grabirdUK 4 Posted May 19, 2021 Posted May 19, 2021 Hi, I have purchased Synology NAS 212+ and HDHomeRun Quattro, for OTA channels(Freeview in UK). I have set them both up and installed Emby on NAS. I find the set up goes fine and easy. I have subscribed to Premiere level. When I try to load the guide, I enter UK and my postcode. There are no options in the lineups box. I get following message: "There was an error downloading TV lineups. Please ensure your information is correct and try again." Am I doing something wrong? The help system says it should work in UK. Thanks!
gillmacca01 220 Posted May 19, 2021 Posted May 19, 2021 Did you put just the first 3 letters/numbers of you postcode? i.e. BA1
grabirdUK 4 Posted May 19, 2021 Author Posted May 19, 2021 Sorry, shot bolt too soon. I tried with my partial postcode - ie first 2 letters and a number only - not the last part. It works fine then. Hopefully a warning to others setting up. Sorry to post. Thanks! 1
grabirdUK 4 Posted May 19, 2021 Author Posted May 19, 2021 Hi, thanks gillmacca01 - just found that! Thanks for such fast response. 1
gillmacca01 220 Posted May 19, 2021 Posted May 19, 2021 That's odd. When I put in my full postcode, I get the error, but just putting in SN5, I get the lineups
grabirdUK 4 Posted May 19, 2021 Author Posted May 19, 2021 Sorry yes, I didn't explain that very well. When I put in the full postcode, I got the error. When I only put in the first part, it was fine. Sorry for confusion. 1
