Edrock200 53 Posted May 21, 2021 Posted May 21, 2021 Interesting. Updated a second test instance from 4.5 to 4.6. the libraries carried over fine, but the play history won't update again. Restored db back to 4.5 and changed container to 4.5, everything works again. I'll just stay on 4.5 for now. If no one else is reporting this then perhaps it's something unique to my setup but I can't imagine what, it's a fairly straight forward emby docker setup with /config redirected to host folder.
Luke 42203 Posted May 21, 2021 Posted May 21, 2021 Just now, Edrock200 said: Interesting. Updated a second test instance from 4.5 to 4.6. the libraries carried over fine, but the play history won't update again. Restored db back to 4.5 and changed container to 4.5, everything works again. I'll just stay on 4.5 for now. If no one else is reporting this then perhaps it's something unique to my setup but I can't imagine what, it's a fairly straight forward emby docker setup with /config redirected to host folder. I've not forgotten you, so don't worry. 1
Edrock200 53 Posted May 21, 2021 Posted May 21, 2021 One more datapoint to add. I've tested this with both the official emby docker (which is what I normally use) as well as the linuxserver docker on a second server. The reason I use the linuxserver docker on the second server is for some reason the official docker wouldn't recognize the iGPU, but the linuxserver docker would on that particular cpu/igpu.
Edrock200 53 Posted May 22, 2021 Posted May 22, 2021 18 hours ago, Luke said: I've not forgotten you, so don't worry. Thank you!
Luke 42203 Posted May 25, 2021 Posted May 25, 2021 On 5/21/2021 at 4:21 PM, Edrock200 said: One more datapoint to add. I've tested this with both the official emby docker (which is what I normally use) as well as the linuxserver docker on a second server. The reason I use the linuxserver docker on the second server is for some reason the official docker wouldn't recognize the iGPU, but the linuxserver docker would on that particular cpu/igpu. HI, what gpu?
Edrock200 53 Posted May 28, 2021 Posted May 28, 2021 Igpu in the intel 9900k proc. It did show up and work with the native container for 4.6. Has anyone else reported the play history issue or is it just me?
Edrock200 53 Posted May 28, 2021 Posted May 28, 2021 Just to close the loop in case anyone comes across this thread, I believe I was able to resolve my issue by following the steps in this article: https://support.emby.media/support/solutions/articles/44002210894-corrupt-database Source is this thread: Thanks again for the prompt support! -Ed 1
Carlo 4561 Posted May 28, 2021 Posted May 28, 2021 Glad you got this resolved and thanks for the update. 1
