ebr 16335 Posted May 17, 2021 Posted May 17, 2021 If you use the "Playback Correction" option on the cog menu does it ever start playing properly? You can repeatedly select that until it gives up.
painomatic 1 Posted May 17, 2021 Author Posted May 17, 2021 "Playback Correction" doesn't solve the problem. @floppy0081have the same problem with a firetv device of the first generation after Emby App update.
BillAdama 1 Posted May 19, 2021 Posted May 19, 2021 Just update the Client to 2.0.0.9a and the same Problem here with Fire-TV 1.Gen.
vdatanet 1619 Posted May 19, 2021 Posted May 19, 2021 Can you try to sideload the latest beta version? Maybe it will solve your problem. Â
BillAdama 1 Posted May 19, 2021 Posted May 19, 2021 i try it with adblink: [100%] /data/local/tmp/app-amazon-release.apk D:/Download/app-amazon-release(1)/app-amazon-release.apk: 1 file pushed. 3.2 MB/s (78336485 bytes in 23.213s) Â Â Â pkg: /data/local/tmp/app-amazon-release.apk Failure [INSTALL_FAILED_UPDATE_INCOMPATIBLE]
BillAdama 1 Posted May 19, 2021 Posted May 19, 2021 I have to deinstall the old version, then the installation of 2.0.18 was successful. Unfortunately the problem is still there.
Luke 42242 Posted May 19, 2021 Posted May 19, 2021 Can you provide a sample video for testing? Thanks.
painomatic 1 Posted May 20, 2021 Author Posted May 20, 2021 (edited) Hey, here is a link to a File and also in the attachment: https://we.tl/PRZPvvJI71 The File is from the following Website: https://thedigitaltheater.com/dolby-trailers/ With the File i can reproduce the error.  Best Felix  Dolby_Countdown_v1_Lossless-thedigitaltheater.mkv Edited May 20, 2021 by painomatic
ebr 16335 Posted May 20, 2021 Posted May 20, 2021 Hi. The current beta of the app should correct this for you.  1
painomatic 1 Posted May 20, 2021 Author Posted May 20, 2021 @ebrPerfect the Beta App fixed my Problem!Â
Luke 42242 Posted May 20, 2021 Posted May 20, 2021 38 minutes ago, painomatic said: @ebrPerfect the Beta App fixed my Problem! Thanks for the feedback.
