leifrodhared 3 Posted May 9, 2021 Author Posted May 9, 2021 Just now, ebr said: Hi. I don't think anything is "erroring". It looks like your music doesn't have proper tags and, when you refresh, you are telling Emby to read those tags (which don't exist so nothing is read). It has tags, I've shown you this, and like I said when I provide extra info manually Emby does not use it either, does not complete the record , fill the remaining info. Why is it that the "identify" option is just on movies? I mean this is what the refresh metadata function should do right? When you run it and select find missing metadata it should do this right? Use the existing one and fetch what is missing. It does not do that. Even DeadBeef can correctly find the song on LastFM so stop gaslighting me that the song is not tagged properly like a copy paste army.
Luke 42203 Posted May 9, 2021 Posted May 9, 2021 Identify is not just on movies. It can also be used on albums and artists.
leifrodhared 3 Posted May 9, 2021 Author Posted May 9, 2021 4 minutes ago, Luke said: Identify is not just on movies. It can also be used on albums and artists. Still not addressing my issue as it cannot be used on single songs. So I tried every combination of doing this manually and refreshing, no luck. Now please address the elephant in the room.
Guest Posted May 9, 2021 Posted May 9, 2021 1 hour ago, leifrodhared said: Uh so the logic is wrong, it should be - I provide data , go fetch according to what I've provided not go fetch "whatever". Otherwise there is no way out of this as I change things and then the system changes it back. The user action and preference should always trump whatever the system "wants" if it comes to logical metadata structures. And if what you say is true why do you have 2 options for updating metadata? One to remove one to find missing? Atm they both do the same thing, wipe my manual edits and then they still don't find the correct data. They just leave the file as it was originally which I have shown on screenshots. Embedding your metadata with TagScanner or Picard first is really the best way to start.. problems with filling this information in from the internet, in addition to what is embedded... such as album and artists descriptions and images... seems to be a subjective thing.. for me I have terrible luck with regard to getting artists images, backdrops, and information responses back from Musicbrainz, AudioDB, and FanArt... so this can be a separate issue even when you have the correct information... Re-scan, Refresh and Replace... then it may work if you go in and do them one by one.. which is weird.. I agree that something seems odd or off with this area... I know people have even asked for bulk editing.. but for the most part.. as to the use scenario for 'Edit Metadata'... It would seem like printed metadata - add-in - manually... where needed. and not something that gives EMBY the metadata to identify.. ( which is also a separate option.. ) This data is changed unless you lock the tags.. and/or can lock the tags.. I as a person using it, would assume differently, in a way.. and expect it to operate the same way as working with a tag editor.. yet this is for the server only and the media presentation - nothing else... You also have to watch for scheduled tasks to refresh and rescan your libraries as well to keep things as they are.. but this seems to follow suit regardless of media type.. Most useful when an item has no way of containing metadata... Like a STRM file for example.. Trouble downloading images comes down to the ability of the server to be able to use providers, send requests and receive that data back... and there are types that will not outside of something like STRM which is a playlist type..technically; in text format.. containing no information or code for identification.. WAV files.. older versions are that way.. for example and AVI files.. requiring all of the EDIT IMAGES and EDIT METADATA options.. Tags should look like this for informations to be used to aggregate roper data .. this gives the online databases enough NORMAL information to return a result.. as an example.. this is embedded not put into the server.. TAGSCANNER As an example..
leifrodhared 3 Posted May 9, 2021 Author Posted May 9, 2021 5 minutes ago, Hxemby001 said: Embedding your metadata with TagScanner or Picard first is really the best way to start.. problems with filling this information in from the internet, in addition to what is embedded... such as album and artists descriptions and images... seems to be a subjective thing.. for me I have terrible luck with regard to getting artists images, backdrops, and information responses back from Musicbrainz, AudioDB, and FanArt... so this can be a separate issue even when you have the correct information... Re-scan, Refresh and Replace... then it may work if you go in and do them one by one.. which is weird.. I agree that something seems odd or off with this area... I know people have even asked for bulk editing.. but for the most part.. as to the use scenario for 'Edit Metadata'... It would seem like printed metadata - add-in - manually... where needed. and not something that gives EMBY the metadata to identify.. ( which is also a separate option.. ) This data is changed unless you lock the tags.. and/or can lock the tags.. I as a person using it, would assume differently, in a way.. and expect it to operate the same way as working with a tag editor.. yet this is for the server only and the media presentation - nothing else... You also have to watch for scheduled tasks to refresh and rescan your libraries as well to keep things as they are.. but this seems to follow suit regardless of media type.. Most useful when an item has no way of containing metadata... Like a STRM file for example.. Trouble downloading images comes down to the ability of the server to be able to use providers, send requests and receive that data back... and there are types that will not outside of something like STRM which is a playlist type..technically; in text format.. containing no information or code for identification.. WAV files.. older versions are that way.. for example and AVI files.. requiring all of the EDIT IMAGES and EDIT METADATA options.. Tags should look like this for informations to be used to aggregate roper data .. this gives the online databases enough NORMAL information to return a result.. as an example.. this is embedded not put into the server.. TAGSCANNER As an example.. Well given no luck with Emby I will have to try Kid3.
leifrodhared 3 Posted May 9, 2021 Author Posted May 9, 2021 I've tagged the file with ID1 and v3 tags, still nothing. Images don't fetch, info does not update, computer says no, what can I say .... Automation does not work somewhere there but since there are no logs that say anything useful I can't see where. For now I have to tag and put images on manually on everything. The devs here seem to be aware of some kind of problem but they don't want to admit it, otherwise they would ask for some useful troubleshooting info or more logs to diagnose the issue. Check the plugins are actually doing the fetching and lookups so they could prove me wrong. But they don't which stinks to me really.
Guest Posted May 9, 2021 Posted May 9, 2021 You did a scan of the file in question.. refresh, and last resort tried removing the file to a different location outside the Library path.. after it is removed from EMBY.. then putting it back and seeing how it shows up?
vdatanet 1619 Posted May 9, 2021 Posted May 9, 2021 3 minutes ago, leifrodhared said: I've tagged the file with ID1 and v3 tags, still nothing. Images don't fetch, info does not update, computer says no, what can I say .... Automation does not work somewhere there but since there are no logs that say anything useful I can't see where. For now I have to tag and put images on manually on everything. The devs here seem to be aware of some kind of problem but they don't want to admit it, otherwise they would ask for some useful troubleshooting info or more logs to diagnose the issue. Check the plugins are actually doing the fetching and lookups so they could prove me wrong. But they don't which stinks to me really. In music library settings, what type of structure folder is selected? I have "Other or non structured", tags are read and links to metadata providers are created:
leifrodhared 3 Posted May 9, 2021 Author Posted May 9, 2021 1 minute ago, Hxemby001 said: You did a scan of the file in question.. refresh, and last resort tried removing the file to a different location outside the Library path.. after it is removed from EMBY.. then putting it back and seeing how it shows up? Yep, I always do all the possible permutations of actions on a given problem. Sysadmin's creed
leifrodhared 3 Posted May 9, 2021 Author Posted May 9, 2021 2 minutes ago, vdatanet said: In music library settings, what type of structure folder is selected? I have "Other or non structured", tags are read and links to metadata providers are created: It is "Other or non structured", the best bit is if I manually paste in MusicBrainz ID's , nothing is fetched. I can lock the file and refresh and it will be stripped by the system of the added manually info. No matter how I refresh. When I re-add the whole library it's the same.
Guest Posted May 9, 2021 Posted May 9, 2021 Just to verify.. Clicked on Library...'EDIT' and have these selected?.. Made sure in Fetcher Settings, that you have the wanted images selected? May have to zoom browser with images to see it.. EDIT LIBRARY
leifrodhared 3 Posted May 9, 2021 Author Posted May 9, 2021 1 minute ago, Hxemby001 said: Just to verify.. Clicked on Library...'EDIT' and have these selected?.. Made sure in Fetcher Settings, that you have the wanted images selected? May have to zoom browser with images to see it.. EDIT LIBRARY Yes the root folder has all the fetcher options ticked
vdatanet 1619 Posted May 9, 2021 Posted May 9, 2021 1 minute ago, leifrodhared said: Yes the root folder has all the fetcher options ticked Maybe a server log is useful.
leifrodhared 3 Posted May 9, 2021 Author Posted May 9, 2021 (edited) Removed Edited May 10, 2021 by leifrodhared Solved
Carlo 4561 Posted May 9, 2021 Posted May 9, 2021 I'd uninstall Cover Art program to get rid of the noise it creates in the logs. Move an album in question completely out of your library. Do a full library scan. While that scan is taking place, use Picard or your favorite mp3 tagging software to tag the album. Upload a screen shot of the album with tags. Once it looks correct we will have you move it back to the library and scan again.
leifrodhared 3 Posted May 9, 2021 Author Posted May 9, 2021 2 minutes ago, cayars said: I'd uninstall Cover Art program to get rid of the noise it creates in the logs. Move an album in question completely out of your library. Do a full library scan. While that scan is taking place, use Picard or your favorite mp3 tagging software to tag the album. Upload a screen shot of the album with tags. Once it looks correct we will have you move it back to the library and scan again. I did all that already.
Carlo 4561 Posted May 9, 2021 Posted May 9, 2021 I don't recall seeing updated tags. Can you show us what the tagging looks like on the problem album?
leifrodhared 3 Posted May 9, 2021 Author Posted May 9, 2021 Picard has solved the tags and the issue. Now they update and pull images. Looks like tag version and encoding is the problem. Emby can't read tags on linux other than in UTF-8 ? Look like it. 1
Guest Posted May 9, 2021 Posted May 9, 2021 Yeah.. most of the reading I have done is support for UTF-8 related.. Most tagging programs do UTF-8 instead of UTF-16 or other.. some have options to change this..
leifrodhared 3 Posted May 10, 2021 Author Posted May 10, 2021 12 hours ago, Hxemby001 said: Yeah.. most of the reading I have done is support for UTF-8 related.. Most tagging programs do UTF-8 instead of UTF-16 or other.. some have options to change this.. I tried tagging with a different app and Emby would not read the tags. It was actually seeing the artist info but not doing anything with it further until I have retagged everything with Picard. Odd but at least it works now.
Carlo 4561 Posted May 10, 2021 Posted May 10, 2021 If in doubt you can run ffprobe against any track you've modified which will show you what tags and info Emby will receive.
Guest Posted May 10, 2021 Posted May 10, 2021 Do you know what differences there are with the versions of FFPROBE and FFMPEG that are distributed with EMBY? versus the ones you install on the system from their site? I know there are differences in their size..
Carlo 4561 Posted May 10, 2021 Posted May 10, 2021 Quite a lot of changes. If you do what I mentioned earlier use the ffprobe included with Emby just to make sure. If you happen to run Emby on a NAS but use a PC for daily activities you can download the Emby Server portable version for PC and then use the ffprobe in that version on the PC.
Guest Posted May 10, 2021 Posted May 10, 2021 The reason I asked is because.. I experimented with another issue and downloaded the 107 MB size files, renamed the originals and have been running for about a week with the ones from the site... without an issue... The problem I did this for didn't change... I had planned to install these in my ENVIRONMENT VARIABLES or PATHS on my system and install them... Just not for sure how this would effect things.
Carlo 4561 Posted May 10, 2021 Posted May 10, 2021 (edited) Don't do that. The version shipped with each server release is well tested for compatibility and substituting a generic version won't have the Emby added features needed by the server. Edited May 10, 2021 by cayars
