Privado18 0 Posted May 24, 2021 Posted May 24, 2021 I found the beta chanel server, i am downloading and testing now, i will update the results soon, will this replace my current server or will be like an extra server?
Privado18 0 Posted May 28, 2021 Posted May 28, 2021 So the sorting works well on beta channel server, but it has an issue with the play next episodes, it will display any random episode on play next rather than the following, might be a issue with series with more than 100 episodes maybe... And that i only named them 1,2,3 etc rather than s01e01 but is hard to name all of them
Carlo 4561 Posted May 28, 2021 Posted May 28, 2021 Hi, it should be really quick to rename files. The key is not to do it manually, but instead use a bulk naming tool like Filebot or Bulk Renamer. Once setup and used, you'll wonder how you ever got on without it. 1
Privado18 0 Posted May 29, 2021 Posted May 29, 2021 11 hours ago, cayars said: Hi, it should be really quick to rename files. The key is not to do it manually, but instead use a bulk naming tool like Filebot or Bulk Renamer. Once setup and used, you'll wonder how you ever got on without it. I tried filebot and didnt work for me, i will search for bulk renamer, thanks
Carlo 4561 Posted May 29, 2021 Posted May 29, 2021 What didn't work about it? If you happen to have gotten java errors that would because it needs to have java installed to work. 1
