Bonesoul 0 Posted February 18, 2020 Posted February 18, 2020 (edited) my docker config is emby: image: emby/embyserver_arm64v8:latest hostname: emby container_name: emby restart: unless-stopped networks: - default ports: - "${EMBY_PORT_1}:8096/tcp" - "${EMBY_PORT_2}:8920/tcp" volumes: - ${USERDIR}/docker/config/emby:/config - /dev/shm:/transcode - ${USERDIR}/docker/data/emby/nas:/nas - ${USERDIR}/docker/data/emby/downloads:/downloads environment: TZ: ${TZ} HOSTNAME: "emby" UID: ${PUID} GID: ${PGID} and the .env is PUID=1000 PGID=998 USERDIR=/home/ubuntu TZ=UTC EMBY_PORT_1=8096 EMBY_PORT_2=8920 in the final step of emby wizard i get these errors; Uncaught (in promise) Error: Load failed: wizard/wizardagreement: http://10.0.0.20:8096/web/wizard/wizardagreement.js?v=4.3.1.0 at HTMLScriptElement.<anonymous> (alameda.js:1) Failed to load resource: the server responded with a status of 403 (Forbidden) :8096/web/index.html?start=wizard#!/wizard/wizardagreement.html:1 Uncaught (in promise) Response apiclient.js?v=4.3.1.0:1 POST http://10.0.0.20:8096/emby/Startup/RemoteAccess 403 (Forbidden) getFetchPromise @ apiclient.js?v=4.3.1.0:1 ApiClient.fetch @ apiclient.js?v=4.3.1.0:1 ApiClient.ajax @ apiclient.js?v=4.3.1.0:1 save @ wizardremoteaccess.js?v=4.3.1.0:1 onSubmit @ wizardremoteaccess.js?v=4.3.1.0:1 :8096/web/index.html?start=wizard#!/wizard/wizardagreement.html:1 Uncaught (in promise) Response {type: "basic", url: "http://10.0.0.20:8096/emby/Startup/RemoteAccess",redirected: false, status: 403, ok: false, …} any ideas? Edited February 18, 2020 by Bonesoul
Luke 42243 Posted February 18, 2020 Author Posted February 18, 2020 Does the server log have anything?
mediacowboy 438 Posted February 29, 2020 Posted February 29, 2020 (edited) Delete Edited March 1, 2020 by mediacowboy
Luke 42243 Posted March 3, 2020 Author Posted March 3, 2020 For those looking for additional options to run Emby Server, we now have Snap packages available for testing: https://emby.media/community/index.php?/topic/83274-emby-server-snap-packages/ Thanks !
Riggs 312 Posted April 1, 2020 Posted April 1, 2020 @@Luke Can you check why Emby always change the permissions after each update on docker? I need to reset the permission and acl's of my shares every time that I update Emby. Thanks.
Luke 42243 Posted April 1, 2020 Author Posted April 1, 2020 Perhaps it's the docker container doing that? There's nothing directly in emby server that checks or changes permissions. 1
Riggs 312 Posted April 1, 2020 Posted April 1, 2020 Perhaps it's the docker container doing that? There's nothing directly in emby server that checks or changes permissions. Okay, thank you, I will going to check.
Max20 0 Posted April 10, 2020 Posted April 10, 2020 (edited) Good evening all, dear @Luke, My family and I love Emby and we have been using it for quite a while now. The investment into Emby Premiere was a good one. I am running the Emby docker on my OpenMediaVault system. Being a tech enthusiast but not a linux expert at all, I have so far always been successful to resolve my issues searching this forum. But after hours or rather days of unsuccessful searching, it's time for my first post, and I hope it's the right location for it... My issue: I want to run a post-processing script (Emby DVR) to cut commercials, convert the .TS to .MKV, extract subtitles etc. And I have found installation guides for comskip and comchap as well as suitable scripts. I have installed comskip, comchap etc. on the docker host system (debian). Calling the post-processing script from the Emby container however doesn't work as the Emby container - so my understanding - does not have comskip etc. plus dependencies installed and therefore cannot run the script successfully. My "simple" question: how can I give the Emby docker access to the post-processing applications/scripts on the host system? If it is possible? I read about the concept of using "- /var/run/docker.sock:/var/run/docker.sock" to give a docker access to a host system but no idea whether this would help here and where I should put it. Any help how I can enable post-processing on my Emby docker would be much appreciated - before I go completely mad.... Thanks! Edited April 10, 2020 by Max20
Luke 42243 Posted April 12, 2020 Author Posted April 12, 2020 ^^ Hmm. @@mastrmind11 have you ever tried that before?
mastrmind11 722 Posted April 13, 2020 Posted April 13, 2020 No I've never done it, but isn't it as simple as mapping the location of comskip as a volume in your docker run command? Then just point emby's post processing var at that volume inside the container? I've not played with post processing so I'm not sure what is even involved, but to give docker access to the host filesystem, it needs to know what you need mapped.
Riggs 312 Posted April 13, 2020 Posted April 13, 2020 (edited) Easy install Emby on Portainer with OMV 5. PULL:emby/embyserver <------ for stable version emby/embyserver:beta <--------for beta version 1-NETWORK: HOST2-RESTART POLICY: ALWAYS3-VOLUMES SECTION: A- YOUR SHARES/mnt/share1 ( always choose bind)/srv/dev-disk-by-label-YOUR-SHARE/YOUR-SHARE (you need to get the absolute path like the example) ( you can add more shares, for the second /mnt/share2 and so) B- YOUR CONFIG FILE PATH/config/srv/appdata/emby--------------------------------------------------------------- ENVIRONMENTAL SECTION: (Check your user ID first) UID=1000GID=100GIDLIST=100 LAST STEP: Click on DEPLOY CONTAINER. (wait a few seconds) That's all. Hope helps Edited April 13, 2020 by Handbrake
Max20 0 Posted April 15, 2020 Posted April 15, 2020 Thank you gents, I will try that again and report back once I found the time.
Irontony 1 Posted April 19, 2020 Posted April 19, 2020 Easy install Emby on Portainer with OMV 5. PULL: emby/embyserver <------ for stable version emby/embyserver:beta <--------for beta version 1-NETWORK: HOST 2-RESTART POLICY: ALWAYS 3-VOLUMES SECTION: A- YOUR SHARES /mnt/share1 ( always choose bind) /srv/dev-disk-by-label-YOUR-SHARE/YOUR-SHARE (you need to get the absolute path like the example) ( you can add more shares, for the second /mnt/share2 and so) B- YOUR CONFIG FILE PATH /config /srv/appdata/emby --------------------------------------------------------------- ENVIRONMENTAL SECTION: (Check your user ID first) UID=1000 GID=100 GIDLIST=100 LAST STEP: Click on DEPLOY CONTAINER. (wait a few seconds) That's all. Hope helps After watching 10hrs of crappy videos, I had to search the forum and within 15mins, everything fell into place. CUDOS to Handbrake.! 1
Riggs 312 Posted April 28, 2020 Posted April 28, 2020 After watching 10hrs of crappy videos, I had to search the forum and within 15mins, everything fell into place. CUDOS to Handbrake.! Glad to can help (yes, i change my name here)
gnollo 17 Posted May 21, 2020 Posted May 21, 2020 Emby docker will not start anymore, deleted the docker, including the image, re-installed and it keeps stopping on an unraid server. Any suggestions on how I can start again from scratch? Log below ErrorWarningSystemArrayLogin [s6-init] making user provided files available at /var/run/s6/etc...exited 0.[s6-init] ensuring user provided files have correct perms...exited 0.[fix-attrs.d] applying ownership & permissions fixes...[fix-attrs.d] done.[cont-init.d] executing container initialization scripts...[cont-init.d] done.[services.d] starting services[services.d] done.Info Main: Application path: /system/EmbyServer.dllInfo Main: EmbyCommand line: /system/EmbyServer.dll -programdata /config -ffdetect /bin/ffdetect -ffmpeg /bin/ffmpeg -ffprobe /bin/ffprobe -restartexitcode 3Operating system: Unix 4.19.41.064-Bit OS: True64-Bit Process: TrueUser Interactive: TrueRuntime: file:///system/System.Private.CoreLib.dllSystem.Environment.Version: 3.1.2Processor count: 4Program data path: /configApplication directory: /systemInfo App: Application version: 4.4.2.0Info App: Loading assembliesInfo App: File /config/plugins/Emby.Dlna.dll has version 1.0.37.0Info App: File /system/plugins/Emby.Dlna.dll has version 1.0.37.0Info App: File /config/plugins/Emby.PortMapper.dll has version 1.0.4.0Info App: File /system/plugins/Emby.PortMapper.dll has version 1.0.4.0Info App: File /config/plugins/Emby.Server.CinemaMode.dll has version 1.0.31.0Info App: File /system/plugins/Emby.Server.CinemaMode.dll has version 1.0.31.0Info App: File /config/plugins/Emby.Webhooks.dll has version 1.0.11.0Info App: File /system/plugins/Emby.Webhooks.dll has version 1.0.11.0Info App: File /config/plugins/MovieDb.dll has version 1.3.4.0Info App: File /system/plugins/MovieDb.dll has version 1.3.4.0Info App: File /config/plugins/NfoMetadata.dll has version 1.0.29.0Info App: File /system/plugins/NfoMetadata.dll has version 1.0.29.0Info App: File /config/plugins/OpenSubtitles.dll has version 1.0.26.0Info App: File /system/plugins/OpenSubtitles.dll has version 1.0.26.0Info App: File /config/plugins/Tvdb.dll has version 1.0.32.0Info App: File /system/plugins/Tvdb.dll has version 1.0.30.0Info App: Loading MovieDb, Version=1.3.4.0, Culture=neutral, PublicKeyToken=null from /config/plugins/MovieDb.dllInfo App: Loading XmlMetadata, Version=3.3.6.0, Culture=neutral, PublicKeyToken=null from /config/plugins/XmlMetadata.dllInfo App: Loading Tvdb, Version=1.0.32.0, Culture=neutral, PublicKeyToken=null from /config/plugins/Tvdb.dllInfo App: Loading MBBackup, Version=1.4.4.0, Culture=neutral, PublicKeyToken=null from /config/plugins/MBBackup.dllInfo App: Loading Emby.PortMapper, Version=1.0.4.0, Culture=neutral, PublicKeyToken=null from /config/plugins/Emby.PortMapper.dllInfo App: Loading Emby.Server.CinemaMode, Version=1.0.31.0, Culture=neutral, PublicKeyToken=null from /config/plugins/Emby.Server.CinemaMode.dllInfo App: Loading OpenSubtitles, Version=1.0.26.0, Culture=neutral, PublicKeyToken=null from /config/plugins/OpenSubtitles.dllInfo App: Loading Emby.Webhooks, Version=1.0.11.0, Culture=neutral, PublicKeyToken=null from /config/plugins/Emby.Webhooks.dllInfo App: Loading Emby.Dlna, Version=1.0.37.0, Culture=neutral, PublicKeyToken=null from /config/plugins/Emby.Dlna.dllInfo App: Loading MediaBrowser.Plugins.Trailers, Version=1.2.9.0, Culture=neutral, PublicKeyToken=null from /config/plugins/Mediabrowser.Plugins.Trailers.dllInfo App: Loading NfoMetadata, Version=1.0.29.0, Culture=neutral, PublicKeyToken=null from /config/plugins/NfoMetadata.dllInfo App: Loading Emby.Api, Version=4.4.2.0, Culture=neutral, PublicKeyToken=nullInfo App: Loading Emby.Web, Version=4.4.2.0, Culture=neutral, PublicKeyToken=nullInfo App: Loading MediaBrowser.Model, Version=4.4.2.0, Culture=neutral, PublicKeyToken=nullInfo App: Loading MediaBrowser.Common, Version=4.4.2.0, Culture=neutral, PublicKeyToken=nullInfo App: Loading MediaBrowser.Controller, Version=4.4.2.0, Culture=neutral, PublicKeyToken=nullInfo App: Loading Emby.Providers, Version=4.4.2.0, Culture=neutral, PublicKeyToken=nullInfo App: Loading Emby.Photos, Version=4.4.2.0, Culture=neutral, PublicKeyToken=nullInfo App: Loading Emby.Server.Implementations, Version=4.4.2.0, Culture=neutral, PublicKeyToken=nullInfo App: Loading Emby.LiveTV, Version=4.4.2.0, Culture=neutral, PublicKeyToken=nullInfo App: Loading Emby.ActivityLog, Version=1.0.0.0, Culture=neutral, PublicKeyToken=nullInfo App: Loading Emby.Server.MediaEncoding, Version=4.4.2.0, Culture=neutral, PublicKeyToken=nullInfo App: Loading Emby.LocalMetadata, Version=4.4.2.0, Culture=neutral, PublicKeyToken=nullInfo App: Loading Emby.Notifications, Version=4.4.2.0, Culture=neutral, PublicKeyToken=nullInfo App: Loading Emby.Codecs.Dxva, Version=4.4.2.0, Culture=neutral, PublicKeyToken=nullInfo App: Loading Emby.Codecs, Version=4.4.2.0, Culture=neutral, PublicKeyToken=nullInfo App: Loading Emby.Server.Connect, Version=4.4.2.0, Culture=neutral, PublicKeyToken=nullInfo App: Loading Emby.Server.Sync, Version=4.4.2.0, Culture=neutral, PublicKeyToken=nullInfo App: Loading EmbyServer, Version=4.4.2.0, Culture=neutral, PublicKeyToken=nullInfo SqliteUserRepository: Sqlite version: 3.31.1Info SqliteUserRepository: Sqlite compiler options: COMPILER=gcc-8.3.0,ENABLE_COLUMN_METADATA,ENABLE_DBSTAT_VTAB,ENABLE_FTS3_PARENTHESIS,ENABLE_FTS3_TOKENIZER,ENABLE_FTS4,ENABLE_FTS5,ENABLE_GEOPOLY,ENABLE_JSON1,ENABLE_PREUPDATE_HOOK,ENABLE_RTREE,ENABLE_SESSION,ENABLE_UNLOCK_NOTIFY,ENABLE_UPDATE_DELETE_LIMIT,LIKE_DOESNT_MATCH_BLOBS,MAX_SCHEMA_RETRY=25,MAX_VARIABLE_NUMBER=250000,OMIT_LOOKASIDE,SECURE_DELETE,THREADSAFE=1Info SqliteUserRepository: Default journal_mode for /config/data/users.db is walInfo AuthenticationRepository: Default journal_mode for /config/data/authentication.db is walInfo ActivityRepository: Default journal_mode for /config/data/activitylog.db is walInfo SqliteDisplayPreferencesRepository: Default journal_mode for /config/data/displaypreferences.db is walInfo App: Adding HttpListener prefix http://+:8096/Info App: Adding HttpListener prefix https://+:8920/Debug XmlSerializer: Deserializing file /config/config/users/51ffa484dd4f4d0c93084380e8c86dac/policy.xmlInfo SqliteItemRepository: Default journal_mode for /config/data/library.db is walError Main: Error in appHost.Init*** Error Report ***Version: 4.4.2.0Command line: /system/EmbyServer.dll -programdata /config -ffdetect /bin/ffdetect -ffmpeg /bin/ffmpeg -ffprobe /bin/ffprobe -restartexitcode 3Operating system: Unix 4.19.41.064-Bit OS: True64-Bit Process: TrueUser Interactive: TrueRuntime: file:///system/System.Private.CoreLib.dllSystem.Environment.Version: 3.1.2Processor count: 4Program data path: /configApplication directory: /systemSQLitePCL.pretty.SQLiteException: Corrupt: database disk image is malformedSQLitePCL.pretty.SQLiteException: Exception of type 'SQLitePCL.pretty.SQLiteException' was thrown.at SQLitePCL.pretty.SQLiteException.CheckOk(sqlite3 db, Int32 rc)at SQLitePCL.pretty.SQLiteException.CheckOk(sqlite3_stmt stmt, Int32 rc)at SQLitePCL.pretty.StatementImpl.MoveNext()at SQLitePCL.pretty.DatabaseConnection.ExecuteAll(IDatabaseConnection This, String sql)at Emby.Server.Implementations.Data.SqliteItemRepository.Initialize(SqliteUserDataRepository userDataRepo, IUserManager userManager)at Emby.Server.Implementations.ApplicationHost.InitDatabases()at Emby.Server.Implementations.ApplicationHost.Init()at EmbyServer.HostedService.StartAsync(CancellationToken cancellationToken)Source: SQLitePCL.prettyTargetSite: Void CheckOk(SQLitePCL.sqlite3, Int32)Info Main: Shutdown complete[cont-finish.d] executing container finish scripts...[cont-finish.d] done.[s6-finish] waiting for services.[s6-finish] sending all processes the TERM signal.[s6-finish] sending all processes the KILL signal and exiting.[s6-init] making user provided files available at /var/run/s6/etc...exited 0.[s6-init] ensuring user provided files have correct perms...exited 0.[fix-attrs.d] applying ownership & permissions fixes...[fix-attrs.d] done.[cont-init.d] executing container initialization scripts...[cont-init.d] done.[services.d] starting services[services.d] done.Info Main: Application path: /system/EmbyServer.dllInfo Main: EmbyCommand line: /system/EmbyServer.dll -programdata /config -ffdetect /bin/ffdetect -ffmpeg /bin/ffmpeg -ffprobe /bin/ffprobe -restartexitcode 3Operating system: Unix 4.19.41.064-Bit OS: True64-Bit Process: TrueUser Interactive: TrueRuntime: file:///system/System.Private.CoreLib.dllSystem.Environment.Version: 3.1.2Processor count: 4Program data path: /configApplication directory: /systemInfo App: Application version: 4.4.2.0Info App: Loading assembliesInfo App: File /config/plugins/Emby.Dlna.dll has version 1.0.37.0Info App: File /system/plugins/Emby.Dlna.dll has version 1.0.37.0Info App: File /config/plugins/Emby.PortMapper.dll has version 1.0.4.0Info App: File /system/plugins/Emby.PortMapper.dll has version 1.0.4.0Info App: File /config/plugins/Emby.Server.CinemaMode.dll has version 1.0.31.0Info App: File /system/plugins/Emby.Server.CinemaMode.dll has version 1.0.31.0Info App: File /config/plugins/Emby.Webhooks.dll has version 1.0.11.0Info App: File /system/plugins/Emby.Webhooks.dll has version 1.0.11.0Info App: File /config/plugins/MovieDb.dll has version 1.3.4.0Info App: File /system/plugins/MovieDb.dll has version 1.3.4.0Info App: File /config/plugins/NfoMetadata.dll has version 1.0.29.0Info App: File /system/plugins/NfoMetadata.dll has version 1.0.29.0Info App: File /config/plugins/OpenSubtitles.dll has version 1.0.26.0Info App: File /system/plugins/OpenSubtitles.dll has version 1.0.26.0Info App: File /config/plugins/Tvdb.dll has version 1.0.32.0Info App: File /system/plugins/Tvdb.dll has version 1.0.30.0Info App: Loading MovieDb, Version=1.3.4.0, Culture=neutral, PublicKeyToken=null from /config/plugins/MovieDb.dllInfo App: Loading XmlMetadata, Version=3.3.6.0, Culture=neutral, PublicKeyToken=null from /config/plugins/XmlMetadata.dllInfo App: Loading Tvdb, Version=1.0.32.0, Culture=neutral, PublicKeyToken=null from /config/plugins/Tvdb.dllInfo App: Loading MBBackup, Version=1.4.4.0, Culture=neutral, PublicKeyToken=null from /config/plugins/MBBackup.dllInfo App: Loading Emby.PortMapper, Version=1.0.4.0, Culture=neutral, PublicKeyToken=null from /config/plugins/Emby.PortMapper.dllInfo App: Loading Emby.Server.CinemaMode, Version=1.0.31.0, Culture=neutral, PublicKeyToken=null from /config/plugins/Emby.Server.CinemaMode.dllInfo App: Loading OpenSubtitles, Version=1.0.26.0, Culture=neutral, PublicKeyToken=null from /config/plugins/OpenSubtitles.dllInfo App: Loading Emby.Webhooks, Version=1.0.11.0, Culture=neutral, PublicKeyToken=null from /config/plugins/Emby.Webhooks.dllInfo App: Loading Emby.Dlna, Version=1.0.37.0, Culture=neutral, PublicKeyToken=null from /config/plugins/Emby.Dlna.dllInfo App: Loading MediaBrowser.Plugins.Trailers, Version=1.2.9.0, Culture=neutral, PublicKeyToken=null from /config/plugins/Mediabrowser.Plugins.Trailers.dllInfo App: Loading NfoMetadata, Version=1.0.29.0, Culture=neutral, PublicKeyToken=null from /config/plugins/NfoMetadata.dllInfo App: Loading Emby.Api, Version=4.4.2.0, Culture=neutral, PublicKeyToken=nullInfo App: Loading Emby.Web, Version=4.4.2.0, Culture=neutral, PublicKeyToken=nullInfo App: Loading MediaBrowser.Model, Version=4.4.2.0, Culture=neutral, PublicKeyToken=nullInfo App: Loading MediaBrowser.Common, Version=4.4.2.0, Culture=neutral, PublicKeyToken=nullInfo App: Loading MediaBrowser.Controller, Version=4.4.2.0, Culture=neutral, PublicKeyToken=nullInfo App: Loading Emby.Providers, Version=4.4.2.0, Culture=neutral, PublicKeyToken=nullInfo App: Loading Emby.Photos, Version=4.4.2.0, Culture=neutral, PublicKeyToken=nullInfo App: Loading Emby.Server.Implementations, Version=4.4.2.0, Culture=neutral, PublicKeyToken=nullInfo App: Loading Emby.LiveTV, Version=4.4.2.0, Culture=neutral, PublicKeyToken=nullInfo App: Loading Emby.ActivityLog, Version=1.0.0.0, Culture=neutral, PublicKeyToken=nullInfo App: Loading Emby.Server.MediaEncoding, Version=4.4.2.0, Culture=neutral, PublicKeyToken=nullInfo App: Loading Emby.LocalMetadata, Version=4.4.2.0, Culture=neutral, PublicKeyToken=nullInfo App: Loading Emby.Notifications, Version=4.4.2.0, Culture=neutral, PublicKeyToken=nullInfo App: Loading Emby.Codecs.Dxva, Version=4.4.2.0, Culture=neutral, PublicKeyToken=nullInfo App: Loading Emby.Codecs, Version=4.4.2.0, Culture=neutral, PublicKeyToken=nullInfo App: Loading Emby.Server.Connect, Version=4.4.2.0, Culture=neutral, PublicKeyToken=nullInfo App: Loading Emby.Server.Sync, Version=4.4.2.0, Culture=neutral, PublicKeyToken=nullInfo App: Loading EmbyServer, Version=4.4.2.0, Culture=neutral, PublicKeyToken=nullInfo SqliteUserRepository: Sqlite version: 3.31.1Info SqliteUserRepository: Sqlite compiler options: COMPILER=gcc-8.3.0,ENABLE_COLUMN_METADATA,ENABLE_DBSTAT_VTAB,ENABLE_FTS3_PARENTHESIS,ENABLE_FTS3_TOKENIZER,ENABLE_FTS4,ENABLE_FTS5,ENABLE_GEOPOLY,ENABLE_JSON1,ENABLE_PREUPDATE_HOOK,ENABLE_RTREE,ENABLE_SESSION,ENABLE_UNLOCK_NOTIFY,ENABLE_UPDATE_DELETE_LIMIT,LIKE_DOESNT_MATCH_BLOBS,MAX_SCHEMA_RETRY=25,MAX_VARIABLE_NUMBER=250000,OMIT_LOOKASIDE,SECURE_DELETE,THREADSAFE=1Info SqliteUserRepository: Default journal_mode for /config/data/users.db is walInfo AuthenticationRepository: Default journal_mode for /config/data/authentication.db is walInfo ActivityRepository: Default journal_mode for /config/data/activitylog.db is walInfo SqliteDisplayPreferencesRepository: Default journal_mode for /config/data/displaypreferences.db is walInfo App: Adding HttpListener prefix http://+:8096/Info App: Adding HttpListener prefix https://+:8920/Debug XmlSerializer: Deserializing file /config/config/users/51ffa484dd4f4d0c93084380e8c86dac/policy.xmlInfo SqliteItemRepository: Default journal_mode for /config/data/library.db is walError Main: Error in appHost.Init*** Error Report ***Version: 4.4.2.0Command line: /system/EmbyServer.dll -programdata /config -ffdetect /bin/ffdetect -ffmpeg /bin/ffmpeg -ffprobe /bin/ffprobe -restartexitcode 3Operating system: Unix 4.19.41.064-Bit OS: True64-Bit Process: TrueUser Interactive: TrueRuntime: file:///system/System.Private.CoreLib.dllSystem.Environment.Version: 3.1.2Processor count: 4Program data path: /configApplication directory: /systemSQLitePCL.pretty.SQLiteException: Corrupt: database disk image is malformedSQLitePCL.pretty.SQLiteException: Exception of type 'SQLitePCL.pretty.SQLiteException' was thrown.at SQLitePCL.pretty.SQLiteException.CheckOk(sqlite3 db, Int32 rc)at SQLitePCL.pretty.SQLiteException.CheckOk(sqlite3_stmt stmt, Int32 rc)at SQLitePCL.pretty.StatementImpl.MoveNext()at SQLitePCL.pretty.DatabaseConnection.ExecuteAll(IDatabaseConnection This, String sql)at Emby.Server.Implementations.Data.SqliteItemRepository.Initialize(SqliteUserDataRepository userDataRepo, IUserManager userManager)at Emby.Server.Implementations.ApplicationHost.InitDatabases()at Emby.Server.Implementations.ApplicationHost.Init()at EmbyServer.HostedService.StartAsync(CancellationToken cancellationToken)Source: SQLitePCL.prettyTargetSite: Void CheckOk(SQLitePCL.sqlite3, Int32)Info Main: Shutdown complete[cont-finish.d] executing container finish scripts...[cont-finish.d] done.[s6-finish] waiting for services.[s6-finish] sending all processes the TERM signal.[s6-finish] sending all processes the KILL signal and exiting.
Whiskeyjack 6 Posted May 31, 2020 Posted May 31, 2020 (edited) I was trying to add a path in the unRaid docker and mistyped it, so the update failed...which then erased my docker. I re-installed the container and now all my saved states/continue watching is gone. Any way to recover this? I'm using the same appdata folder. EDIT: Restored a backup but playstates haven't returned. EDIT2: My mistake. I didn't allow the library scan to complete first. Issue looks like it'll be resolved. Edited May 31, 2020 by Whiskeyjack 2
BAlGaInTl 288 Posted June 1, 2020 Posted June 1, 2020 I was trying to add a path in the unRaid docker and mistyped it, so the update failed...which then erased my docker. I re-installed the container and now all my saved states/continue watching is gone. Any way to recover this? I'm using the same appdata folder. EDIT: Restored a backup but playstates haven't returned. EDIT2: My mistake. I didn't allow the library scan to complete first. Issue looks like it'll be resolved. Good to know that you got the issue resolved.
Pog22 52 Posted June 2, 2020 Posted June 2, 2020 I'm getting a new version 4.4.3.0 is available notifications since yesterday, I destroyed and pulled down the latest docker but it's still on 4.4.2.0
BAlGaInTl 288 Posted June 2, 2020 Posted June 2, 2020 I'm getting a new version 4.4.3.0 is available notifications since yesterday, I destroyed and pulled down the latest docker but it's still on 4.4.2.0 The Docker version can lag a bit behind at times. It will show up. Are you using the official docker or one of the other ones out there?
Riggs 312 Posted June 2, 2020 Posted June 2, 2020 It should be up now. There is a new beta up newer than 4.5.0.12?
gnollo 17 Posted June 5, 2020 Posted June 5, 2020 I just had the same issue, emby not starting. Had to delete the library again. Not happy, What is going on?
