rbjtech 5345 Posted May 4, 2021 Posted May 4, 2021 (edited) Please could you include a hyperlink to the release notes in question for a new release ? - ie the same as the current version (in green) So in the example below - 4.6.0.43 is also a hyperlink to - https://github.com/MediaBrowser/Emby.Releases/releases/tag/4.6.0.43 This way, for those with manual updates on the beta channel, we can see what is included in the next release without having to go and find the release notes ourselves. This also serves as list of what has changed so we can provide feedback on that change as necessary as opposed to guessing what has changed .. Ideally, following the install, it should also display what has changed as a one off notification. ie Fix : Fix repeated unzipping in xmltv provider, causing excess disk space to be consumed Fix : Enforce min collection size option when importing from nfo Change : Rework display of locked fields in metadata editor Add : Support multi-select remove from playlist/collection Thanks. Edited May 4, 2021 by rbjtech 1
