ginjaninja 605 Posted May 15, 2021 Posted May 15, 2021 (edited) Purpose/Reason what the script does onplaystart, all other paused sessions on the server for the said mediaitem on all other devices for the user are stopped. (prevents paused sessions muddying the playbackposition later on) installation: install powershell 7+ (Windows, Linux etc) configure onplaystart event on ScripterX to call script with parameters create apikey and add to config file. ClearPaused v0.0.0.2.zip Edited June 1, 2022 by ginjaninja 1
Banquero 38 Posted May 28, 2022 Posted May 28, 2022 Hola, me gustaria utilizar este plugin en mi synology. Como puedo hacerlo? @ginjaninja
ginjaninja 605 Posted May 28, 2022 Author Posted May 28, 2022 5 hours ago, Banquero said: Hola, me gustaria utilizar este plugin en mi synology. Como puedo hacerlo? @ginjaninja i am not familiar with Synology, and i dont speak Spanish so this may get complicated 1st challenge is can you install Powershell and Scripter X Emby plugin on Synology? https://github.com/PowerShell/powershell/releases
fillidill 175 Posted May 30, 2022 Posted May 30, 2022 This is really cool and have given me a reason to check ScripterX out. Thanks for sharing!
ginjaninja 605 Posted June 1, 2022 Author Posted June 1, 2022 With the renewed interest. I have moved the code over to use the "/emby/Sessions/" + $_.id + "/Playing/Stop" endpoint which seems to be more compatible with web clients. updated to v0.0.0.2
