BAlGaInTl 288 Posted February 2, 2024 Posted February 2, 2024 1 hour ago, lightsout said: Anyone been able to upgrade to 4.8 on Docker/Unraid? The dashboard shows that there is an update, but I can get it to come up in docker. Using the official Emby image with this tag in the template "emby/embyserver:latest" 32 minutes ago, lightsout said: I'm not exactly sure how to interpret that but it seems like it says it's out? Oh well I don't need to complicate things it will come when it does I'm also running the official Emby docker image on Unraid. I just did a refresh and mine is NOT indicating that there is an update yet. Current version from my dashboard is 4.7.14.0. 1
Edrock200 53 Posted February 2, 2024 Posted February 2, 2024 (edited) 2 hours ago, BAlGaInTl said: I'm also running the official Emby docker image on Unraid. I just did a refresh and mine is NOT indicating that there is an update yet. Current version from my dashboard is 4.7.14.0. As far as I can tell, the "latest" tag is still pointing to 4.7.14 for both linuxserver.io and emby repos. You'll have to manually update the tag to one of the 4.8 releases if you want to update. Note it's a one way upgrade, you cannot roll back. So backup your data folder first just in case. Would be nice if the emby copied the db's to something like *.db.4.7 prior to doing the one-way schema upgrades. Edited February 2, 2024 by Edrock200
BAlGaInTl 288 Posted February 2, 2024 Posted February 2, 2024 2 hours ago, Edrock200 said: As far as I can tell, the "latest" tag is still pointing to 4.7.14 for both linuxserver.io and emby repos. You'll have to manually update the tag to one of the 4.8 releases if you want to update. Note it's a one way upgrade, you cannot roll back. So backup your data folder first just in case. Would be nice if the emby copied the db's to something like *.db.4.7 prior to doing the one-way schema upgrades. Is there a reason that it hasn't been updated to 4.8 as the latest for Docker? Is it just because it's a big change?
hjason7812 35 Posted February 2, 2024 Posted February 2, 2024 On 10/13/2014 at 8:29 PM, Luke said: I've kicked off a new docker build. keep in mind we have some new dependencies that have not been incorporated into docker yet, but we'll get it in for the next server release. libwebp - 0.4.1 MediaInfo Even the truenas core version is still the old one even when you try to force the update it won't due to the links are all still previous versions.
Luke 42242 Posted February 2, 2024 Author Posted February 2, 2024 Hi, it's coming. Apologies for the delay. 2 3
Trapperjohn61 24 Posted February 2, 2024 Posted February 2, 2024 Hi, Fyi Linuxserver has the updated version but not the official Emby repository I use the official one Thank you, Bryan @Luke 2
zer0ish 12 Posted February 2, 2024 Posted February 2, 2024 Who ever is managing the Unraid container needs to update the "More Info" tab when you click the container in Unraid. Right now it's linked to "https://registry.hub.docker.com/r/emby/embyserver/" and that link is broken. 3
Nabukodonosor 13 Posted February 3, 2024 Posted February 3, 2024 Why does it take so long to update the official Emby repository?! Should I switch to Linuxserver? 2
Trapperjohn61 24 Posted February 3, 2024 Posted February 3, 2024 18 minutes ago, Adamaen said: Or after months of waiting, just wait one or two day more Not sure of the process but one would think that the official repository would be update 1st then others just asking
Nabukodonosor 13 Posted February 3, 2024 Posted February 3, 2024 Yeah, I was thinking the same thing. Or just don't announce anything until you have it uploaded.
Edrock200 53 Posted February 3, 2024 Posted February 3, 2024 19 hours ago, Edrock200 said: Boom there it goes! Thanks! Oops, that was linuxserver.io. Easiest way to check official repo is when this tag doesn't say "5 mo ago" anymore https://hub.docker.com/r/emby/embyserver/tags?page=1&name=latest
Nabukodonosor 13 Posted February 3, 2024 Posted February 3, 2024 Yeah, but now I think it will take some time. 1
StevenDTX 15 Posted February 3, 2024 Posted February 3, 2024 I saw the post about 4.8 being released, so I removed the beta tag from my unRAID Docker. Had a little oh crap moment when it didnt come back up. Glad to find out the "latest" tag isnt updated to 4.8 yet.
Luke 42242 Posted February 3, 2024 Author Posted February 3, 2024 Hi. The Docker release is coming. Apologies for the delay. 1 1
Trapperjohn61 24 Posted February 3, 2024 Posted February 3, 2024 5 minutes ago, Luke said: Hi. The Docker release is coming. Apologies for the delay. Thank you luke sorry to bother you about this 1
Neminem 1623 Posted February 4, 2024 Posted February 4, 2024 Updated no issues to speak off. Good job guys Now to investigate whats new
DeNiX 0 Posted February 4, 2024 Posted February 4, 2024 Hi there, I'm unable to create new api keys in latest beta version, running a docker container. (fresh install) If I create a separate container with tag latest, this works as expected and api keys get created. Anybody else also experiencing this too?
Neminem 1623 Posted February 4, 2024 Posted February 4, 2024 7 minutes ago, DeNiX said: Hi there, I'm unable to create new api keys in latest beta version, running a docker container. (fresh install) If I create a separate container with tag latest, this works as expected and api keys get created. Anybody else also experiencing this too? Yes had that happen to me to. But I ran beta to test, guess the beta period is over for now. So will scrape that, and install a new when the new beta starts. But not seeing this in 4.8.0.80 where i can create and delete.
DeNiX 0 Posted February 4, 2024 Posted February 4, 2024 Thnx for the reply, i was using the beta since av1 support, never checked the latest versions to see if it was already available, but i just updated my main instance to latest, and happy to see that all is still working as expected, i was thinking if it aint broken dont fix it, since it was a pain in the ass to get it working in the first place
Trapperjohn61 24 Posted February 4, 2024 Posted February 4, 2024 Hi, So I was able to upgrade Emby server. thank you I also update the Emby apps on iPhone and ipad i am also a premiere member and entered my key on Emby startup when I go into backup and restore I find that it does not see my current backups. so I uninstalled and reinstalled restore and backup and did the Emby restarts needed but it still does not see previous 4.7 backups. Always worked before so I did a test and found if I do a backup it then sees the new backup but there are 2 files created backup full and databases I also wish to mention that when choosing the same backup folder I have used for years I find when I select it but do not hit ok I see my backups there so it does see the separate 4.7 backups with the ending auto. Am thinking there is a compatibility issue between 4.7 backups and 4.8? just guessing Thank you for your help, Bryan
tattler 31 Posted February 5, 2024 Posted February 5, 2024 On 03/02/2024 at 13:26, Nabukodonosor said: Why does it take so long to update the official Emby repository?! Should I switch to Linuxserver? I am using the Linuxserver docker image. Just upgraded yesterday without a hitch! Kudos to Emby team! Which repository should I use? Linuxserver or official Emby?
Jeansy 4 Posted February 5, 2024 Posted February 5, 2024 (edited) Hi, I updated my emby docker image to version 4.8.0.80. Now it wouldn't start anymore, leaving me the following error in the log: [s6-init] making user provided files available at /var/run/s6/etc...exited 0. s6-envuidgid: fatal: unknown user: root s6-envuidgid: fatal: unknown user: root s6-envuidgid: fatal: unknown user: root s6-envuidgid: fatal: unknown user: root s6-envuidgid: fatal: unknown user: root s6-envuidgid: fatal: unknown user: root s6-envuidgid: fatal: unknown user: root [s6-init] ensuring user provided files have correct perms...exited 0. [fix-attrs.d] applying ownership & permissions fixes... [fix-attrs.d] done. [cont-init.d] executing container initialization scripts... [cont-init.d] done. [services.d] starting services exec: fatal: unable to exec sh: Exec format error [services.d] done. [cont-finish.d] executing container finish scripts... [cont-finish.d] done. [s6-finish] waiting for services. [s6-finish] sending all processes the TERM signal. [s6-finish] sending all processes the KILL signal and exiting. My docker-compose.yml looks like this: name: emby services: app: container_name: emby environment: - TZ=Europe/Berlin - UID=1000 - GID=1000 - GIDLIST=1000 image: emby/embyserver:latest networks: - network restart: always ports: - 8096:8096 volumes: - /mnt/m/emby/programdata:/config - /mnt/f:/mnt/f networks: network: external: true Does anyone else struggle with this problem or has a hint for me how to fix it? Edited February 5, 2024 by Jeansy
alucryd 318 Posted February 5, 2024 Posted February 5, 2024 3 hours ago, tattler said: I am using the Linuxserver docker image. Just upgraded yesterday without a hitch! Kudos to Emby team! Which repository should I use? Linuxserver or official Emby? Depends on your needs, ours is very lightweight and based on busybox, you could be missing some tools for third-party post-process scripts for instance, but for general use it would be the preferred option. LSIO runs on top of a fully-fledged distro and would be more suitable for more exotic usages, including using it as a base image as you have access to a package manager to install additional linux packages in the image.
