dcook 303 Posted May 13, 2021 Posted May 13, 2021 (edited) I have noticed lately that any of my media that has an Audio type of: EAC3 will not play any sound. I use the FireTV app 99% of the time and I have made sure its updated to latest version, and there is no audio. I also tried the same media types with EAC3 via web browser, again there is no audio. This is not specific to 1 media file, but happens with any media file that has Audio type EAC3 FireTV App shows it as cpw EAC3 Other Audio types play normally in FireTV, Roku or Web Browser Is this a known issue? and is there a resolution to correct this? Emby Server: 4.5.4.0 Example of a media that has no audio: Edited May 13, 2021 by dcook
dcook 303 Posted May 13, 2021 Author Posted May 13, 2021 (edited) Here you go, it says in the log: TranscodeReasons=AudioCodecNotSupported However these used to work before, so something has changed in the Emby Server that is breaking the audio ffmpeg-remux-0d45bb32-b519-464a-9d7a-89411f3c882c_1.txt Edited May 13, 2021 by dcook
Happy2Play 9812 Posted May 13, 2021 Posted May 13, 2021 (edited) Has Chrome ever supported it? I just went to HTML5test - How well does your browser support HTML5? and Edge shows yes and Chrome shows no. Edited May 13, 2021 by Happy2Play
dcook 303 Posted May 13, 2021 Author Posted May 13, 2021 I know it used to work in FireTV app as that is what I use 99% of the time to watch my content I can't say if specific browsers do or don't
Happy2Play 9812 Posted May 13, 2021 Posted May 13, 2021 Also 4.5.4.0 has been out for what 6 months so nothing has changed on the server. I know I have no issues on my Roku as I just tested. Now specific clients could be another story, but logs for specific clients are needed as the Chrome log is only relevant to that playback (TranscodeReasons=AudioCodecNotSupported).
dcook 303 Posted May 13, 2021 Author Posted May 13, 2021 Also, I just tried using Microsoft Edge, no audio either: Example of no audio using Edge:
dcook 303 Posted May 13, 2021 Author Posted May 13, 2021 (edited) I don't think it was a recent change, but something has changed in the past few months, because I have older episodes that I know I watched using FireTV, and now when I play them there is no audio. I assumed it was Emby Server issue as I am also getting no audio when trying to play via browser. But perhaps its specific to the FireTV app, and not Emby Server I just hooked up my Roku and the same media plays with audio fine. Here you can see photo of my tv using Roku: Audio is identified as Cpe EAC3 and does play correctly So the question is: Why does EAC3 audio no longer work on FireTV app? (I know it used to before) And why does it not work when using Web Client? Edited May 13, 2021 by dcook
dcook 303 Posted May 13, 2021 Author Posted May 13, 2021 Here is the log while playing successfully with Roku ffmpeg-remux-407afa3f-f4b5-40a8-8569-fe9d26a5bd89_1.txt
Happy2Play 9812 Posted May 13, 2021 Posted May 13, 2021 Just moved a eac3 test item to my test server and Edge directplayed with audio and Chrome got Audio codec not supported,Direct play error. Devs will have comment more as I am not seeing any issues.
dcook 303 Posted May 13, 2021 Author Posted May 13, 2021 I was just searching on here and found these posts, perhaps its the same issue:
Happy2Play 9812 Posted May 13, 2021 Posted May 13, 2021 (edited) On the Roku I would be looking and the Roku Audio settings as the device currently returns it does not support eac3. (AudioCodec=ac3,aac,mp2,mp3,flac,vorbis,lpcm) It would not be the same issue across multiple different platforms clients in my opinion. As I have no issues in Edge or Roku. Edited May 13, 2021 by Happy2Play
dcook 303 Posted May 14, 2021 Author Posted May 14, 2021 My Roku plays the EAC3 audio fine, the issue for me is that my Firestick does not play it at all, and neither does web browser client
ebr 16337 Posted May 14, 2021 Posted May 14, 2021 14 hours ago, dcook said: and neither does web browser client In one of your browsers, the audio was transcoding to mp3 but the other one is direct playing. What is the audio equipment involved here in both cases? Are other sounds working on that machine? What if you play the item with something like VLC?
speechles 2062 Posted May 14, 2021 Posted May 14, 2021 (edited) 14 hours ago, dcook said: My Roku plays the EAC3 audio fine, the issue for me is that my Firestick does not play it at all, and neither does web browser client The Roku properly detected no support for E-AC3 and only support for Dolby in AC3. It transcoded the audio to AC3. {"Codec":"eac3","Language":"cpe","TimeBase":"1/1000","CodecTimeBase":"1/48000","DisplayTitle":"Cpe EAC3 2 ch (Default)","IsInterlaced":false,"Channels":2,"SampleRate":48000,"IsDefault":true,"IsForced":false,"Type":"Audio","Index":1,"IsExternal":false,"IsTextSubtitleStream":false,"SupportsExternalStream":false,"Protocol":"File"} The "cpe" at the front is part of the Display Title. Edited May 14, 2021 by speechles
rbjtech 5344 Posted May 14, 2021 Posted May 14, 2021 (edited) With the latest FireTV release and latest beta server - I do not have any issues playing EAC3 on a Gen2 FireTV stick. SFN says - Audio Codec : DOLBY+ (direct) As expected, no ffmpeg log is generated as it is DirectPlay. According to the Amazon Dev website - eac3 is supported - so what emby is using/reporting appears to be correct. eAC3 (Dolby Digital Plus). Up to 48kHz, 6 channels, 16-bit and 24-bit On three browsers - Edge & Chrome - Audio is converted to MP3, plays fine. Firefox - Audio is converted to AAC, plays fine. Edited May 14, 2021 by rbjtech
dcook 303 Posted May 14, 2021 Author Posted May 14, 2021 1 hour ago, ebr said: In one of your browsers, the audio was transcoding to mp3 but the other one is direct playing. What is the audio equipment involved here in both cases? Are other sounds working on that machine? What if you play the item with something like VLC? @ebrNo special audio equipment, just my TV speakers When I use Roku to play via Emby audio works When I open the same file with VLC audio works Now that I have updated my Chrome browser when I use the Emby Web Client to play the same file audio works When I try to play the same file via Firestick, video plays, but there is no audio. Seems my issue is specific to the Android/Firestick client, can you assign this to that forum sub group? And is this a known issue with eAC3 and Android/Firestick client? According to my searches on this forum, there are other users have reported audio issues with eAC3 as well?
ebr 16337 Posted May 14, 2021 Posted May 14, 2021 Exactly which stick is it? What are the audio settings on the device itself? Does the TV support DD+?
dcook 303 Posted May 14, 2021 Author Posted May 14, 2021 1 hour ago, rbjtech said: With the latest FireTV release and latest beta server - I do not have any issues playing EAC3 on a Gen2 FireTV stick. SFN says - Audio Codec : DOLBY+ (direct) As expected, no ffmpeg log is generated as it is DirectPlay. According to the Amazon Dev website - eac3 is supported - so what emby is using/reporting appears to be correct. eAC3 (Dolby Digital Plus). Up to 48kHz, 6 channels, 16-bit and 24-bit On three browsers - Edge & Chrome - Audio is converted to MP3, plays fine. Firefox - Audio is converted to AAC, plays fine. @rbjtechHere are my versions Emby Server: 4.5.4.0 Emby FireTv App: 2.0.09a You are using the same versions and eAC3 audio works for you?
dcook 303 Posted May 14, 2021 Author Posted May 14, 2021 5 minutes ago, ebr said: Exactly which stick is it? What are the audio settings on the device itself? Does the TV support DD+? FireStick Lite: https://www.amazon.ca/Fire-TV-Stick-Lite-No-TV-Controls-2020-release/dp/B07ZZW18N6 Firestick says its updated to latest version: 7.2.3.4 (PS7234/2039) Audio settings are default, there does not seem to be much options: If all other media plays fine, doesn't that mean its some kind of issue with eAC3 files and the Emby FireTv client? Especially if the same files play on Roku and Web Client?
dcook 303 Posted May 14, 2021 Author Posted May 14, 2021 (edited) @ebr if I change the audio setting from: Best Available to Passthrough Dolby Digital then the audio works fine playing media with eAC3 on my Firestick, Emby Dashboard shows me playing via Direct Playing So it would seem that the issue with the Emby client on FireTV is specific to having the default audio option of "Best Available" selected when playing via Direct Playing method. Hope this helps you find the issue! Edited May 14, 2021 by dcook
ebr 16337 Posted May 14, 2021 Posted May 14, 2021 Sometimes the automatic detection on these devices gets tripped up so, if you've found a setting that works then you should be good. Thanks.
horstepipe 423 Posted September 25, 2021 Posted September 25, 2021 (edited) The problem is back with beta .44 on devices which do not support eac3 on Android TV. Guess you need an inapp log? Edited September 25, 2021 by horstepipe
