mahmoudnabil 0 Posted May 2, 2021 Posted May 2, 2021 When adding PDF books to emby Not working, go to the books section in emby, but I find the file is empty. Only the file name is present even though the book format is PDF
Guest Posted May 2, 2021 Posted May 2, 2021 PDF format is not supported by EMBY at this time.. Audio Books are...
mahmoudnabil 0 Posted May 5, 2021 Author Posted May 5, 2021 Well, what is the format in which to create a library of books in emby other than in PDF format and in non-audio books?
Happy2Play 9798 Posted May 5, 2021 Posted May 5, 2021 Emby does not have a eBook reader. You can only catalog said eBooks. There are open feature requests for eBook reader within Emby though.
mrfragger 39 Posted May 5, 2021 Posted May 5, 2021 I suggest using Komga for PDFs and comics (cbr, cbz) https://komga.org or Ubooquity for PDFs, comics and epubs https://vaemendis.net/ubooquity/ both are free java ebook servers which generate covers 1
Lighthammer 91 Posted May 14, 2021 Posted May 14, 2021 On 5/5/2021 at 7:49 PM, mrfragger said: I suggest using Komga for PDFs and comics (cbr, cbz) https://komga.org or Ubooquity for PDFs, comics and epubs https://vaemendis.net/ubooquity/ both are free java ebook servers which generate covers Thanks. I was just proding the topic to see if there was any movement in getting a PDF/CBZ reading added yet. Moving those items to a dedicated project is probably the best answer.
Luke 42176 Posted July 19, 2025 Posted July 19, 2025 Emby Server 4.9.1.8+ will now have a book reader in the web app for the following formats: EPUB MOBI FB2 CBZ PDF Please try it out once available and report your experience in the Testing Area of the community: Thanks !
