RandallC 3 Posted May 21, 2021 Author Posted May 21, 2021 @cayars - Looks like nope. No errors, it creates the folder for the recording with all the metadata but then same error when I try to play back. I looked on my NAS and there is no video file there.
Carlo 4561 Posted May 21, 2021 Posted May 21, 2021 From a web browser can you run this then upload the sample file please. http://192.168.1.28:5004/auto/v12.1?duration=120 That should create a 2 minute file so it's shouldn't take long to upload.
Carlo 4561 Posted May 21, 2021 Posted May 21, 2021 At first glance I don't see anything wrong with the recording and it will transcode fine through Emby. I see just a couple errors but they aren't unusual 17:13:17.131 [mpeg2video @ 000001fac6ff1900] Invalid frame dimensions 0x0. Last message repeated 10 times 17:13:17.163 [mpegts @ 000001fac6fd1b00] PES packet size mismatch Last message repeated 1 times I honestly don't have an idea what the issue might be. I don't know if this will give us more info or not but could you try going to scheduled tasks and doing a log rotation. Then go to log menu and turn on debug option. Try a playback from web for that channel. Turn off debug log Upload the server and any transcode logs for that time frame.
RandallC 3 Posted May 21, 2021 Author Posted May 21, 2021 Here they are! Thanks for sticking with me, @cayars. embyserver.txt ffmpeg-transcode-e736aac4-fbb0-48aa-aef0-38cf5573df65_1.txt ffmpeg-transcode-d8f5a86e-c3d0-435e-bb82-f620c8f27b24_1.txt ffmpeg-transcode-11130864-14b2-459c-8171-255addab8b0b_1.txt
Carlo 4561 Posted May 21, 2021 Posted May 21, 2021 Haven't looked yet but was this one playback that created 3 different ffmpeg logs?
RandallC 3 Posted May 21, 2021 Author Posted May 21, 2021 Actually I think it created two of them. The third had a timestamp slightly earlier so I wasn't 100% sure. So - probably ignore the one ending in b0b_1.txt.
Carlo 4561 Posted May 21, 2021 Posted May 21, 2021 All the ffmpeg logs show basically the same thing and for some reason Emby can't identify the codecs used in this stream 15:06:12.170 [mpegts @ 000002ca13e80680] PES packet size mismatch 15:06:12.171 [mpegts @ 000002ca13e80680] probed stream 0 failed 15:06:12.172 [mpegts @ 000002ca13e80680] Could not find codec parameters for stream 0 (Unknown: none): unknown codec Consider increasing the value for the 'analyzeduration' and 'probesize' options 15:06:12.172 Input #0, mpegts, from 'http://127.0.0.1:8096/LiveTv/LiveStreamFiles/868e4e84c95f41299cdeac524d74e2a2/stream.ts': 15:06:12.173 Duration: N/A, start: 67241.871956, bitrate: N/A 15:06:12.173 Program 1 15:06:12.173 No Program 15:06:12.173 Stream #0:0[0x35]: Unknown: none, Start-Time 67241.872s 15:06:12.175 Stream specifier 'v:0' in filtergraph description [v:0]format@f1=pix_fmts=yuv420p[f1_out0] matches no streams. Grasping at straws here but is the firmware on this tuner from 2021? @softworkz I think we've exhausted things we can look at, time to call in the big dog.
RandallC 3 Posted May 21, 2021 Author Posted May 21, 2021 This is probably nothing, but should the address referenced be localhost and not the address of the tuner? 15:06:12.172 Input #0, mpegts, from 'http://127.0.0.1:8096/LiveTv/LiveStreamFiles/868e4e84c95f41299cdeac524d74e2a2/stream.ts': And yep, the tuner is running 20210422.
