amateurgod 33 Posted January 22, 2023 Posted January 22, 2023 18 minutes ago, Q-Droid said: Hmmm. Have you tried different caching options? When you say "partial" or better you mean higher level/more caching? I wonder how the kernel change notifications are tied to mergerfs caching levels. I don't know what else you're using this server for but since media is not exactly a high perf, high IOPS application is there any real benefit to caching in FUSE. I haven't used it though I do find it interesting that you had inotify working which contradicts all of the literature I've found for mergerfs. Another thing - is the runtime user for the emby container the same one that was running the bare metal installation? If you had tweaked your mergerfs mounts to where the old emby user was working but running the container by a different one that might also be a factor. I use mergerFS mainly for Sonarr etc to have all my drives in one mount point, I could probably change emby around so that emby is pointed at each mount point individualy instead of at the merger. I just don't understand why the RTM would work bare metal but not in docker, unless it's something to do with how emby is seeing the merger changing now that it's containerised, however I don't see why it would see it any differenty when I assigned the docker container environment variables with the UID and GID of the user that emby was running as before
Q-Droid 1011 Posted January 22, 2023 Posted January 22, 2023 21 minutes ago, amateurgod said: I use mergerFS mainly for Sonarr etc to have all my drives in one mount point, I could probably change emby around so that emby is pointed at each mount point individualy instead of at the merger. I just don't understand why the RTM would work bare metal but not in docker, unless it's something to do with how emby is seeing the merger changing now that it's containerised, however I don't see why it would see it any differenty when I assigned the docker container environment variables with the UID and GID of the user that emby was running as before I'm out of ideas so if you do get it figured out please share. There are many in the community who have tried to get this working over the years.
hapylestat 10 Posted January 30, 2023 Posted January 30, 2023 On 1/22/2023 at 7:42 PM, Q-Droid said: I'm out of ideas so if you do get it figured out please share. There are many in the community who have tried to get this working over the years. well - mergerFS is an userspace FUSE FS, while docker and any another containerization/virtualization working only with kernel level FS (coz docker, podman etc. use kernel for IO/process/network separation and kernel have no idea about your userspace FUSE stuff)
Sandro1982 0 Posted February 1, 2023 Posted February 1, 2023 On 1/22/2023 at 2:14 PM, amateurgod said: I don't use deluge however when I was running emby bare metal, "cache.files=auto-full" worked for me for the RTM, when I'm back home at my PC I'll SSH into the server and share my full mergerFS settings for you as they all worked for me for RTM when I was running baremetal, I also had to increase my max watch instances and max watch users but you shouldn't need to do that unless you have a large library with a lot of files to watch I have a library of 4,000 movies and 25,000 episodes of TV series. So I wanted to see how to configure these things.
Neminem 1623 Posted February 16, 2023 Posted February 16, 2023 (edited) Im having a strange problem. Some how the docker timezone is set to -e TZ="Europe/Paris" And my server is set to Europe/Copenhagen which is ok same time. But if i open the docker console and look at time and date, it comes out "Thu Feb 16 16:58:18 UTC 2023 " What am i doing wrong ? Its not fun to expect to watch a recording from last night, where the recording a hour late, and not what you expected. Edited February 16, 2023 by jaycedk
Q-Droid 1011 Posted February 17, 2023 Posted February 17, 2023 7 hours ago, jaycedk said: Im having a strange problem. Some how the docker timezone is set to -e TZ="Europe/Paris" And my server is set to Europe/Copenhagen which is ok same time. But if i open the docker console and look at time and date, it comes out "Thu Feb 16 16:58:18 UTC 2023 " What am i doing wrong ? Its not fun to expect to watch a recording from last night, where the recording a hour late, and not what you expected. I see the same thing in my beta container shell but the timestamps in the Emby log files are correct and match my server local time. The UTC time is also right so Emby must be picking up the correct offset. My guess is that this is fine, just that the shell doesn't reflect the location. Are the Emby times and schedules not right? Did you try changing the container TZ value to Copenhagen? I tested adding a bind mount to /etc/localtime but that didn't change anything for me.
Neminem 1623 Posted February 17, 2023 Posted February 17, 2023 Yes i have tried to change the tz to Copenhagen. And time in logs are off by 1 hour. I will look again in the tv schedules, and see if they are off by 1 hour too. When i get off work.
Q-Droid 1011 Posted February 17, 2023 Posted February 17, 2023 I would check your other containers for inconsistencies to make sure it's not docker. Maybe binding to your host /etc/localtime can fix the offset. Mine is aligned so it had no effect. The container image default is UTC.
Neminem 1623 Posted February 17, 2023 Posted February 17, 2023 lol I have found my error, and its mine alone. -e TZ="Europe/Copenhagen should be -e TZ="Europe/Copenhagen" Forgot the " in the end 1 1
Darkseidd 59 Posted March 9, 2023 Posted March 9, 2023 how do you load emby beta into docker? im using docker on portainer, on omv6
Neminem 1623 Posted March 10, 2023 Posted March 10, 2023 You can see all the different docker images here emby/embyserver Tags | Docker Hub And then you pull the docker with beta tag. 1
kbijvank 58 Posted March 17, 2023 Posted March 17, 2023 Hello, I was wondering if Emby Server is affected by this: What to know about the end of Docker Free Teams | Docker.
Luke 42242 Posted March 21, 2023 Author Posted March 21, 2023 On 3/17/2023 at 11:12 AM, kbijvank said: Hello, I was wondering if Emby Server is affected by this: What to know about the end of Docker Free Teams | Docker. Hi, yes we are. We'll let you know when we've decided on what we're going to do. Hopefully it will be just staying on Docker Hub. 1 1
kbijvank 58 Posted March 21, 2023 Posted March 21, 2023 If Docker-Hub is not possible in the future you can try ghcr.io 1
Luke 42242 Posted March 24, 2023 Author Posted March 24, 2023 On 3/21/2023 at 4:07 PM, kbijvank said: If Docker-Hub is not possible in the future you can try ghcr.io We're staying on Docker Hub, so there won't be any disruption.
kbijvank 58 Posted March 25, 2023 Posted March 25, 2023 Also, no need for any change, backlash was too big Thanks Luke! https://www.docker.com/blog/no-longer-sunsetting-the-free-team-plan/ 1
Darkseidd 59 Posted April 11, 2023 Posted April 11, 2023 h iwant to ask just purchased intelnuc and installed omv6 on it, then docker+portainer+remotemount plugin upon deploying stack, portainer shows embyserver (beta) running for few second before it show "exited" status. may i know if there's any issue on my docker compose? and how to teoubleshoot this Quote version: "2.3" services: emby: image: emby/embyserver:beta container_name: embyserver # runtime: nvidia # Expose NVIDIA GPUs # network_mode: host # Enable DLNA and Wake-on-Lan environment: - UID=1000 # The UID to run emby as (default: 2) - GID=100 # The GID to run emby as (default 2) - GIDLIST=100 # A comma-separated list of additional GIDs to run emby as (default: 2) - TZ=Asia/Singapore volumes: # - /path/to/programdata:/config # Configuration directory # - /path/to/tvshows:/mnt/share1 # Media directory # - /path/to/movies:/mnt/share2 # Media directory - /srv/remotemount/whiteSSD-remote/AppConfig/emby-beta:/config - /srv/remotemount/toshibaHDD-remote:/toshibaHDD - /srv/remotemount/whiteHDD-remote:/whiteHDD - /srv/remotemount/blackHDD-remote:/blackHDD - /srv/remotemount/redHDD-remote:/redHDD - /srv/remotemount/purpleHDD-remote:/purpleHDD - /srv/remotemount/blueHDD-remote:/blueHDD ports: - 8096:8096 # HTTP port - 8920:8920 # HTTPS port devices: - /dev/dri:/dev/dri # VAAPI/NVDEC/NVENC render nodes # - /dev/vchiq:/dev/vchiq # MMAL/OMX on Raspberry Pi restart: on-failure issue..?
Neminem 1623 Posted April 11, 2023 Posted April 11, 2023 It looks like you have commented network out. # network_mode: host # Enable DLNA and Wake-on-Lan Remove the # in front
Darkseidd 59 Posted April 12, 2023 Posted April 12, 2023 how do i confirm if my transcoding is hardware-accelerated?
Darkseidd 59 Posted April 12, 2023 Posted April 12, 2023 (edited) 2 hours ago, jaycedk said: Here is a guide. this applied for Intel QuickSync too? EDIT. got it working. added render and video id to GIDLIST Edited April 12, 2023 by Darkseidd 1
spongebob69 10 Posted May 28, 2023 Posted May 28, 2023 Could I be affected by latest hacker attack If I am using Emby in docker? I could not log in today and had to recreate container with the 4.7.12 version and now it works. Should I do any steps to fix my Emby?
Q-Droid 1011 Posted May 28, 2023 Posted May 28, 2023 Any Emby server on any platform could have been affected if they met the criteria in the advisory. The best thing for all Emby users running a server would be to read the advisory and follow the steps to identify and take action if needed. https://emby.media/support/articles/advisory-23-05.html
Trapperjohn61 24 Posted May 31, 2023 Posted May 31, 2023 Hi, If I install the update over the excising version of emby in docker of course doing a reset in docker of emby then download new version then run will that delete the files involved in the security breach? If not if I delete emby in Docker and reinstall emby new version will that delete the files involved in the security breach? Does deleting a package in docker remove the whole app directory? I ask this since it has been very hard to access the file directories of the apps I have running in docker on synology. Thank you for your help, Bryan
KMBanana 116 Posted May 31, 2023 Posted May 31, 2023 Speaking to docker generally and not Synology's implementation, "No". Docker containers are designed to be frequently discarded and entirely replaced. This happens every time you update the container. But your configs, databases, metadata, etc are stored on the host device filesystem and will persist through that process. 1
