pdm 1 Posted May 15, 2021 Posted May 15, 2021 Hi Luke, I am having issues with the TV guide not displaying. This issue has been ongoing for about a month, I have been monitoring the forum to find out if others were having the same issue. It is now becoming a bit of a pain. I am running ET ver. 4.5.4.0, Prior to the guide not displaying, there were no changes or other issues with my system (turned computer off at end of one day, turned computer & ET on the following day - TV guide not displaying). I have attached emby server & ET logs. PDM embyserver.txt theater-63756744757.txt
Luke 42237 Posted May 15, 2021 Posted May 15, 2021 Hi, try refreshing the guide data in emby server, and then if there's still a problem after that, please attach the emby server log. thanks.
pdm 1 Posted May 15, 2021 Author Posted May 15, 2021 HI Luke, Thanks for your help. I have updated Xml file & refreshed TV guide data through emby server with no joy. I have attached the latest log. PDM embyserver (1).txt
Luke 42237 Posted May 15, 2021 Posted May 15, 2021 Do you see guide data in the web app? Have you checked the contents of your xml guide data to ensure that it even has program data for the dates and channels you're expecting? Have you checked the mapping tool in Emby Server to see how the tuner channels are mapped to guide channels?
pdm 1 Posted May 15, 2021 Author Posted May 15, 2021 Hi Luke, The TV guide does display in web view (sorry, I didn't check that part), I have checked the channel mapping - all good & there is program data for all channels I am viewing. The TV guide will display when you select a channel to watch (see attached screen dumps) however, will not dsiplay an the overview page. PDM
Luke 42237 Posted May 15, 2021 Posted May 15, 2021 Can you try updating to the latest version? Thanks.
pdm 1 Posted May 15, 2021 Author Posted May 15, 2021 Hey Luke, Silly question, I am looking in the download tab for an updated version, however, I can not seem to find emby theatre to download. Please point me in the right direction :). PDM
pdm 1 Posted May 15, 2021 Author Posted May 15, 2021 Hey Luke, Thanks heaps for you help - downloaded & installed updated version - all working good. Next time I have issues, I will remember to check for version updates. Thanks again PDM
OldBoldMan 0 Posted June 6, 2023 Posted June 6, 2023 I have the same problem. I have attached my log files. I have restarted the server. I have also installed the latest version hardware_detection-63821604184.txt embyserver.txt
ebr 16332 Posted June 6, 2023 Posted June 6, 2023 7 hours ago, OldBoldMan said: I have the same problem On 5/15/2021 at 6:43 PM, Luke said: What version of Emby Theater?
Luke 42237 Posted June 6, 2023 Posted June 6, 2023 Also are you able to see guide data in the Emby web app?
OldBoldMan 0 Posted June 7, 2023 Posted June 7, 2023 Nope, I was not able to see it in the web app unfortunately.
Luke 42237 Posted June 9, 2023 Posted June 9, 2023 On 6/7/2023 at 10:39 AM, OldBoldMan said: Nope, I was not able to see it in the web app unfortunately. Where are you looking for it? Please attach the Emby server log from when the problem occurred: How to Report a Problem Thanks.
