mirdragon 15 Posted May 6, 2021 Posted May 6, 2021 I have emby installed on a intel i5-4460 with 16gb ram and GTX 750 TI graphics card, the machine is running linux server 20.04 with the nvidia 460 drivers. I have a HDHomerun Quatro and this is configured through emby. I watch through two nvidia shield pro devices, one is 2015 model and other is 2019 model. If I select Direct Play I have issues playing the Live TV stream to my LG TV's, but if I turn of direct play it works. Android TV is running 2.0.09G If I test on our Apple TV 4K it reports it is playing direct play to the same tv If then try channels dvr on the shields, this works fine when selecting direct play So is there a bug in the latest version of the app for android tv where it will not work with Direct Play?
ebr 16337 Posted May 6, 2021 Posted May 6, 2021 2 hours ago, mirdragon said: So is there a bug in the latest version of the app for android tv where it will not work with Direct Play? Hi. No there is not to our knowledge. 2 hours ago, mirdragon said: I have issues playing the Live TV stream to my LG TV's Can we please look at an example of this? What "issues"?
Carlo 4561 Posted May 6, 2021 Posted May 6, 2021 3 hours ago, mirdragon said: I have emby installed on a intel i5-4460 with 16gb ram and GTX 750 TI graphics card, the machine is running linux server 20.04 with the nvidia 460 drivers. I have a HDHomerun Quatro and this is configured through emby. I watch through two nvidia shield pro devices, one is 2015 model and other is 2019 model. If I select Direct Play I have issues playing the Live TV stream to my LG TV's, but if I turn of direct play it works. Android TV is running 2.0.09G If I test on our Apple TV 4K it reports it is playing direct play to the same tv If then try channels dvr on the shields, this works fine when selecting direct play So is there a bug in the latest version of the app for android tv where it will not work with Direct Play? If you go to settings->Live TV do you have it set to direct play on Android ATV?
mirdragon 15 Posted May 6, 2021 Author Posted May 6, 2021 (edited) Yes, I had it set to Direct Play and as said if disable it, the channels play fine. I took a couple of photos of one channel, where in emby it shows it's transcoding while plex/channels it's playing direct no transcoding for the same channel I'll try to get a couple more and post them up tomorrow Edited May 6, 2021 by mirdragon 1
mirdragon 15 Posted May 7, 2021 Author Posted May 7, 2021 @ebr and @cayars The files were too large to upload here, so shared them here https://1drv.ms/u/s!Am4G_VcG7lhmhsUgKOZgVk5tkoX6Pg?e=busJ5T There is a channels dvr, plex and emby file All on the same shield and same channel
mirdragon 15 Posted May 7, 2021 Author Posted May 7, 2021 @cayars @ebr Is this log-file of any use for the transcoding this morning ffmpeg-transcode-fca971fb-0432-40b3-a340-7acdaa36f508_1.txt
ebr 16337 Posted May 7, 2021 Posted May 7, 2021 Audio is stream copying. It is de-interlacing on the server. Assuming that you don't have the options turned on to force this, the next server release should allow it to remux or direct play instead. 1
mirdragon 15 Posted May 7, 2021 Author Posted May 7, 2021 3 hours ago, ebr said: Audio is stream copying. It is de-interlacing on the server. Assuming that you don't have the options turned on to force this, the next server release should allow it to remux or direct play instead. i've tried with the setting both on and off and doesn't play until you enable the live feature so can pause the tv
ebr 16337 Posted May 7, 2021 Posted May 7, 2021 What exactly do you mean by "it doesn't play"? What happens?
mirdragon 15 Posted May 7, 2021 Author Posted May 7, 2021 (edited) 40 minutes ago, ebr said: What exactly do you mean by "it doesn't play"? What happens? ignore that been a long day - i had been testing with the stream copy enabled/disabled and when set playback to direct play i just got the spinning circle - but direct play for audio does work as when enable live view option and check the stats it says direct play for audio but just done some more testing and added two photos to the link i posted further up On both of these Emby is doing direct play, but i noticed if i change channels to another hd channel i get the buffering issue and sometimes can go back to the original channel without issue, but other times i get the buffering. i rotated the emby log prior to testing this and have attached it after completing the latest test, hopefully it will provide a bit more info I also exited emby and reloaded it and problem persisted, i also ensured closed all background apps and retested. embyserver.txt Edited May 7, 2021 by mirdragon
ebr 16337 Posted May 7, 2021 Posted May 7, 2021 7 minutes ago, mirdragon said: but i noticed if i change channels to another hd channel i get the buffering issue and sometimes can go back to the original channel without issue, but other times i get the buffering. Hi. What is "the buffering issue"?
mirdragon 15 Posted May 7, 2021 Author Posted May 7, 2021 35 minutes ago, ebr said: Hi. What is "the buffering issue"? the bit where you see the spinning circle on the screen but nothing plays until you switch to live view
ebr 16337 Posted May 7, 2021 Posted May 7, 2021 39 minutes ago, mirdragon said: switch to live view And "live view" is...?
mirdragon 15 Posted May 7, 2021 Author Posted May 7, 2021 1 hour ago, ebr said: And "live view" is...? sorry, the live seek feature
mirdragon 15 Posted May 8, 2021 Author Posted May 8, 2021 47 minutes ago, Luke said: Is it consistent? yes it is consistent, only with emby I can exit emby go to plex and channels play fine, exit plex and go to channels dvr and that plays fine, come back to emby and have same problem with channels not working I've set emby to record two hd channels later on tonight to see if it actually records them or has problems and they fail
mirdragon 15 Posted May 9, 2021 Author Posted May 9, 2021 ok done some testing last night, emby recorded from the channels without issue, but could not perform direct play back through either of my Shield TVs for the items that were recorded. I copied the files to another location and got Plex to play them without any issues using direct play
mirdragon 15 Posted May 10, 2021 Author Posted May 10, 2021 On 07/05/2021 at 14:01, cayars said: @ebr could this be an AAC_LATM issue? Thought I'll give another update as checked the server when had to change to live seek and it looks to be the audio that is being transcoded Transcoding (25 fps) 21.0 Mbps H264 AAC_LATM 1
mirdragon 15 Posted May 14, 2021 Author Posted May 14, 2021 works fine on a lower specced apple tv, just don't really want to use that as remote is fiddly and awkward to navigate the app
Luke 42245 Posted May 20, 2021 Posted May 20, 2021 Hi there, have you tried with the latest update to the android tv app?
mirdragon 15 Posted May 22, 2021 Author Posted May 22, 2021 My Android TV version is still on 2.0.0.9g and says there are no updates available On checking the Play Store on PC it still shows 2.0.0.9g is the only version available for me to install
ebr 16337 Posted May 22, 2021 Posted May 22, 2021 Do recordings of these channels have the same problem? If so, can you record a short one and give it to us for testing?
mirdragon 15 Posted May 22, 2021 Author Posted May 22, 2021 (edited) Yes, they do, i've also updated to the latest linux version today and same issue through Android TV client but it's weird as some days they will play the channel without issues, so i have a feeling it's down to how they are broadcast but only affects emby as the same recordings through a different app or via windows media player are fine i'll try try and do a short recording later Edited May 22, 2021 by mirdragon
