mike3821 67 Posted May 13, 2021 Posted May 13, 2021 When scrolling through the channel guide and selecting a channel, you get a pop-up with information and a play button to select. Is it possible to turn the pop-up off so it tunes directly to the channel?
Carlo 4561 Posted May 13, 2021 Posted May 13, 2021 Hi, Assuming you're talking about the web app, have you looked at the menu option "Keyboard and Remote". You will find shortcuts listed there you can use from the keyboard to do different things like quickly starting playback.
mike3821 67 Posted May 13, 2021 Author Posted May 13, 2021 7 minutes ago, cayars said: Hi, Assuming you're talking about the web app, have you looked at the menu option "Keyboard and Remote". You will find shortcuts listed there you can use from the keyboard to do different things like quickly starting playback. Referring to the android app.
