Luke 42243 Posted June 5, 2020 Author Posted June 5, 2020 I just had the same issue, emby not starting. Had to delete the library again. Not happy, What is going on? Hi there, we're happy to help. Please see how to report a problem. Thanks !
gnollo 17 Posted June 5, 2020 Posted June 5, 2020 Hi Luke, here is the server log and previous logs for the last couple of hours embyserver.txt logs.zip
gnollo 17 Posted June 7, 2020 Posted June 7, 2020 It's now working back to normal, with the exception that the actor's pictures do not appear anymore. My metadata path is /mnt/user/ImagesByName/metadata. The People subfolder contains other folders with letters, and inside them are the actors folders with the pictures.
gnollo 17 Posted June 8, 2020 Posted June 8, 2020 Update, it's not just the pictures, but also the metadata. I found two actors amongst hundreds that work on both counts. I swear this was working before I updated the server and then had to kill the library? Refreshing people takes 57 seconds. Movie metadata downloaders was not selected under the Library option, ticked it and refreshed people again. No change. I use Media Center Master to download covers, actors and metadata. Movie covers all work fine.
Luke 42243 Posted June 9, 2020 Author Posted June 9, 2020 Update, it's not just the pictures, but also the metadata. I found two actors amongst hundreds that work on both counts. I swear this was working before I updated the server and then had to kill the library? Refreshing people takes 57 seconds. Movie metadata downloaders was not selected under the Library option, ticked it and refreshed people again. No change. I use Media Center Master to download covers, actors and metadata. Movie covers all work fine. Since you've created a separate topic (good), we'll help you there now. Thanks. 1
livtyler 0 Posted June 11, 2020 Posted June 11, 2020 (edited) Hi @Luke, I have a small issue with Emby in docker as im unable to get my IPTV. The details are correct but on looking at the logs I see the following hopefully someone cant help. Ive attached the snippet from the logs. emby.txt Edited June 11, 2020 by livtyler
Luke 42243 Posted June 15, 2020 Author Posted June 15, 2020 On 6/11/2020 at 12:31 PM, livtyler said: Hi @Luke, I have a small issue with Emby in docker as im unable to get my IPTV. The details are correct but on looking at the logs I see the following hopefully someone cant help. Ive attached the snippet from the logs. emby.txt 2.41 kB · 0 downloads Try adding https:// to the front of your m3u url if it's not already there.
livtyler 0 Posted June 15, 2020 Posted June 15, 2020 8 hours ago, Luke said: Try adding https:// to the front of your m3u url if it's not already there. Hi @Luke I get " There was an error saving the TV provider. Please ensure it is accessible and try again." These seting sowrked fine when I used Emby in a VM, does LiveTv need its own volume at all?
Luke 42243 Posted June 17, 2020 Author Posted June 17, 2020 On 6/15/2020 at 5:00 AM, livtyler said: Hi @Luke I get " There was an error saving the TV provider. Please ensure it is accessible and try again." These seting sowrked fine when I used Emby in a VM, does LiveTv need its own volume at all? Server log from that? Thanks.
NeoMatrix 4 Posted July 20, 2020 Posted July 20, 2020 I have version 4.4.3.0 Docker installed on Ubuntu 18.04 I'm getting a lot of the errors below. Could you suggest what the issue could be? Resources? Corrupt library.db etc........ As i'm using a docker this rules out the "Multiple instance" running ? (Note: I am runnig 2 seperate dockers both of Emby) (As dockers are isolated - I presume this would this not cause the multiple instance running.........) Open to any ideas, suggestions........ Thanks Info LibraryMonitor: Watching directory /storage/Movies_TUVWXYZ Info HttpServer: HTTP POST http://xxxxxxx.xxxxxx.xxx:8096/emby/Sessions/Playing/Progress. UserAgent: Dalvik/2.1.0 (Linux; U; Android 8.1.0; TX3 Mini Build/NHG47L) Info LibraryMonitor: Watching directory /storage/Music Info App: Entry point completed: Emby.ActivityLog.ActivityLogEntryPoint. Duration: 0.0381476 seconds Info App: Starting entry point Emby.Server.MediaEncoding.Api.EncodingManagerEntryPoint Info App: Entry point completed: Emby.Server.MediaEncoding.Api.EncodingManagerEntryPoint. Duration: 0.0024266 seconds Info App: Starting entry point Emby.Notifications.Notifications Error MediaSourceManager: Error getting media sources Error MediaSourceManager: Error getting media sources *** Error Report *** Version: 4.4.3.0 Command line: /system/EmbyServer.dll -programdata /config -ffdetect /bin/ffdetect -ffmpeg /bin/ffmpeg -ffprobe /bin/ffprobe -restartexitcode 3 Operating system: Unix 4.15.0.29 64-Bit OS: True 64-Bit Process: True User Interactive: True Runtime: file:///system/System.Private.CoreLib.dll System.Environment.Version: 3.1.2 Processor count: 8 Program data path: /config Application directory: /system SQLitePCL.pretty.SQLiteException: Busy: database is locked - PRAGMA journal_mode SQLitePCL.pretty.SQLiteException: Exception of type 'SQLitePCL.pretty.SQLiteException' was thrown. at SQLitePCL.pretty.SQLiteDatabaseConnection.PrepareStatement(String sql, String& tail) at SQLitePCL.pretty.DatabaseConnection.PrepareStatement(IDatabaseConnection This, String sql) at Emby.Sqlite.BaseSqliteRepository.PrepareStatement(IDatabaseConnection connection, ReadOnlySpan`1 sql) at Emby.Sqlite.BaseSqliteRepository.CreateConnection(Boolean isReadOnly) at Emby.Server.Sync.SyncRepository.GetJobItemReader[T](SyncJobItemQuery query, String baseSelectText, Func`2 itemFactory) at Emby.Server.Sync.SyncRepository.GetJobItems(SyncJobItemQuery query) at Emby.Server.Sync.SyncManager.GetJobItems(SyncJobItemQuery query) at Emby.Server.Sync.SyncedMediaSourceProvider.GetSyncedItems(BaseItem item) at Emby.Server.Sync.SyncedMediaSourceProvider.GetMediaSources(BaseItem item, CancellationToken cancellationToken) at Emby.Server.Implementations.Library.MediaSourceManager.GetDynamicMediaSources(BaseItem item, IMediaSourceProvider provider, CancellationToken cancellationToken) Source: SQLitePCL.pretty TargetSite: SQLitePCL.pretty.IStatement PrepareStatement(System.String, System.String ByRef)
BarryAmerika 24 Posted July 20, 2020 Posted July 20, 2020 29 minutes ago, NeoMatrix said: Note: I am runnig 2 seperate dockers both of Emby Did you specify alternate ports? I have found using a reverse proxy I need to specify different docker images or they will somehow clash. Even with them split into different docker networks with no ports exposed on the host. That is emby/embyserver:beta linuxserver/emby:beta In my case.
NeoMatrix 4 Posted July 20, 2020 Posted July 20, 2020 Yes sir - You cannot setup 2 dockers with the same ports so 100% they have different ports.......
NeoMatrix 4 Posted July 20, 2020 Posted July 20, 2020 But interesting regarding you must use 2 different docker images. It makes no sense that they should clash but its not difficult for me to test the theory... Open to more suggestions but I will move the second docker to a different image and see if that helps..............
NeoMatrix 4 Posted July 22, 2020 Posted July 22, 2020 just an update I am now using 2 different dockers (even if i stop the second docker) the errors continue. Anyone else hazard a guess why this is happening ? Error MediaSourceManager: Error getting media sources *** Error Report *** Version: 4.4.3.0 Command line: /system/EmbyServer.dll -programdata /config -ffdetect /bin/ffdetect -ffmpeg /bin/ffmpeg -ffprobe /bin/ffprobe -restartexitcode 3 Operating system: Unix 4.15.0.29 64-Bit OS: True 64-Bit Process: True User Interactive: True Runtime: file:///system/System.Private.CoreLib.dll System.Environment.Version: 3.1.2 Processor count: 8 Program data path: /config Application directory: /system SQLitePCL.pretty.SQLiteException: Busy: database is locked - PRAGMA journal_mode SQLitePCL.pretty.SQLiteException: Exception of type 'SQLitePCL.pretty.SQLiteException' was thrown. at SQLitePCL.pretty.SQLiteDatabaseConnection.PrepareStatement(String sql, String& tail) at SQLitePCL.pretty.DatabaseConnection.PrepareStatement(IDatabaseConnection This, String sql) at Emby.Sqlite.BaseSqliteRepository.PrepareStatement(IDatabaseConnection connection, ReadOnlySpan`1 sql) at Emby.Sqlite.BaseSqliteRepository.CreateConnection(Boolean isReadOnly) at Emby.Server.Sync.SyncRepository.GetJobItemReader[T](SyncJobItemQuery query, String baseSelectText, Func`2 itemFactory) at Emby.Server.Sync.SyncRepository.GetJobItems(SyncJobItemQuery query) at Emby.Server.Sync.SyncManager.GetJobItems(SyncJobItemQuery query) at Emby.Server.Sync.SyncedMediaSourceProvider.GetSyncedItems(BaseItem item) at Emby.Server.Sync.SyncedMediaSourceProvider.GetMediaSources(BaseItem item, CancellationToken cancellationToken) at Emby.Server.Implementations.Library.MediaSourceManager.GetDynamicMediaSources(BaseItem item, IMediaSourceProvider provider, CancellationToken cancellationToken) Source: SQLitePCL.pretty TargetSite: SQLitePCL.pretty.IStatement PrepareStatement(System.String, System.String ByRef)
mastrmind11 722 Posted July 22, 2020 Posted July 22, 2020 3 hours ago, NeoMatrix said: just an update I am now using 2 different dockers (even if i stop the second docker) the errors continue. Anyone else hazard a guess why this is happening ? Error MediaSourceManager: Error getting media sources *** Error Report *** Version: 4.4.3.0 Command line: /system/EmbyServer.dll -programdata /config -ffdetect /bin/ffdetect -ffmpeg /bin/ffmpeg -ffprobe /bin/ffprobe -restartexitcode 3 Operating system: Unix 4.15.0.29 64-Bit OS: True 64-Bit Process: True User Interactive: True Runtime: file:///system/System.Private.CoreLib.dll System.Environment.Version: 3.1.2 Processor count: 8 Program data path: /config Application directory: /system SQLitePCL.pretty.SQLiteException: Busy: database is locked - PRAGMA journal_mode SQLitePCL.pretty.SQLiteException: Exception of type 'SQLitePCL.pretty.SQLiteException' was thrown. at SQLitePCL.pretty.SQLiteDatabaseConnection.PrepareStatement(String sql, String& tail) at SQLitePCL.pretty.DatabaseConnection.PrepareStatement(IDatabaseConnection This, String sql) at Emby.Sqlite.BaseSqliteRepository.PrepareStatement(IDatabaseConnection connection, ReadOnlySpan`1 sql) at Emby.Sqlite.BaseSqliteRepository.CreateConnection(Boolean isReadOnly) at Emby.Server.Sync.SyncRepository.GetJobItemReader[T](SyncJobItemQuery query, String baseSelectText, Func`2 itemFactory) at Emby.Server.Sync.SyncRepository.GetJobItems(SyncJobItemQuery query) at Emby.Server.Sync.SyncManager.GetJobItems(SyncJobItemQuery query) at Emby.Server.Sync.SyncedMediaSourceProvider.GetSyncedItems(BaseItem item) at Emby.Server.Sync.SyncedMediaSourceProvider.GetMediaSources(BaseItem item, CancellationToken cancellationToken) at Emby.Server.Implementations.Library.MediaSourceManager.GetDynamicMediaSources(BaseItem item, IMediaSourceProvider provider, CancellationToken cancellationToken) Source: SQLitePCL.pretty TargetSite: SQLitePCL.pretty.IStatement PrepareStatement(System.String, System.String ByRef) You can't share a database... makes sense if you think about it, there would be row contention everywhere.
NeoMatrix 4 Posted July 22, 2020 Posted July 22, 2020 Im not sure what gives the impression im sharing a database? I certainly am not sharing a database unless Ive completely lost my mind.......... its an isolated docker. if i have 1 or 10 its not sharing a DB and even with just a single docker running , im encountering this issue. Maybe a corrupt library DB file? I assume I can just delete it and redo my metadata scan? willing to listen to all ideas........
NeoMatrix 4 Posted July 22, 2020 Posted July 22, 2020 See attached image - anyone know what these errors mean? Can they be ignored? Can they be fixed?
BarryAmerika 24 Posted July 24, 2020 Posted July 24, 2020 So you definitely mapped different persistent data volumes to each docker? I would stop both containers, delete the wal and shm files that are next to the DB in the containers respective persistent data locations and restart one only and see what errors it throws. Once you have one working I would stop it and then start the other. Are they both blank instances? Nothing scanned yet? Are you able to share the docker configs from each? Just remove any personal information or URLs first.
NeoMatrix 4 Posted July 25, 2020 Posted July 25, 2020 Barry, Stopped both containers and deleted Wal and shm started just 1 container but same issues persist. Both dockers are fully scanned and indexed.
mastrmind11 722 Posted July 25, 2020 Posted July 25, 2020 2 hours ago, NeoMatrix said: Barry, Stopped both containers and deleted Wal and shm started just 1 container but same issues persist. Both dockers are fully scanned and indexed. share your run command for each. hav you tried smoking your /config directories and removing/restarting your container?
NeoMatrix 4 Posted July 25, 2020 Posted July 25, 2020 Thx - Ill post my config files in about an hour so I'm specific... (when I get home) is "smoking /your config" a typo? removed/restarted container already yes. But using the same persisten volume on my HD.... Ill be back with my config line within an hour.............
NeoMatrix 4 Posted July 25, 2020 Posted July 25, 2020 (edited) here my run command.... docker run -d --volume /home/docker/embyconfig:/config --volume /home/storagemedia:/storage --publish 98096:8096 --publish 98920:8920 --env UID=1000 --env GID=1000 emby/embyserver:latest I do have a non-privalged user with UID, GIF of 1000 If this is relevant, I have noticed some high CPU_IOWAIT times that coinside with the horrid slowness..... Edited July 25, 2020 by NeoMatrix
BarryAmerika 24 Posted July 26, 2020 Posted July 26, 2020 On 7/26/2020 at 1:08 AM, NeoMatrix said: But using the same persisten volume on my HD.. This is where the DB is stored so you are hitting that DB with two different instances and sharing it as was suggested by mastrmind11. Each instance will need its own persistent volume.
