Luke 42243 Posted July 17, 2021 Posted July 17, 2021 6 hours ago, Przemek said: Hi @Luke last time I drive a cor and listen to some album for 2 hours without problem. I was very happy my problem is over. Then I stop and go to gas station, start to listen to my playlist and it stops during first song. regards. Can you grab the android app log from that time? Thanks.
Przemek 70 Posted August 7, 2021 Author Posted August 7, 2021 Hi, @Luke sorry for late response. I was testing streaming for some time with disbled Emby notification badge on Android smartphone top screen. Everything works fine until yesterday. I put Android logs as attachment. Also put all Emby logs from today. Regards. 16116ac6-5e48-4147-a8ca-9cc7f51c1c3d.log f39e74f1-df36-4965-8d1a-a90c26c7450f.log embyserver-63763891201.txt ffmpeg-transcode-b4fc0020-24dd-489a-bdff-33f4c4a877bc_1.txt ffmpeg-transcode-98179f8b-3c5b-4f34-be35-b8fe02f80627_1.txt quick-extract-imageseries-02ab7d32-157a-48e8-876a-567bbd40d423_1 (1).txt quick-extract-imageseries-02ab7d32-157a-48e8-876a-567bbd40d423_1.txt quick-extract-imageseries-f83a0aca-44f3-4b0c-8eb3-51a97f14f764_1.txt embyserver.txt
Przemek 70 Posted August 18, 2021 Author Posted August 18, 2021 14 hours ago, Luke said: Are you still having an issue with this? Yes, still have that. Regards.
Przemek 70 Posted August 21, 2021 Author Posted August 21, 2021 (edited) @Luke Hi, Today I watch episode without problem on smartphone LTE. When I finish I try to watch another. Episode don't start. Then I try to watch yt and there also have problem. Like internet connection was down. That was only few seconds and then everything works except Emby. On Emby still cannot start another episode. Then I convert from 1080p to 480p mobile and also don't work. Next I turn off Bluetooth and episode start fast with 1080p. Regards. Edited August 21, 2021 by Przemek
Luke 42243 Posted August 24, 2021 Posted August 24, 2021 Perhaps the issue was the network connection hadn't come back yet?
Przemek 70 Posted August 24, 2021 Author Posted August 24, 2021 Hi, my sister has the same smartphone and the same LTE provider and she don't have that issue. Meybe when I change phone soon everything will work ok. Regards.
Przemek 70 Posted August 31, 2021 Author Posted August 31, 2021 Hi, I have v3.2.05. I will buy new smartphone in few days and I will see if that problem still occurs. Regards.
Luke 42243 Posted October 4, 2021 Posted October 4, 2021 Hi, are you still having this issue with 3.2.14+?
Przemek 70 Posted October 5, 2021 Author Posted October 5, 2021 Hello @Luke I get new smartphone OnePlus9Pro with Android 11 (OxygenOS) but don't have Emby upgrade yet. I have still version 3.2.12. I don't test that smartphone with Emby for longer journey but so far it works OK. Regards.
Przemek 70 Posted October 25, 2021 Author Posted October 25, 2021 Hi @Luke. I noticed that problem again on my new phone but on weak internet connection. My friend also occur that on smartphone. He has weak internet in home. He use my Emby server. He can smooth stream Emby in browser but have problems in Android app smartphone and he can even connect on app on smart tv (Android tv). On that tv he can smooth stream Netflix and HBO. i think Emby have some problems when internet is not enough fast. regards.
Przemek 70 Posted October 25, 2021 Author Posted October 25, 2021 On smartphone I have 3.2.19. Meybe it's because of my SSL. When my phone app stops I try on Chrome but I have error: NET::ERR_CERT_AUTHORITY_INVALID And says my connection isn't private. But when I try on Firefox there's no problem. I connect with https.
Przemek 70 Posted October 26, 2021 Author Posted October 26, 2021 3 hours ago, Luke said: What ssl certificate are you using? I'm using let's encrypt and no-ip. Regards.
Luke 42243 Posted October 28, 2021 Posted October 28, 2021 I wonder if it's just a brief loss of network causing this. Have you tried with downloaded music?
tda0626 0 Posted October 29, 2021 Posted October 29, 2021 This happens to me as well and only happens if I have been on WiFI: Leave the house in my car with it still connected to WIFI, make the transition to the cell network and when the audio buffer is depleted, it stops and the app becomes unresponsive to any input. Have to restart the app every time this happens. Guess it confuses the server going from local to WAN side access and can't recover.
Luke 42243 Posted November 2, 2021 Posted November 2, 2021 On 10/29/2021 at 10:47 AM, tda0626 said: This happens to me as well and only happens if I have been on WiFI: Leave the house in my car with it still connected to WIFI, make the transition to the cell network and when the audio buffer is depleted, it stops and the app becomes unresponsive to any input. Have to restart the app every time this happens. Guess it confuses the server going from local to WAN side access and can't recover. Hi, that's not quite what we're talking about here, but to respond to you, currently the user interface can handle switching from LAN to WAN seamlessly, but media playback cannot yet at this time. It's something we are working on improving. Thanks.
Przemek 70 Posted November 2, 2021 Author Posted November 2, 2021 Hi, @Luke I test many songs and for now it work fine. Meybe upgade fix my problem. On my new smartphone I noticed that problems when listen to Google Podcasts. It stops many times but unlike emby I see notice that is network error (low signal) and I can resume after a while. Regards.
