moiahbabi 6 Posted May 8, 2021 Posted May 8, 2021 Hello, New to Emby, but just wanted to know if it is currently possible to change subtitle font to a custom one? if not, can I use "subfont.woff2" for srt subtitles too? the reason is that when ever I use the SSA subtitle format, I would get a consistent font style across all devices, that is from the "subfont.woff2", which looks like this: but when I switch to the SRT file, the font style is dependent on the system default. for example in windows I got the following style: I believe this because Roboto font does not support arabic, so it uses system default as a fallback.
Solution Carlo 4561 Posted May 8, 2021 Solution Posted May 8, 2021 Hi, this is not possible at this point in time. You could check to see if there is a feature request for this and if not create one. https://emby.media/community/index.php?/forum/98-feature-requests/ 1
Abobader 3485 Posted May 8, 2021 Posted May 8, 2021 Hi, As cayars said, but why not simply use SSA it supported unless I misunderstand the issue here. My best
moiahbabi 6 Posted May 8, 2021 Author Posted May 8, 2021 Hello, 2 hours ago, Abobader said: Hi, As cayars said, but why not simply use SSA it supported unless I misunderstand the issue here. My best it is just that I have an external tool to download missing subtitles in multiple languages, which mostly downloads in SRT format. I can manually change it to SSA files, but this means changing all files instead making the change once on the server. for now, I will check https://emby.media/community/index.php?/forum/98-feature-requests/ to see if similar request exists. thanks. 1
