nicko84 72 Posted May 3, 2021 Posted May 3, 2021 Hello, When you decide to delete a file and play another movie, ET stops playing and comes back to main menu. It happens too when you're scrolling in Emby files, deleting a file, scrolling down ... then ET goes to the top of the list or comes back to main menu (same problem in ET online when you delete files) ET have some problems with deleting files and doing another task in the same time (?)
Luke 42237 Posted May 3, 2021 Posted May 3, 2021 Hi, can you please go over a specific example? Thanks.
nicko84 72 Posted October 19, 2022 Author Posted October 19, 2022 Now ET comes back to parameters menu when i delete a file. And it takes about one or two minutes to ET to delete this file. Deleting is not instantaneous (as usual)
Luke 42237 Posted October 19, 2022 Posted October 19, 2022 Hi there @nicko84 let's look at an example. How to Report a Problem Thanks.
