lesgars37 0 Posted May 19, 2021 Posted May 19, 2021 (edited) Hi, So I've been using Emby (server on Windows + app on Xiaomi Smart TV) for a month. It worked very well until this week, where I started to notice the audio was bad on the TV. After investigation I noticed audio codec on TV is Dolby+ when the sound is bad while Dolby is fine. But how do I control transcoding on the TV app ? Here's the log when I start playing the Snyder Cut on TV (as well as the media info). Honestly I'm a bit disapointed this isn't working properly just a week after I paid for the app on my TV. Thank you in advance for any hep provided. embyserver.txt Edited May 19, 2021 by lesgars37
ebr 16337 Posted May 19, 2021 Posted May 19, 2021 Hi. There is no transcoding happening here. The item is direct playing. Can you please describe exactly what you mean by "the audio is bad"? What are the audio settings in the device menus?
lesgars37 0 Posted May 19, 2021 Author Posted May 19, 2021 (edited) There is some kind of stuttering with the sound. With 720p tv shows it's harder to notice, but for the Snyder Cut it is quite terrible. It doesn't happen with Dolby and AAC audio files are just not starting. "What are the audio settings in the device menus?" -> I'm not sure I understand what you mean, sorry Edited May 19, 2021 by lesgars37
ebr 16337 Posted May 19, 2021 Posted May 19, 2021 36 minutes ago, lesgars37 said: "What are the audio settings in the device menus?" -> I'm not sure I understand what you mean, sorry In the Android system settings on the TV itself, there will be an "Audio" setting of some sort. It is probably on some sort of "auto" setting but probably also gives you the ability to go in and make more custom settings. If it has the option, try turning off support for DD+.
lesgars37 0 Posted May 19, 2021 Author Posted May 19, 2021 Well the audio settings of the TV are very limited, I can only choose the audio profile. If I play a tv show from a USB stick on the TV media player, Dolby+ is perfect. What bothers me is that sound issue wasn't there last week and apparently there was no update of the Emby App recently, so I have trouble figuring out what went wrong. Thanks for those quick answers btw.
ebr 16337 Posted May 19, 2021 Posted May 19, 2021 1 minute ago, lesgars37 said: I can only choose the audio profile What are the choices there? Are you just using the TV speakers?
lesgars37 0 Posted May 19, 2021 Author Posted May 19, 2021 I am using TV speakers ; audio profiles are just tweaking the equalizer.
Happy2Play 9812 Posted May 19, 2021 Posted May 19, 2021 7 minutes ago, lesgars37 said: If I play a tv show from a USB stick on the TV media player, Dolby+ is perfect. So is this using the same Player as Emby is? Emby is also direct playing via http not direct playing file, so could this be a file access issue?
lesgars37 0 Posted May 19, 2021 Author Posted May 19, 2021 Quote So is this using the same Player as Emby is? Emby is using ExoPlayer while the default player I use to watch stuff from USB seems to be the Xiaomi one (com.xiaomi.mitv.mediaexplorer). Quote Emby is also direct playing via http not direct playing file, so could this be a file access issue? The server being on my PC is it not normal to play the file via http ?
Happy2Play 9812 Posted May 19, 2021 Posted May 19, 2021 2 minutes ago, lesgars37 said: The server being on my PC is it not normal to play the file via http ? This comes back to file access as not all players/client have direct file access, but could be overall setup but a fellow Android user would have to comment more.
lesgars37 0 Posted May 19, 2021 Author Posted May 19, 2021 I found this thread with a similar problem to mine : So I tried using Emby through Chromecast : the Dolby Audio works, but I lose the dolby vision on the Snyder Cut (which is the reason I started using the Emby TV app in the first place).
ebr 16337 Posted May 19, 2021 Posted May 19, 2021 11 minutes ago, lesgars37 said: I found this thread with a similar problem to mine : So I tried using Emby through Chromecast : the Dolby Audio works, but I lose the dolby vision on the Snyder Cut (which is the reason I started using the Emby TV app in the first place). I don't believe that is the same problem. I think your issue may be related to this one though as it is the same device:
lesgars37 0 Posted May 19, 2021 Author Posted May 19, 2021 (edited) Not exactly the same TV but same OS and Emby App. I wouldn't describe the voices as robotic though, it's stuttering and "bad sound" like when there is too much compression on a file. Anyway it seems Dolby+ is simply not working properly with the app. In the meantime I guess I'll use Emby via Chromecast and I'll stop watching Dolby Vision movies until it's fixed. EDIT : maybe we should rename the topic since I was wrong about transcoding ? Edited May 19, 2021 by lesgars37
ebr 16337 Posted May 19, 2021 Posted May 19, 2021 There are really no audio settings on this TV? If you go into the Android menus, what is under Display and Sound? Also, can you play one of these for a few seconds and then send a log from the app? Thanks.
darkside40 108 Posted May 20, 2021 Posted May 20, 2021 There are only some EQ Presets to choose, like Movie, News, Standard etc. but from what i hear there is no much difference in it. And you can choose what output to use, the internal speakers or maybe a Soundbar etc. Thats it, not more to configure. 1
ebr 16337 Posted May 20, 2021 Posted May 20, 2021 Okay, can you please do the following? 14 hours ago, ebr said: can you play one of these for a few seconds and then send a log from the app? Thanks. Edit: Woops, never mind, you are not the OP.
lesgars37 0 Posted May 20, 2021 Author Posted May 20, 2021 Hi again, I just sent the logs from the app ( 16:37 UTC - User=Gae - started the Snyder Cut on playback for a few seconds).
ebr 16337 Posted May 20, 2021 Posted May 20, 2021 Something really wrong with the audio track or device decoders here. Your log was completely full of audio errors: 05-20 18:37:39.901 24563 24706 V AudioTrack: reqSize 512,writtenSize 0 05-20 18:37:39.908 24563 24706 V AudioTrack: processAudioBuffer(84): obtainBuffer(784) returned 272 = 272 + 0 err 0 05-20 18:37:39.908 24563 24706 V AudioTrack: reqSize 272,writtenSize 0 05-20 18:37:39.912 24563 24706 V AudioTrack: processAudioBuffer(84): obtainBuffer(784) returned 784 = 752 + 32 err 0 05-20 18:37:39.912 24563 24706 V AudioTrack: reqSize 752,writtenSize 0 05-20 18:37:39.923 24563 24706 V AudioTrack: processAudioBuffer(84): obtainBuffer(784) returned 784 = 784 + 0 err 0 05-20 18:37:39.924 24563 24706 V AudioTrack: reqSize 784,writtenSize 0 05-20 18:37:39.934 24563 24706 V AudioTrack: processAudioBuffer(84): obtainBuffer(784) returned 784 = 208 + 576 err 0 05-20 18:37:39.934 24563 24706 V AudioTrack: reqSize 208,writtenSize 0 ... 1000s of them. Not sure if it will make a difference but definitely worth trying the beta version of the app.
lesgars37 0 Posted May 20, 2021 Author Posted May 20, 2021 Well it did make a difference, everything seems to be working fine now Thanks a lot for your help and availability, I'll be sure to recommand the app around me.
Luke 42245 Posted May 20, 2021 Posted May 20, 2021 49 minutes ago, lesgars37 said: Well it did make a difference, everything seems to be working fine now Thanks a lot for your help and availability, I'll be sure to recommand the app around me. Thanks for the feedback.
dmtg 11 Posted June 20, 2022 Posted June 20, 2022 I have the same problem in Last server beta version, and the Android TV beta. The sound in dobly + not work perfect. In my xiaomi mi tv p1 i have problems sound and some vídeo the image is freezing In my mi Stick 4k i dont have..
ebr 16337 Posted June 20, 2022 Posted June 20, 2022 48 minutes ago, dmtg said: I have the same problem in Last server beta version, and the Android TV beta. The sound in dobly + not work perfect. In my xiaomi mi tv p1 i have problems sound and some vídeo the image is freezing In my mi Stick 4k i dont have.. Hi. I'm sure your issue is something else but let's please look at specifics. Please create a new thread with details. How to Report a Problem
