One2Go 121 Posted May 18, 2021 Posted May 18, 2021 The Live TV recording works perfectly, however is there a setting somewhere that limits how many episodes are kept? I couldn't find such a setting, I just click on series like "NBC Today" and it records it, but rather then manually deleting a full week's recordings van it be set to like keep the last 5 episodes or another number? Thanks O2G
Solution Carlo 4561 Posted May 18, 2021 Solution Posted May 18, 2021 Hi, have you setup a SERIES recording and then looked at it's options? Try that and you'll find what your looking for! 1
One2Go 121 Posted May 18, 2021 Author Posted May 18, 2021 Thanks that did it changing from "keep as many as possible" to just 3. Thanks O2G 1
Carlo 4561 Posted May 18, 2021 Posted May 18, 2021 Perfect. Glad you got exactly what you needed working!
