acnp77 67 Posted May 9, 2021 Posted May 9, 2021 Hi, I prefer not to use images for the libraries on the homescreen (webapp - "Homescreen" - "My Media"). So I deleted the default images ("Edit images" > "Delete"). But they reappear after a library scan. The same happens with the images for playlists. Is there a way to permanently delete them? What I want: After library scan the default image reappears: Emby Server Version 4.5.4.0 (emby-server-deb_4.5.4.0_amd64.deb)
Solution ebr 16309 Posted May 9, 2021 Solution Posted May 9, 2021 Hi. Yes. Give them a custom image via that same dialog instead of just deleting the automatic one. 1
acnp77 67 Posted May 9, 2021 Author Posted May 9, 2021 3 minutes ago, ebr said: Hi. Yes. Give them a custom image via that same dialog instead of just deleting the automatic one. @ebr Thank you for your reply. Do you know where to find the files for the "placeholders" images like: so I can add them as custom image, and also change the sometimes strange colors to make them all blue? Cheers
ebr 16309 Posted May 9, 2021 Posted May 9, 2021 Those are actually generated on the fly I think from the material icon set. You could make your own from there. You may also want to check out: https://emby.media/community/index.php?/forum/70-fan-art-videos/ 1
