for a few years now. However I only get three channels. I am interested in those free-to-air satellite systems, that get free channels. I realize many are international channel, but if I can pick up a few more English language channels I think it would be worth it. So, my question is, anyone have a free-to-air satellite system and have it integrated (through IP) with Emby? Is there a way to do it natively/direct, or did you have to use TV HeadEnd application and plugin? I would love to find a system that I know will work with Emby. I use FreeBSD if that matters, which I doubt. Note: I had TV HeadEnd installed years ago on FreeBSD but I found TV Headend to be poor at best; not sure if they have made any good progress in the last few years.
Carlo 4561 Posted May 20, 2021 Posted May 20, 2021 It would help if you gave a general GEO location where you are as that will determine what services are available.
arrbee99 1836 Posted May 20, 2021 Posted May 20, 2021 No I don't know what I'm talking about, but might be worth mentioning that NextPVR seems to have a Linux version and if you're talking about Sat over IP, or whatever its called, I came across this - https://forums.nextpvr.com/showthread.php?tid=59871 if its of any use. I am a fan of NextPVR, so I'm biased.
FreeBSD_Lover 14 Posted May 20, 2021 Author Posted May 20, 2021 Sorry, and thanks. Eastern part of Canada.
Carlo 4561 Posted May 21, 2021 Posted May 21, 2021 I'm near Philadelphia or the eastern part of the US and can tell you we probably share the same view of the sky for the most part. Unlike the UK, our "free to use" satellite choices really don't exist. I'd love for someone to speak up and say I'm wrong but that's been my experience. With that said with some monster size dishes and the right equipment you can get some channels but it's not worth it and not in the league of what the UK guys get. 1
FreeBSD_Lover 14 Posted May 21, 2021 Author Posted May 21, 2021 cayars, you are correct. I am in the same satellite footprint as you, just my signal levels will be a bit fainter. And thank you for your honesty. 1
