Oracle 86 Posted May 2, 2021 Posted May 2, 2021 Followed all the steps the same way that Genre Cleaner does, but to no avail. Any idea what's causing this? Any known bugs?
Happy2Play 9814 Posted May 2, 2021 Posted May 2, 2021 Can you go over a specific example and post the server log.
Oracle 86 Posted May 2, 2021 Author Posted May 2, 2021 Hey, sure thing. Essentially, I've mapped together duplicates, or just grouped them together (the studios) with specific titles for my liking, and I save it. I then run a library scan, and wait...and wait...and wait. Nothing changes. Here is an attached log: embyserver.txt
Happy2Play 9814 Posted May 2, 2021 Posted May 2, 2021 @snazy2000Not seeing any errors but I can't get plugin to work in 4.5.4.0 either.
Luke 42255 Posted May 2, 2021 Posted May 2, 2021 Try refreshing metadata on existing content that has already been scanned into the library.
Oracle 86 Posted May 2, 2021 Author Posted May 2, 2021 @Luke, I tried that, as well. No bueno. It is still showing all of the studios under the Network tab in TV Shows as separated, as well as Film Studios in Movies Library.
Luke 42255 Posted May 2, 2021 Posted May 2, 2021 Try removing your third party plugins and then try again.
Oracle 86 Posted May 2, 2021 Author Posted May 2, 2021 (edited) All of them or just Studio cleaner? UPDATE: Uninstalled Studio Cleaner, restarted Server, then reinstalled Studio Cleaner. Still nothing. Edited May 2, 2021 by Arly (Sprinkles) Update
Happy2Play 9814 Posted May 2, 2021 Posted May 2, 2021 14 hours ago, Luke said: Try refreshing metadata on existing content that has already been scanned into the library. In my test this worked removing the disallowed studio. 1
Oracle 86 Posted May 2, 2021 Author Posted May 2, 2021 42 minutes ago, Happy2Play said: In my test this worked removing the disallowed studio. Can you explain to me what you mean, and the steps you took? Sorry.
Happy2Play 9814 Posted May 2, 2021 Posted May 2, 2021 1 minute ago, Arly (Sprinkles) said: Can you explain to me what you mean, and the steps you took? Sorry. I initialize Movie and TV studios via plug config, remove and/or mapped studio, hit save. Went to a item that has adjusted studio and selected Refresh Metadata/refresh all-Refresh. The mapped and/or removed studio was applied. 2021-05-02 14:20:02.642 Info App: Studio 'ABC (AU)' mapped to 'ABC' for Back Roads.
Happy2Play 9814 Posted May 2, 2021 Posted May 2, 2021 I was having issues Refreshing some, but notice the items were locked. After unlocking the refreshed. But at the same time we should not have to Refresh item to get them to map already existing studios.
