EDIIIZ 0 Posted May 5, 2021 Posted May 5, 2021 Would it be possible to take that 5.1 / 7.1 PCM Stream that Emby creates by software decoding and pack it into DD or DD+ stream locally and output that? I specifically ask for locally on the device because hdr movies and audio transcoding on the server don't play well together on my 6700K. I get green artifacts because the HDR Support on that iGPU is limited. The Shield supports everything but my TV only supports Dolby Codecs and PCM 2.0. If I passthrough via ARC and Software Decode is enabled DTS gets downmixed to PCM 2.0 but if i enable "server transcode to Dolby Digital" I get the green artifacts. I know kodi can do something similar that it can decode locally to pcm and pack it into a dd stream locally. Would appreciate it!
ebr 16339 Posted May 5, 2021 Posted May 5, 2021 7 minutes ago, EDIIIZ said: Would it be possible to take that 5.1 / 7.1 PCM Stream that Emby creates by software decoding and pack it into DD or DD+ stream locally and output that? Not at this time, no. You can use the option to convert on the server though. 1
EDIIIZ 0 Posted May 5, 2021 Author Posted May 5, 2021 1 minute ago, ebr said: Not at this time, no. You can use the option to convert on the server though. Hmm, yeah but then HDR movies are not watchable because of the full screen green artifact caused by the iGPU not fully supporting HDR. Or is there a way to fix that?
rbjtech 5345 Posted May 5, 2021 Posted May 5, 2021 (edited) 16 minutes ago, EDIIIZ said: Hmm, yeah but then HDR movies are not watchable because of the full screen green artifact caused by the iGPU not fully supporting HDR. Or is there a way to fix that? In Transcoding > Advanced Try changing around the priority of the decoders - ie QuickSync and DX11VA Edited May 5, 2021 by rbjtech
ebr 16339 Posted May 5, 2021 Posted May 5, 2021 1 minute ago, rbjtech said: In Transcoding > Advanced Try changing around the priority of the decoders - ie QuickSync and DX11VA I suspect he's running into the issue of stream-copying HEVC HDR so those won't have an effect. 3
