benquan 0 Posted May 12, 2021 Posted May 12, 2021 I have problems resuming playback of Emby from external devices like Google Home when casting to a chromecast device. I use the android App and select to cast to my chromecast device: I then select a movie a play it. From the Android app, I am able to play/pause resume with no problems as long as I do it from the application. But if I try to control Emby from outside the application, this is where the problem occurs. If I go to google Home for example: If I see the play button, I can start playback, the movie starts playing and the icon will change to pause (all OK)... But if I then press the pause button, the movie WILL pause but google home will still think the movie is playing as the icon displayed will still be a pause button and not the expected play button. If I then open the android app, it will have the correct status in other words I will see the play button and as expected it does work if I press it, continuing playback. This same issue will happen if I try to control playback from a google voice device. If I pause it, no problem. It stops, but when I say resume, it wont continue playback as it thinks that its already playing the content. What I would think is that Emby server is failing to transmit the pause status to google home. I started using Emby about 3 years ago, but this error started happening about 2 years ago after an update. Ben
Luke 42237 Posted June 17, 2021 Posted June 17, 2021 hi @benquan thanks for reporting, we'll take a look.
SamES 1084 Posted August 22, 2021 Posted August 22, 2021 @benquan, can you please check this for me. I can see the issue you describe (start playback, then pause/play using Google Home app and the play/pause icon state doesn't update). I've noticed that if I wait about 10 seconds after pressing play or pause with the Google Home app then the icon state eventually changes. Do you see this as well? I think it is being updated correctly, but there is a delay in sending the update message. I'll take a look and try and work out why there is a delay.
Luke 42237 Posted September 7, 2021 Posted September 7, 2021 @benquan can you please try this again? This should be resolved now. Thanks !
benquan 0 Posted September 14, 2021 Author Posted September 14, 2021 Hello! Sorry for the late response but yes! it is fixed! Thanks
codyhood10000 3 Posted February 18, 2025 Posted February 18, 2025 Hello I know this is a old thread but I can't seem to play/pause my living room chromecast with emby anymore like I always have been able to do. I can still do this with YouTube or Plex or Amazon and Disney ect .. just stopped working with emby. I tried everything from resetting network and emby and google home resetting Chromecast ect. It lets me pause from emby but not the Google home app. The Google home and emby app shows as casting but I can't play or pause with my voice in emby, but again this feature still works with every other app. Been a couple months and still not having luck. Any help is appreciated. Thanks
Luke 42237 Posted March 1, 2025 Posted March 1, 2025 On 2/17/2025 at 11:07 PM, codyhood10000 said: Hello I know this is a old thread but I can't seem to play/pause my living room chromecast with emby anymore like I always have been able to do. I can still do this with YouTube or Plex or Amazon and Disney ect .. just stopped working with emby. I tried everything from resetting network and emby and google home resetting Chromecast ect. It lets me pause from emby but not the Google home app. The Google home and emby app shows as casting but I can't play or pause with my voice in emby, but again this feature still works with every other app. Been a couple months and still not having luck. Any help is appreciated. Thanks Hi, yes we are looking into this. Thanks.
Luke 42237 Posted May 10, 2025 Posted May 10, 2025 Hi, please try this again and let us know if your issue is resolved. Thanks.
