Happy2Play 9802 Posted June 16, 2021 Posted June 16, 2021 6 minutes ago, LeidenSpain said: ok, I haven't done that (I have many hand-edited movies). If you have these you should Lock the metadata or the fields you edit if possible. As Emby need to write the new <set> tag to each item that is a Collection item. You could try a Refresh Search for Missing Metadata.
LeidenSpain 33 Posted June 16, 2021 Posted June 16, 2021 2 minutes ago, Happy2Play said: If you have these you should Lock the metadata or the fields you edit if possible. As Emby need to write the new <set> tag to each item that is a Collection item. You could try a Refresh Search for Missing Metadata. Whenever I remember, I block metadata for movies that are misidentified (but sometimes I forget). I have re-updated metadata for the movies and the Transformers collection still does not appear. It is already very late in Spain, tomorrow more. And as always, thank you very much
Happy2Play 9802 Posted June 16, 2021 Posted June 16, 2021 1 minute ago, LeidenSpain said: Whenever I remember, I block metadata for movies that are misidentified (but sometimes I forget). I have re-updated metadata for the movies and the Transformers collection still does not appear. It is already very late in Spain, tomorrow more. And as always, thank you very much Please provide a specific example along a server log showing a Refresh of those items.
LeidenSpain 33 Posted June 17, 2021 Posted June 17, 2021 7 hours ago, Happy2Play said: Please provide a specific example along a server log showing a Refresh of those items. Good Morning. Well, it seems that not only I needed to go to sleep. This morning I found the collections like this: The images do not appear (now I will give it to update), but at least it has already created the missing collections. So, how do you have to create collections? Do you have to manually update the metadata of the movies? Regards,
Carlo 4561 Posted June 17, 2021 Posted June 17, 2021 Hi, With just a few missing covers I would just use the 3 dot menu on each collection to edit images. Then 3 dot on the Primary images with a Search for a New Image. https://support.emby.media/support/solutions/articles/44002196420-image-editing-and-image-types 1
LeidenSpain 33 Posted June 17, 2021 Posted June 17, 2021 2 hours ago, cayars said: Hi, With just a few missing covers I would just use the 3 dot menu on each collection to edit images. Then 3 dot on the Primary images with a Search for a New Image. https://support.emby.media/support/solutions/articles/44002196420-image-editing-and-image-types is what I have done, better only to search a few images than not the whole library 1
Luke 42202 Posted June 21, 2021 Posted June 21, 2021 On 6/17/2021 at 9:56 AM, LeidenSpain said: is what I have done, better only to search a few images than not the whole library Hi, has this resolved your issue? 1
LeidenSpain 33 Posted June 21, 2021 Posted June 21, 2021 46 minutes ago, Luke said: Hi, has this resolved your issue? Yes, the problems were accumulating. I have had to move the content of the library, and I have not noticed, and I synchronized the libraries. So when I have added it again ... it has been hours and hours scanning, without showing films or collections in half. But now it seems that it shows me all the libraries, although before this "incident" there were some collections that did not add some movies. Now (although it is a very bad solution) it has detected me everything
Luke 42202 Posted June 22, 2021 Posted June 22, 2021 On 6/21/2021 at 12:48 PM, LeidenSpain said: Yes, the problems were accumulating. I have had to move the content of the library, and I have not noticed, and I synchronized the libraries. So when I have added it again ... it has been hours and hours scanning, without showing films or collections in half. But now it seems that it shows me all the libraries, although before this "incident" there were some collections that did not add some movies. Now (although it is a very bad solution) it has detected me everything Thanks for the feedback. Apologies for the disruption.
LeidenSpain 33 Posted June 22, 2021 Posted June 22, 2021 21 minutes ago, Luke said: Thanks for the feedback. Apologies for the disruption. not at all, thanks to you for always being there helping 2
