DarkStar1977 120 Posted May 19, 2021 Author Posted May 19, 2021 19 minutes ago, vdatanet said: @DarkStar1977 What server version are you running? Beta 4.6 with tone mapping options enabled? Latest available for WD PR4100 OS 3 is 4.5.4.0, the one I'm running
DarkStar1977 120 Posted May 19, 2021 Author Posted May 19, 2021 (edited) 25 minutes ago, vdatanet said: Is HDR? Native player transcodes that, MPV direct plays. That's the difference. Not sure how to see this, this is the Mediainfo for this file: General Unique ID : 73152914844072270969199538203876666964 (0x3708BD29F9A72C0D5B75FF207F742E54) Complete name : /1x02 - Exposicion.mkv Format : Matroska Format version : Version 4 File size : 700 MiB Duration : 1 h 1 min Overall bit rate : 1 581 kb/s Encoded date : UTC 2021-04-23 23:38:14 Writing application : mkvmerge v27.0.0 ('Metropolis') 64-bit Writing library : libebml v1.3.6 + libmatroska v1.4.9 Video ID : 1 Format : HEVC Format/Info : High Efficiency Video Coding Format profile : Main@L4@High Codec ID : V_MPEGH/ISO/HEVC Duration : 1 h 1 min Bit rate : 1 025 kb/s Width : 1 920 pixels Height : 1 080 pixels Display aspect ratio : 16:9 Frame rate mode : Constant Frame rate : 23.976 (24000/1001) FPS Color space : YUV Chroma subsampling : 4:2:0 Bit depth : 8 bits Bits/(Pixel*Frame) : 0.021 Stream size : 453 MiB (65%) Writing library : x265 3.2.1+1-b5c86a64bbbe:[Mac OS X][clang 11.0.3][64 bit] 8bit+10bit+12bit Encoding settings : cpuid=1111039 / frame-threads=3 / wpp / no-pmode / no-pme / no-psnr / no-ssim / log-level=2 / input-csp=1 / input-res=1920x1080 / interlace=0 / total-frames=0 / level-idc=40 / high-tier=1 / uhd-bd=0 / ref=3 / no-allow-non-conformance / no-repeat-headers / annexb / no-aud / no-hrd / info / hash=0 / no-temporal-layers / open-gop / min-keyint=24 / keyint=240 / gop-lookahead=0 / bframes=4 / b-adapt=2 / b-pyramid / bframe-bias=0 / rc-lookahead=20 / lookahead-slices=6 / scenecut=40 / radl=0 / no-splice / no-intra-refresh / ctu=64 / min-cu-size=8 / no-rect / no-amp / max-tu-size=32 / tu-inter-depth=1 / tu-intra-depth=1 / limit-tu=0 / rdoq-level=0 / dynamic-rd=0.00 / no-ssim-rd / signhide / no-tskip / nr-intra=0 / nr-inter=0 / no-constrained-intra / strong-intra-smoothing / max-merge=3 / limit-refs=1 / no-limit-modes / me=1 / subme=2 / merange=57 / temporal-mvp / no-hme / weightp / no-weightb / no-analyze-src-pics / deblock=0:0 / sao / no-sao-non-deblock / rd=3 / selective-sao=4 / early-skip / rskip / no-fast-intra / no-tskip-fast / no-cu-lossless / b-intra / no-splitrd-skip / rdpenalty=0 / psy-rd=2.00 / psy-rdoq=0.00 / no-rd-refine / no-lossless / cbqpoffs=0 / crqpoffs=0 / rc=crf / crf=24.0 / qcomp=0.60 / qpstep=4 / stats-write=0 / stats-read=0 / vbv-maxrate=30000 / vbv-bufsize=30000 / vbv-init=0.9 / crf-max=0.0 / crf-min=0.0 / ipratio=1.40 / pbratio=1.30 / aq-mode=2 / aq-strength=1.00 / cutree / zone-count=0 / no-strict-cbr / qg-size=32 / no-rc-grain / qpmax=69 / qpmin=0 / no-const-vbv / sar=1 / overscan=0 / videoformat=5 / range=0 / colorprim=1 / transfer=1 / colormatrix=1 / chromaloc=0 / display-window=0 / cll=0,0 / min-luma=0 / max-luma=255 / log2-max-poc-lsb=8 / vui-timing-info / vui-hrd-info / slices=1 / no-opt-qp-pps / no-opt-ref-list-length-pps / no-multi-pass-opt-rps / scenecut-bias=0.05 / no-opt-cu-delta-qp / no-aq-motion / no-hdr / no-hdr-opt / no-dhdr10-opt / no-idr-recovery-sei / analysis-reuse-level=5 / scale-factor=0 / refine-intra=0 / refine-inter=0 / refine-mv=1 / refine-ctu-distortion=0 / no-limit-sao / ctu-info=0 / no-lowpass-dct / refine-analysis-type=0 / copy-pic=1 / max-ausize-factor=1.0 / no-dynamic-refine / no-single-sei / no-hevc-aq / no-svt / no-field / qp-adaptation-range=1.00 Default : Yes Forced : No Color range : Limited Color primaries : BT.709 Transfer characteristics : BT.709 Matrix coefficients : BT.709 Audio #1 ID : 2 Format : AC-3 Format/Info : Audio Coding 3 Commercial name : Dolby Digital Codec ID : A_AC3 Duration : 1 h 1 min Bit rate mode : Constant Bit rate : 384 kb/s Channel(s) : 6 channels Channel layout : L R C LFE Ls Rs Sampling rate : 48.0 kHz Frame rate : 31.250 FPS (1536 SPF) Compression mode : Lossy Stream size : 170 MiB (24%) Title : Español DD 5.1 @ 384 kbps Language : Spanish Service kind : Complete Main Default : Yes Forced : No Audio #2 ID : 3 Format : AAC LC SBR Format/Info : Advanced Audio Codec Low Complexity with Spectral Band Replication Commercial name : HE-AAC Format settings : Explicit Codec ID : A_AAC-2 Duration : 1 h 1 min Bit rate : 170 kb/s Channel(s) : 6 channels Channel layout : C L R Ls Rs LFE Sampling rate : 48.0 kHz Frame rate : 23.438 FPS (2048 SPF) Compression mode : Lossy Stream size : 75.3 MiB (11%) Title : English Language : English Default : No Forced : No Text #1 ID : 4 Format : UTF-8 Codec ID : S_TEXT/UTF8 Codec ID/Info : UTF-8 Plain Text Duration : 48 min 0 s Bit rate : 1 b/s Count of elements : 17 Stream size : 628 Bytes (0%) Title : Español - Forzado Language : Spanish Default : Yes Forced : Yes Text #2 ID : 5 Format : UTF-8 Codec ID : S_TEXT/UTF8 Codec ID/Info : UTF-8 Plain Text Duration : 58 min 57 s Bit rate : 68 b/s Count of elements : 724 Stream size : 29.6 KiB (0%) Title : Español Language : Spanish Default : No Forced : No Text #3 ID : 6 Format : UTF-8 Codec ID : S_TEXT/UTF8 Codec ID/Info : UTF-8 Plain Text Duration : 58 min 57 s Bit rate : 68 b/s Count of elements : 973 Stream size : 29.5 KiB (0%) Title : English Language : English Default : No Forced : No Edited May 19, 2021 by DarkStar1977
vdatanet 1619 Posted May 19, 2021 Posted May 19, 2021 Some media play better using the native player, some using the MPV player and some (too much) with neither. We will have to wait for improvements in the MPV player, I think that is the way to go.
DarkStar1977 120 Posted May 19, 2021 Author Posted May 19, 2021 Ok but meanwhile, can they correct the problem with subtitles on non MPV Player ?
unisoft 355 Posted May 21, 2021 Posted May 21, 2021 (edited) Forced subtitles don't work for me using the Native Player anyway; never have. MPV Player currently is too terrible with interlaced playback to use, and whilst the Native Player cant show interlaced content if its HD resolution (it can only do progressive), it seems to handle SD interlaced a little bit better than MPV and MPV wont play a large number of H264 music videos encoded in high profile Handbrake app, that everything else (TVs/Rokus/Web) plays fine. I have an iTunes MP4 repackaged as MKV using BOX app (all my moves are MKV) and they have an 5.1 Dolby Digital track, Stereo Track and basic subtitles as would be in an iTunes MP4 file with the "Forced" flag set if a force subtitle set (and EN). AGain these work fine on ROKU/TV Emby apps. Edited May 21, 2021 by unisoft
Luke 42241 Posted June 28, 2021 Posted June 28, 2021 On 5/21/2021 at 5:15 AM, unisoft said: Forced subtitles don't work for me using the Native Player anyway; never have. MPV Player currently is too terrible with interlaced playback to use, and whilst the Native Player cant show interlaced content if its HD resolution (it can only do progressive), it seems to handle SD interlaced a little bit better than MPV and MPV wont play a large number of H264 music videos encoded in high profile Handbrake app, that everything else (TVs/Rokus/Web) plays fine. I have an iTunes MP4 repackaged as MKV using BOX app (all my moves are MKV) and they have an 5.1 Dolby Digital track, Stereo Track and basic subtitles as would be in an iTunes MP4 file with the "Forced" flag set if a force subtitle set (and EN). AGain these work fine on ROKU/TV Emby apps. @unisoft are you still able to reproduce this?
unisoft 355 Posted July 1, 2021 Posted July 1, 2021 On 28/06/2021 at 14:40, Luke said: @unisoft are you still able to reproduce this? The Apple Tv is at partner's house. When I am down there next, I'll let you know. They were simple (iTunes) subtitles (SUBRIP?) not PGS
Luke 42241 Posted July 18, 2021 Posted July 18, 2021 On 7/1/2021 at 7:53 AM, unisoft said: The Apple Tv is at partner's house. When I am down there next, I'll let you know. They were simple (iTunes) subtitles (SUBRIP?) not PGS Great, thanks.
unisoft 355 Posted July 19, 2021 Posted July 19, 2021 (edited) On 18/07/2021 at 06:46, Luke said: Great, thanks. Sorry Luke, kicking myself. Was there yesterday and forgot to check. I should be there by end of this week hopefully so will check. I'd normally remember, but it was a rush visit. UPDATE: Should be able to update on Thursday 22/07/21 Edited July 20, 2021 by unisoft
unisoft 355 Posted July 23, 2021 Posted July 23, 2021 (edited) On 18/07/2021 at 06:46, Luke said: Great, thanks. Hi Luke, SubRIP (SRT?) subtitles worked BUT only if I picked the subtitles as ON and "AUTO" did not work. The MKV did have the flag set for "Forced Subtitles" too, so expectation under AUTO was for it to automatically display where there was forced subs (like it does on ROKU and LG App). MKV had one subtitle track only in English. This was the 1.5.3 (0) Apple TV app version (general release) Edited July 23, 2021 by unisoft
