banana120 1 Posted August 17, 2021 Author Posted August 17, 2021 i can't use emby any more if it continue this issue ....... i wonder how can i refund my emby premiere........ the emby premiere email is same as the email attched to this forums account.
Luke 42237 Posted August 17, 2021 Posted August 17, 2021 Try removing the port mapper and dlna plugins, then restart the server and see if that helps. Thanks.
banana120 1 Posted August 22, 2021 Author Posted August 22, 2021 happen again without upload this time ..... but almost runing out cpu and ram this cause my nas run very slowly.... i have to shutdown emby... embyserver-63765227633.txt
Luke 42237 Posted August 22, 2021 Posted August 22, 2021 You could try removing the Dlna plugin, then restart the server and see if that helps. Thanks.
banana120 1 Posted September 1, 2021 Author Posted September 1, 2021 On 8/22/2021 at 1:27 PM, Luke said: You could try removing the Dlna plugin, then restart the server and see if that helps. Thanks. not happen untill now seem to be a dlna problom......
Luke 42237 Posted September 1, 2021 Posted September 1, 2021 Are all ports of this machine completely exposed on the internet? You might be getting dlna network requests from random internet addresses if that is true.
banana120 1 Posted September 2, 2021 Author Posted September 2, 2021 11 hours ago, Luke said: Are all ports of this machine completely exposed on the internet? You might be getting dlna network requests from random internet addresses if that is true. it make some sense but before post this On 8/22/2021 at 11:30 AM, banana120 said: happen again without upload this time ..... but almost runing out cpu and ram this cause my nas run very slowly.... i have to shutdown emby... i just change my router setting ,i cancel DMZ ip point to nas , just relay some file trans port such as ftp 21 how to explain the emby run out of cpu but without upload?? what did dlna plugin doing that time???
Luke 42237 Posted September 2, 2021 Posted September 2, 2021 4 minutes ago, banana120 said: it make some sense but before post this i just change my router setting ,i cancel DMZ ip point to nas , just relay some file trans port such as ftp 21 how to explain the emby run out of cpu but without upload?? what did dlna plugin doing that time??? server log?
banana120 1 Posted September 2, 2021 Author Posted September 2, 2021 43 minutes ago, Luke said: server log? log is attached preview On 8/22/2021 at 11:30 AM, banana120 said: embyserver-63765227633.txt 30.3 kB · 3 downloads
Luke 42237 Posted September 2, 2021 Posted September 2, 2021 10 hours ago, banana120 said: log is attached preview Please attach the complete emby server log as this is only a small snippet. Thanks.
banana120 1 Posted September 4, 2021 Author Posted September 4, 2021 log is lost 。。。i updated emby ....i downgrade version by mistake and update again...
Luke 42237 Posted September 4, 2021 Posted September 4, 2021 OK yes that could cause problems and is therefore not supported.
banana120 1 Posted December 8, 2021 Author Posted December 8, 2021 it's ok since i close dlna may be dlna have some bug ,whatever i don't use dlna,,,i install emby app on my tv please end this topic
