AaronClarke 3 Posted May 6, 2021 Posted May 6, 2021 Today I installed the new version of emby on my android tv box. When going in to the various libraries, the images are not displaying correctly. I've tried changing the image size in the menu but it doesn't help. The images are either vertically stretched and overlapping or not filling the area they reside in and leaves large spaces between each item..
Carlo 4561 Posted May 6, 2021 Posted May 6, 2021 Hi, what Android TV box is this and what version of Android is running on it?
AaronClarke 3 Posted May 6, 2021 Author Posted May 6, 2021 (edited) Android 10.0 TV Box T95 4GB RAM 64 ROM Allwinner H616 Quad-Core 64-bit ARM Cortex-A53 Android Box with 2.4G WiFi 10/100M Ethernet, Support H.265/3D/6K Ultra HD/BT 5.0/HDMI 2.0 Smart TV Box https://www.amazon.co.uk/dp/B08DRZM374/ref=cm_sw_r_cp_apa_glt_fabc_HF4FZG889HKF3YNA1NJ1?_encoding=UTF8&psc=1 Edited May 6, 2021 by AaronClarke
Carlo 4561 Posted May 6, 2021 Posted May 6, 2021 I had a feeling. This isn't an Android TV OS but just Android 10. It likely has mods to make it function more like ATV and these graphic libraries are likely the issue. @Luke Does that sound about right to you?
Happy2Play 9813 Posted May 6, 2021 Posted May 6, 2021 (edited) Have you check to see if the issue has anything to do with CoverArt plugin? Temporarily uninstall or disable treatment per media type. Edited May 6, 2021 by Happy2Play 1
AaronClarke 3 Posted May 6, 2021 Author Posted May 6, 2021 52 minutes ago, cayars said: I had a feeling. This isn't an Android TV OS but just Android 10. It likely has mods to make it function more like ATV and these graphic libraries are likely the issue. @Luke Does that sound about right to you? Can I get the .apk file for version 1 and 2 to test. I have no issues on my Android 9 box with version 1 so if load version 2 on android 9 and version 1 on android 10 I can do a comparison. My playstore on android 9 isn't working properly at the moment so I can't download from app store.
ebr 16338 Posted May 6, 2021 Posted May 6, 2021 Yeah, that box is running a phone OS. I think the next beta may solve this issue though. 1
