abstract 5 Posted August 20, 2014 Posted August 20, 2014 Anyone experienced the following critical error before? Everything is working perfectly - MB server, MB clients and MB classic all functioning perfectly. Following earlier discussion with EBR re: parental controls and some suggested changes to users I've launched up the configurator to make changes and presented with the following: I can close the error, but selecting any options in the configurator results in further error messages or the program crashing/closing completely. Anyone else experienced this? This is the first time I've used the configurator for some (considerable) time, so couldn't pin-point any specific changes that have occurred, but I have recently installed (WMC) Guide Tool in order to fix some of the missing guide data (UK DVB-T freeview - Emley Moor region). Will try a reboot and, failing that, a reinstall of MBC, but would prefer not to as everything else is working perfectly (really perfectly - I don't want to risk that lovely state!!)
blade005 185 Posted August 20, 2014 Posted August 20, 2014 abstract, I have not encountered the specific error you listed above, but on the rare occasion that I bring up Media Browser Classic Configurator I have had a few instances where my Virus Protection software (Avast) has had issues with the configurator window opening up. Closing and then opening up the configurator a few times has worked, or turning off my Virus Protection software to pop into the configurator, make changes, and then turn Virus Protection back on. Thought I would mention that for you to consider, before you start chasing all sorts of gremlins.
abstract 5 Posted August 20, 2014 Author Posted August 20, 2014 Thanks blade, disabled Norton, but no joy. Ditto with the reboot - will try a reinstall of MBC...
abstract 5 Posted August 20, 2014 Author Posted August 20, 2014 Very strange - cannot pin-point the cause, but a reinstall has solved the configurator issue. EBR - only chocolate theme, no other plugins installed.
