Joevaen3 0 Posted May 12, 2021 Posted May 12, 2021 Linux Server and Android App. When I use emby connected on mobile net, the emby connect is not stable, sometimes it is well but more often it doesn't work. I wanna know whether it is normal. Thanks.
Joevaen3 0 Posted May 19, 2021 Author Posted May 19, 2021 (edited) On 5/12/2021 at 10:09 PM, Luke said: Hi there, what does "doesn't work" mean? Sorry, I have solved that. Restart server will work. But I have a new question. I find if I use vlc player on my local WAN net where my emby server in, the player will search my library and play the movie without any permission striction. It means authority of a user is meanless. Do you have some solution to prevent vlc or other video player from view my emby library? In another word, what should I do so that the server can only log in through an account? Edited May 19, 2021 by Joevaen3
Q-Droid 1011 Posted May 19, 2021 Posted May 19, 2021 (edited) Disable DLNA on the Emby server. Edited May 19, 2021 by Q-Droid
Luke 42246 Posted May 19, 2021 Posted May 19, 2021 2 hours ago, Q-Droid said: Disable DLNA on the Emby server. Yes this is correct.
Joevaen3 0 Posted May 26, 2021 Author Posted May 26, 2021 Sorry, I can't find DLNA option in my emby dashboard.
Luke 42246 Posted May 26, 2021 Posted May 26, 2021 That's not related to emby connect though. Are you still having an issue with this?
