pXius 3 Posted May 7, 2021 Posted May 7, 2021 Hi, Just reporting a possible bug. Server version 4.5.4.0 I've got a family member using a certified android box (for the last 2 years). Connected to a to a TV via HDMI. Internal TV speakers are used for sound. Android box is set to PCM And LN for Dolby. Playing almost anything that uses a surround sound coded ie. Dolby+ causes playback to have no sound. (Direct Playing) The new update has less Audio settings from what I can tell. Ended up reverting to 1.8.55g and the issue is gone. Upgraded back to 2.0.0.9g just to confirm I can reproduce the issue. I will of course follow up with logs. (On mobile atm)
ebr 16338 Posted May 7, 2021 Posted May 7, 2021 16 minutes ago, pXius said: Android box is set to PCM And LN for Dolby. Hi. Exactly what does that mean?
pXius 3 Posted May 7, 2021 Author Posted May 7, 2021 1 hour ago, ebr said: Hi. Exactly what does that mean? Sorry, Sound Output has a selection of HDMI - RAW SPDIF - RAW PCM <-- Selected. Dolby Sound has the options of RF LN <-- Selected OFF These are the options within the android sounds settings. There is also an option for Surround. Which can be set to Auto or Off. I have tried both. ---- All that said, it works with the previous post settings settings on 1.8.55 and previous versions.
ebr 16338 Posted May 7, 2021 Posted May 7, 2021 37 minutes ago, pXius said: Sound Output has a selection of HDMI - RAW SPDIF - RAW PCM <-- Selected. Dolby Sound has the options of RF LN <-- Selected OFF Those are non-standard option so I'm not sure exactly how they behave. Also no idea what RF or LN are in relation to Dolby but it seems to contradict the setting of PCM in your normal output setting. I would try HDMI-RAW and see what happens...
pXius 3 Posted May 7, 2021 Author Posted May 7, 2021 2 hours ago, ebr said: Those are non-standard option so I'm not sure exactly how they behave. Also no idea what RF or LN are in relation to Dolby but it seems to contradict the setting of PCM in your normal output setting. I would try HDMI-RAW and see what happens... Fair enough. I have tried pretty much every possible combination of those settings without success. - Fact stays that 1.8.55 work 100% for those settings, and always have. Hopefully the logs will reveal more.
Luke 42246 Posted May 8, 2021 Posted May 8, 2021 Ok, once you're able to send a log example we'll be able to look at specific scenario. Thanks.
DDobreff 0 Posted May 8, 2021 Posted May 8, 2021 I have similar problems. The sound became just stereo. It does not play Dolbi Atmos and almost all other formats that were played correctly before the update. Now everything is downmixed to stereo !!!
Luke 42246 Posted May 8, 2021 Posted May 8, 2021 2 minutes ago, DDobreff said: I have similar problems. The sound became just stereo. It does not play Dolbi Atmos and almost all other formats that were played correctly before the update. Now everything is downmixed to stereo !!! Hi there @DDobreff, can we please look at an example? Please attach the information requested in how to report a media playback issue. thanks !
horstepipe 423 Posted May 8, 2021 Posted May 8, 2021 Same here, but this is a custom Android TV build for X96 Max. It worked with previous stable, now it looks like everything is being transcoded (on device) to DD+ which the device doesn’t seem to be capable off. I‘ll provide logs tomorrow.
ebr 16338 Posted May 8, 2021 Posted May 8, 2021 3 hours ago, horstepipe said: now it looks like everything is being transcoded (on device) to DD+ That's not happening so let's please look at details of an example. Thanks. 1
intranetsnob 0 Posted May 10, 2021 Posted May 10, 2021 Hi all, The latest update for Android TV version of EMBY has issues with sound playback, as per the first comment on this. There is literally no longer sound for playing the same audio that was playing. This issue is bypassed by using VLC player so definitely can confirm the issue is with the latest EMBY update. Please review and update to fix the sound issue. Thank you.
horstepipe 423 Posted May 10, 2021 Posted May 10, 2021 On 5/8/2021 at 10:30 PM, ebr said: That's not happening so let's please look at details of an example. Thanks. I saw that issue of a friend of mine. Now I plugged in a x96 max here to send you the log files. But unfortunately here the settings appear lol. did you update the emby package without increasing it’s version (v2.0.09?) I attached it to an AVR, my friend to a tv. I’ll plug it to my tv to compare...
CBers 7554 Posted May 10, 2021 Posted May 10, 2021 28 minutes ago, horstepipe said: I saw that issue of a friend of mine. Now I plugged in a x96 max here to send you the log files. But unfortunately here the settings appear lol. did you update the emby package without increasing it’s version (v2.0.09?) I attached it to an AVR, my friend to a tv. I’ll plug it to my tv to compare... Make sure you have the DEBUG option enabled in the app.
horstepipe 423 Posted May 10, 2021 Posted May 10, 2021 (edited) Ok when the box is connected to TV directly I eee the issue. There’s NO setting in playback settings regarding down mixing to stereo or dts support. It was there when the box was connected to AVR. There’s no sound for Dolby movies here, stats for nerds show DOLBY (direct) For DTS there’s sound here but if I remember correctly there wasn’t sound either at my friends. Guess it is about DTS capabilities of the TVs... I just sent a report, user name is bRnc2E Edited May 10, 2021 by horstepipe
horstepipe 423 Posted May 10, 2021 Posted May 10, 2021 4 minutes ago, CBers said: Make sure you have the DEBUG option enabled in the app. I think you misunderstood...?
vdatanet 1619 Posted May 10, 2021 Posted May 10, 2021 1 hour ago, horstepipe said: I saw that issue of a friend of mine. Now I plugged in a x96 max here to send you the log files. But unfortunately here the settings appear lol. did you update the emby package without increasing it’s version (v2.0.09?) I attached it to an AVR, my friend to a tv. I’ll plug it to my tv to compare... This depends on the device chain (rather, the audio capabilities of the devices in the chain.) The same Shield connected to different TVs and AVRs, shows different audio options for me. 1
CBers 7554 Posted May 10, 2021 Posted May 10, 2021 1 hour ago, horstepipe said: But unfortunately here the settings appear lol. 57 minutes ago, horstepipe said: I think you misunderstood...? Perhaps I did, but your original post was a bit confusing Never mind, you have supplied logs now. 2
