RudoMedia 3 Posted May 19, 2021 Posted May 19, 2021 Hallo zusammen, ich habe noch so eine Android TV Box (Android 8.1) hier und wollte darauf EMBY als Client installieren um das vernünftig auf dem TV zu nutzen. Leider funktioniert die Installation über den Playstore nicht. Gibt es da Erfahrungen mit solchen China Boxen ?
Carlo 4561 Posted May 19, 2021 Posted May 19, 2021 Hi, What error do you get when you try to install it? Can you post a picture of the error and if possible translate the error to English?
ebr 16335 Posted May 19, 2021 Posted May 19, 2021 Hi. Can you search for "Emby for Android TV" instead?
RudoMedia 3 Posted May 19, 2021 Author Posted May 19, 2021 No, the same error, i try to change to my smartphone Account - but the same problem. with emby for Android TV to...
RudoMedia 3 Posted May 19, 2021 Author Posted May 19, 2021 I make a reset.. an configurate new... after this i try again
RudoMedia 3 Posted May 19, 2021 Author Posted May 19, 2021 No, the same Result.. "Can't download EMBY for Android TV"
Carlo 4561 Posted May 19, 2021 Posted May 19, 2021 So as far as I know that device does not run Android TV but only standard Android. That error using Google Translate to English reads: Cannot download Emby for Android Try again. If the problem persists, here are some common solutions You could try downloading the APK install file from our website and manually installing https://emby.media/emby-for-android.html
RudoMedia 3 Posted May 19, 2021 Author Posted May 19, 2021 Ok.. i fixed the Problem with intalling the apk file. Now i try how it is working
Carlo 4561 Posted May 19, 2021 Posted May 19, 2021 Did you load the APK manually? Is it working correctly for you now?
RudoMedia 3 Posted May 19, 2021 Author Posted May 19, 2021 some little problems.. but ich check this... have to order the premiere package... then its working i think. EMBY Server runs on a HP Proliant Microserver GEN 8, Movies via SMB from Dreambox 7080... Handy App is working fine, Via Browser on PC the same... everything looks good. 1
