xenkw0n 2 Posted May 24, 2021 Posted May 24, 2021 That is odd - It says it's now "Mixed Content" - How can I change this without having to re-load the entire Library? I have done a lot of metadata tweaking to get things to load properly and don't want to go through that again.
Carlo 4561 Posted May 24, 2021 Posted May 24, 2021 Did you do a restore from the backup plugin by any chance?
xenkw0n 2 Posted May 25, 2021 Posted May 25, 2021 On 5/24/2021 at 3:08 PM, cayars said: Did you do a restore from the backup plugin by any chance? One time, over a year ago. Not recently, though.
Luke 42203 Posted May 25, 2021 Posted May 25, 2021 You might be able to shutdown the server end edit the library options xml for that library. That might be a little less destructive of an approach.
xenkw0n 2 Posted May 25, 2021 Posted May 25, 2021 2 minutes ago, Luke said: You might be able to shutdown the server end edit the library options xml for that library. That might be a little less destructive of an approach. So it's stored in some XML files? Noice. Let me give that a try. 1
Luke 42203 Posted May 25, 2021 Posted May 25, 2021 Under the server's program data folder/root/default you'll find options.xml
Carlo 4561 Posted May 25, 2021 Posted May 25, 2021 Let us know how you make out or if you need help with this. 1
xenkw0n 2 Posted May 25, 2021 Posted May 25, 2021 59 minutes ago, Luke said: Under the server's program data folder/root/default you'll find options.xml Thank you. It looks like that did it... Just created a new "tvshows" library content type to find out what value to use between those tags and just pasted that in the file in the same spot where "movies" had it's "movies" specification. The right menu's appear now though I guess Ill have to re-scan the library to see the list of upcoming shows again.
Luke 42203 Posted May 25, 2021 Posted May 25, 2021 Thanks for the feedback. Apologies for the disruption. 1
xenkw0n 2 Posted May 25, 2021 Posted May 25, 2021 4 minutes ago, Luke said: Thanks for the feedback. Apologies for the disruption. Of course... Appreciate the continued effort for improved and additional features Best lifetime membership service I ever paid for. Always be around to help if someone wanted to reach out. 1
