davedick 19 Posted May 4, 2021 Posted May 4, 2021 I've been testing Emby on a Roku Ultra LT. When I look at the channel guide, it's not in channel number order. How do I sort the guide so it's in channel number order? Thanks
pwhodges 2033 Posted May 4, 2021 Posted May 4, 2021 As I recall (I can't get at my Roku right now) you move the cursor out to the right-hand column where there are various settings icons, and do it there. But I might be thinking of the wrong screen... Paul
speechles 2062 Posted May 4, 2021 Posted May 4, 2021 You press the * button on your Roku remote. This will open the guide settings. From there you can change the layout of the guide among other things.
ebr 16334 Posted May 4, 2021 Posted May 4, 2021 Hi. Does this answer your question? The "*" button is the standard Roku settings button. 1
