ebr 16309 Posted May 28, 2021 Posted May 28, 2021 5 minutes ago, frylich said: Any updates with that fanart issue?
frylich 9 Posted May 28, 2021 Posted May 28, 2021 1 minute ago, ebr said: Soooo, that means we can keep on going with my collection cover issue?
Happy2Play 9802 Posted May 28, 2021 Posted May 28, 2021 42 minutes ago, frylich said: Any updates with that fanart issue? Sorry we don't control them, but others have reported fanart.tv images working again. And a quick test, I am able to get images from them without errors.
frylich 9 Posted May 28, 2021 Posted May 28, 2021 1 minute ago, Happy2Play said: Sorry we don't control them, but others have reported fanart.tv images working again. And a quick test, I am able to get images from them without errors. Please excuse me, you may not know, but that is not my problem. Since the last update there are collections. These are automatically generated and identified by Emby. Unfortunately, that happens without the pictures in the collection. If I manually identify the collection again, Emby also takes over the images. With several hundred collections, this is unfortunately very tedious. Unfortunately, no tip has helped so far (metadata or library scan). Maybe you have an idea?
Carlo 4561 Posted May 28, 2021 Posted May 28, 2021 Fanart is working for me. OK if your issue is that collections didn't get the correct graphic I think you would have to manually refresh them at this point. Try clicking the circle top left on a collection then selecting 5 or so other collections. The use the 3 dot menu top right to REFRESH metadata to see if this updates the pictures. You may need to exit to the home screen then go back into collections to see if they updated. If that worked you can repeat that a couple of times with 50 or so collections at a time. Let us know if that works.
Luke 42203 Posted May 28, 2021 Posted May 28, 2021 2 hours ago, frylich said: Soooo, that means we can keep on going with my collection cover issue? Hi, if you can attach the emby server log from when they were imported we might be able to see why they didn't get images.
frylich 9 Posted May 28, 2021 Posted May 28, 2021 45 minutes ago, cayars said: Fanart is working for me. OK if your issue is that collections didn't get the correct graphic I think you would have to manually refresh them at this point. Try clicking the circle top left on a collection then selecting 5 or so other collections. The use the 3 dot menu top right to REFRESH metadata to see if this updates the pictures. You may need to exit to the home screen then go back into collections to see if they updated. If that worked you can repeat that a couple of times with 50 or so collections at a time. Let us know if that works. As I said before, refreshing the metadata doesn't help. Just re-identify each collection individually. unfortunately there is no batch job button for this.
frylich 9 Posted May 28, 2021 Posted May 28, 2021 27 minutes ago, Luke said: Hi, if you can attach the emby server log from when they were imported we might be able to see why they didn't get images. I just sent you a PM. Thanks in advance.
frylich 9 Posted May 29, 2021 Posted May 29, 2021 15 hours ago, frylich said: I just sent you a PM. Thanks in advance. Good news! I dont know why, but the collection images are now working correctly :DDDDDDDDDDDDDDDDDDDD The metadata refresh is working now ! 1 1
LeidenSpain 33 Posted June 16, 2021 Posted June 16, 2021 good afternoon, It was a pending issue since 4.6 but until now I had other more urgent problems with emby. The point is that shortly before or shortly after (I can't remember) updating to 4.6 I also lost part of the movies. The point is that now as I am adding them, some create coections and others do not. For example, Transformers (which before if I had it as a collection), now I do not believe it. I have tried to copy the folder from data to metadata, but it has not worked for me either. And yet Harry Potter the same thing happened, or Terminator, if I created the collection
Carlo 4561 Posted June 16, 2021 Posted June 16, 2021 Hi, After you get all your media reloaded perform a meta-data refresh on the Movie library. This will refresh the meta-data and pull in any missing collection info which will rebuild your collections.
LeidenSpain 33 Posted June 16, 2021 Posted June 16, 2021 Hi, En la At the top my current metadata/collection folder with the Transformers folder copied from data. I have scanned multiple times and this collection still does not appear. And like that collection, it happens to me with several.
LeidenSpain 33 Posted June 16, 2021 Posted June 16, 2021 Or for example, the libraries are not updated.
Luke 42203 Posted June 16, 2021 Posted June 16, 2021 Hi, this isn't possible in Emby Server 4.6. Why not just create the collections using the web interface?
Happy2Play 9802 Posted June 16, 2021 Posted June 16, 2021 7 minutes ago, LeidenSpain said: Or for example, the libraries are not updated. Usually a image cache issue as I see this occasionally also. Have you refreshed the Collection?
LeidenSpain 33 Posted June 16, 2021 Posted June 16, 2021 36 minutes ago, Luke said: Hi, this isn't possible in Emby Server 4.6. Why not just create the collections using the web interface? I understood that collections are created automatically, right? I have all the transformers movies, but it doesn't create the collection for me automatically. Before with the plugin if it worked.
LeidenSpain 33 Posted June 16, 2021 Posted June 16, 2021 30 minutes ago, Happy2Play said: Usually a image cache issue as I see this occasionally also. Have you refreshed the Collection? Indeed, if I update the metadata, it works fine. Is that because I have to update the collections one by one so that the icons are updated?
Happy2Play 9802 Posted June 16, 2021 Posted June 16, 2021 Just now, LeidenSpain said: Indeed, if I update the metadata, it works fine. Is that because I have to update the collections one by one so that the icons are updated? It will rebuilt all images but you could delete the server image cache. You can see your cache location on Dashboard Paths and just delete the contents of the images folder. 1
LeidenSpain 33 Posted June 16, 2021 Posted June 16, 2021 14 minutes ago, Happy2Play said: Reconstruirá todas las imágenes, pero puede eliminar la memoria caché de imágenes del servidor. Puede ver la ubicación de su caché en Dashboard Paths y simplemente eliminar el contenido de la carpeta de imágenes. Thank you although the main problem is that the collections are not created automatically.
Happy2Play 9802 Posted June 16, 2021 Posted June 16, 2021 Just now, LeidenSpain said: Thank you although the main problem is that the collections are not created automatically. Since the new method creates off item metadata, all items need Refreshed to create the required new metadata.
LeidenSpain 33 Posted June 16, 2021 Posted June 16, 2021 3 minutes ago, Happy2Play said: Since the new method creates off item metadata, all items need Refreshed to create the required new metadata. I think I've already done it, but I'm still wrong. Exactly what and how do I have to do it?
Carlo 4561 Posted June 16, 2021 Posted June 16, 2021 Right click on the movie library and select Refresh Metadata. You don't need to replace graphics. 1 1
LeidenSpain 33 Posted June 16, 2021 Posted June 16, 2021 4 minutes ago, cayars said: Right click on the movie library and select Refresh Metadata. You don't need to replace graphics. ok, I haven't done that (I have many hand-edited movies). What I've always done is scan libraries. Let's go there.... 1
